Old 02-03-2014, 10:41 PM   #1
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Dyno :)
[ame="http://youtu.be/fYWZHgrCD5k"]http://youtu.be/fYWZHgrCD5k[/ame]
Tuned by R/T Tuning in Landsdale, PA. Vendor on here..
93 octane gas
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following User Says Thank You to woode For This Useful Post:
R/T Tuning (02-03-2014)
Old 02-03-2014, 10:45 PM   #2
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
i doubt 16 psi on 93 is safe
The Following 3 Users Say Thank You to whitefrs For This Useful Post:
Cal3000 (02-05-2014), ecko04 (02-03-2014), ramiram1984 (02-04-2014)
Old 02-03-2014, 11:24 PM   #3
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
I would be expecting more power at 16 psi to but maybe I guess that would just be with E85 not 93 octane.
toekneehair is offline   Reply With Quote
Old 02-03-2014, 11:36 PM   #4
woode
Boosted Member
woode's Avatar
Probably going to be doing an E85 tune within the next month or two, so should have comparative results..
I know on this turbo I have seen ~285 @ 5.7psi on 93, ~330 @ 11psi on 93, and I got ~365 @ 16psi on 93 so I would say that seems about right.
It's just too bad that it's snowing and I can't really play with it!
Old 02-03-2014, 11:38 PM   #5
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Glad to see after all that you've gone through that you're finally getting some positive results.
Dustin is offline   Reply With Quote
The Following User Says Thank You to Dustin For This Useful Post:
woode (02-03-2014)
Old 02-03-2014, 11:44 PM   #6
woode
Boosted Member
woode's Avatar
Thanks!
It's definitely been a bumpy road dealing with this kit, and honestly in like a year n half I am probably going to switch out for the JDL kit (really like how that kit looks so far) and build the motor..
The guys at R/T Tuning are nothing short of awesome.. probably one of the best businesses I have dealt with. They installed my clutch and injectors and did the tune.
Old 02-03-2014, 11:46 PM   #7
R/T Tuning
R/T Tuning's Avatar
Drives: 2013 ScionRacing FRS w/2AZ-FE swap
Glad to see you made it home safe (unless you are stranded and typing all of this from your phone)
R/T Tuning is offline   Reply With Quote
The Following User Says Thank You to R/T Tuning For This Useful Post:
woode (02-04-2014)
Old 02-04-2014, 12:47 AM   #8
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
stock block.. balls of steel!
Build Thread
Instagram
Old 02-04-2014, 01:29 AM   #9
lexusb3
Drives: FRS
I thought I had balls 16psi on PUMP dam.. Enjoy the car it's a blast. Least you have cold weather instead of 90 degree hot weather!
lexusb3 is offline   Reply With Quote
The Following User Says Thank You to lexusb3 For This Useful Post:
woode (02-04-2014)
Old 02-04-2014, 05:58 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I think you definitely have the record for 93 octane now. I would love to see some dyno graphs and AFR/boost graphs.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
PrimeMotoring (02-08-2014), woode (02-04-2014)
Old 02-04-2014, 06:29 PM   #11
woode
Boosted Member
woode's Avatar
This isn't the printout from that exact run in the video but heres a shitty picture of another run..
The car was speed density tuned due to the MAF sensor location on this kit giving bad readings and causing it to unsafely lean out. Target boost was 15psi, hit 16.x psi max. 55°F / 45% Humidity. Car was on the dyno literally all day, but worth it in the end. This thing pulls hard!
(added graph to OP as well)
Old 02-04-2014, 07:51 PM   #12
phloozy
phloozy's Avatar
Drives: Scion FR-S
didnt realize you went to R/T. Were you the maniac that drove during the snow storm? I saw it on facebook
phloozy is offline   Reply With Quote
The Following User Says Thank You to phloozy For This Useful Post:
woode (02-04-2014)
Old 02-04-2014, 07:53 PM   #13
woode
Boosted Member
woode's Avatar
That would be me!
Old 02-04-2014, 08:11 PM   #14
jamesm
that's a lotta boost on a stock block on 93. i've run up to 14 and that felt like i was pushing it. i guess if you plan to build the motor anyway...
POST UP YOUR DYNO FIGS!![Nat. Asp]DYNO Figures (BEFORE and AFTER) stevo_12v Engine, Exhaust, Transmission 10 12-19-2013 03:02 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 04:16 AM
Cheap Dyno? Sponsored Dyno? swift996 Mid-Atlantic 3 02-09-2013 01:29 PM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 09:06 AM
