#3151 |
Drives: 86
#3152 |
Drives: 86
#3153 |
Drives: 2013 SWP BRZ
no problem man. Glad I saved you some trouble. I originally thought I was going to have to drill and extract, then my buddy was like "did you even check to see if its broken loose?" Then I felt like an idiot because I didn't, haha.
| The Following User Says Thank You to xxscaxx For This Useful Post: | TemeCal (02-03-2014) |
#3154 |
WUB WUB
Drives: 2013 Firestorm
they finally posted the vid of my dyno run. you can see the big black cloud. :/
https://www.facebook.com/photo.php?v...type=2&theater
| The Following User Says Thank You to wrxgoose For This Useful Post: | kbogarto (02-26-2014) |
#3155 |
That's what innovate wrote on my bag. I only torqued to 27 i think.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#3156 | |
Drives: 86
Thanks for the response. Hopefully we can figure out which is correct! I'd hate to under OR over torque these bolts. |
| The Following 2 Users Say Thank You to TemeCal For This Useful Post: | swift996 (02-03-2014) |
#3157 |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | Calum (02-04-2014) |
#3158 |
Grip>Slip
97 inch pounds = 8.08 ft/lbs, no? not 8.8, but pretty close.
#3159 |
Drives: 86
#3160 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
#3161 | |
Drives: Raven FR-S
Stock map sensor. Should I upgrade?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#3162 | |
Road Warrior
But it's is a relief to know I'm not the only one,. I kept having thrown at me that nobody else is having the issues I've reported. Keep that list of problems going, I believe there are definitely hardware issues that the manufacturer must sort out. |
#3163 |
Road Warrior
#3164 |
Drives: Raven FR-S
Innovate Supercharger Owners Topic
My tune is through delicious as well Edit: I also found that I've got a minor leak where the lines are crimped going into the coolant bottle.
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
