Troll Hunter
Drives: fr-s, tundra
Clutch popping when engaging pedal & Car off -- SOLVED
Today I moved the clutch engage position around based on the diy here
http://www.ft86club.com/forums/showthread.php?t=8040 I moved it around a couple of times, found what worked for me, and tried it out. I came back, moved it once more, and all the sudden got this clicking sound. I moved the clutch pedal back to it's original engagement point and was still getting it. I'm getting it at the most extreme (long engagement) and 70% short engagement. It pops when I push it in, and then pops again when I release From there, it doesn't pop. But it's undriveable that close. It happens both on and off. can be heard very well inside the cabin. Can also be heard above the dash as shown in the video. I took the cotter pin out from the clutch engagement pedal, and moved the now two parts individually. Isolated the noise to between the cotter pin and the master cylinder. Noise does not come from between pedal and cotter pin. Feels purely mechanical.. any thoughts? Not to worried about it, it's just annoying. video here - you can hear it pretty well. Doesn't happen every time. FIX! Okay, so here's the fix. This bolt here, with the red circle around it, is too tight. It may be hard to locate at first. Look for the rod that you adjusted that goes into the master clutch cylinder. Follow that back until you find the large rod that goes perpendicular to it, going all the way to the clutch pedal. The assembly to hold the actuator in, that bolt there is too tight. Factory spec is 13ft lbs but it should be more around 8 ft lbs. I bought a nylon washer from lowes, not sure if it helps much. This will remove the popping noise. I can still hear some kind of noise, but it is much more subtle and not as loud as the obnoxious pop. ![]() ![]() The key is to not over tighten that bolt. Loosen it up a bit, and do a guess and check. Play and see if that causes it to pop. I think the nylon washer allowed me to make it a little tighter while still preventing the noise from happening. If it is real loose, then the assembly will move around a bit. You want it right where it doesn't move around barely, and it doesn't make the noise
| The Following 4 Users Say Thank You to 86-tundra For This Useful Post: |
#2 |
hmmm.......just a couple of "obvious" comments.
* you did tighten up the locking nut ..? * are you sure the cotter pin isn't hitting the bracket .. ?
| The Following User Says Thank You to humfrz For This Useful Post: | 86-tundra (02-03-2014) |
#3 |
Troll Hunter
lol, thanks humfrz. yes the locking nut was tightened back up, and the cotter pin isn't hitting the bracket. it really sounds like it's coming from the master cylinder. I appreciate the response
#4 | |
.....and NO, I ain't sellen them braces ....
#5 |
Troll Hunter
I think maybe this could be it. I don't know why adjusting the clutch engagement location would change it at all. It's really hard to diagnose because there is only 1 of me, and not someone to hit the clutch will looking at different areas
#6 |
Master Installer
Drives: Scion FRS
Adjust back to stock and see if it still does it.
If yes, then you have bigger problems... If not, then you mess up adjusting it. |
#7 |
Troll Hunter
Yes thanks, I did adjust back to stock and same issue. why would you say this is a bigger problem?
#8 | |
.... I doubt she has heard that pick up line before.I hope you get it sorted out. Let us know what it was. |
| The Following User Says Thank You to humfrz For This Useful Post: | 86-tundra (02-04-2014) |
#9 |
Troll Hunter
Does anyone have a diagram of the mastery /slave cylinder brace including the clutch line?
I'm considering disassembling it and trying to isolate the noise
#10 |
Drives: 2013 Whiteout FRS
Your case sounds very similar to mine, although mine didn't appear until ~4000 miles mark. (I did the clutch adjustment at around 500 miles) And as you stated, it does feel mechanical and after hours of troubleshooting, I believe the sound is coming from the weld where the long metal shaft meets the triangular metal piece - right above the gas pedal (if you did the clutch adjustment, you should know what I mean).
*edit: maybe mine is coming from the pin to the cylinder as well. I never took the pin out to test both pieces, so my assumption could be wrong.* I originally posted a thread - http://www.ft86club.com/forums/showthread.php?t=51935, but the clicking sound still exists today! I actually went into the dealership to get it looked at a couple months ago and the outcome was a brand new clutch and clutch cover/plate. Their reason was: loose clutch plate. And guess what? The sound came back on my drive back home on that same day. I'm almost at 8k miles with no clutch failure; I've been just ignoring the annoying clicking sound... |
| The Following User Says Thank You to BaeK For This Useful Post: | 86-tundra (02-04-2014) |
#11 | |
Troll Hunter
It's something really hard to explain to someone, because most people would shrug it off as being part of the transmission noise. I'm glad you spoke up You should go take the cotter pin out and disconnect the cam from the rod that goes to the cylinder. if you move the pedal, do you still get the sound? I didn't, so I know it's got something to do from the rod down
#12 | |
What I'm also planning on doing is to revert back to the original clutch height and rotate the U-bracket instead of the small rod that goes into the master cylinder. I used my fingers to rotate the rod for adjustment, but now I am questioning myself if I should have rotated the U-bracket. |
#13 | |
Drives: JAWS
#14 |
Troll Hunter
I rotated the rod as well. There is definitely a common trend there.
| Clutch pedal springy sound | pdreams | Issues | Warranty | Recalls / TSB | 16 | 06-01-2015 02:33 PM |
| Clutch Pedal Adjustment? | EAGLE5 | Northern California | 41 | 05-20-2015 01:10 AM |
| Clutch Pedal Noise Help!! | ZackZ | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 09-06-2013 05:35 PM |
| BRZ gas pedal popping/squeaking noise | chenshuo | Issues | Warranty | Recalls / TSB | 8 | 05-10-2013 09:52 AM |
| Popping/Clicking Dead Pedal | BRaZinDave | BRZ First-Gen (2012+) — General Topics | 6 | 12-08-2012 04:14 AM |
