go_a_way1
Old 01-31-2014, 07:24 PM   #365
philstar
philstar's Avatar
Drives: Argento FR-S
Originally Posted by txninja View Post
so gonna have drift event at my local place lone star drift battle.. i was just wondering i just wanted to practice and have fun currently running all stock as well.. would it be safe to just drift it all stock? gonna be running a few sets of tires... so far heard lowering car and drifting breaks axels pretty quick...
My car is pretty low and I've been lucky enough to not break any axles yet... but I feel like its a ticking time bomb that I need to address this season.
and YES it will be safe and extremely fun to drift it stock. I left mine stock for over a year before I began modifying it.
[ame="http://www.youtube.com/watch?v=FSFe8FhmaZc"]Scion FR-S Drifting - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=wF2aJ2-ze3w"]Scion FR-S drifting at Automass - YouTube[/ame]
philstar is offline   Reply With Quote
Old 01-31-2014, 07:25 PM   #366
philstar
philstar's Avatar
Originally Posted by THA STI GUY View Post
Yep thats him. looks like we will both be coming up this year
There will be so many of us with FRS/BRZ there! I foresee tandem trains?! I missed out on JAM last season due to work, I refuse to miss out on Final Bout this year
The Following User Says Thank You to philstar For This Useful Post:
canu_50 (02-05-2014)
Old 02-02-2014, 10:37 PM   #367
chris x sway
chris x sway's Avatar
Drives: 2014 FR-S in Mayonnaise
So I know there's a broken axle thread going on. Anybody have this problem and found a solution? I enter drift events every month since december on stock suspension but I'm getting some BC Racing coils soon. Thanks for the input.
chris x sway is offline   Reply With Quote
Old 02-02-2014, 10:53 PM   #368
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
I've been through it all.
It's a common issue when setup super low and driven hard. Too much low fucks with the axle geometry and puts a lot of added stress on the axel bearing cases. That's what I broke. I was also running 9.5" Kiwamis on the back, so wide wheels probably don't help either.
I installed the DSS 600hp axles. You can read about all the dramas I had from post #15 in my build thread.
http://www.ft86club.com/forums/showthread.php?t=29724
JordanWho is offline   Reply With Quote
The Following User Says Thank You to JordanWho For This Useful Post:
chris x sway (02-02-2014)
Old 02-02-2014, 10:54 PM   #369
diss7
Drives: AE86, 2x GT86, TE27
If you're worried about your axles, dial grip out of the back.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
Old 02-03-2014, 05:28 AM   #370
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Between DSS axles, PBM diff risers AND subframe risers, I feel like I'll never have an axle issue again.
Once it gets on the car, I'll probably end up dropping the car down close to another inch.
The Following User Says Thank You to TylerLieberman For This Useful Post:
chris x sway (02-03-2014)
Old 02-03-2014, 09:51 AM   #371
JordanWho
JordanWho's Avatar
The Drifting Thread
Does anyone know how high the diff and subframe is actually raised with both risers installed??? I've emailed the same question to PBM without a response at this stage.
I want to know this info before I consider moving forward. It's not exactly an easy install and realistically, to somewhat straighten out the axles when LOW the diff really needs to come up by around 10-20mm from what it is from factory. Anything less than 10mm and I'm not sure if it's worth all the trouble.
If it is raised enough, then I will install them for sure. Even with DSS 600HP axles installed, I still had issues with them leaking grease from the CV boots due to the bad angle they were running at. I've even had the boots replaced and reclamped from splitting and they're less than six months old. TBH this whole axle thing has been a fucking nightmare. The only thing that fixed the issue was raising the car and nobody go time for that.
Old 02-03-2014, 10:06 AM   #372
chris x sway
Exactly. Thanks for shedding some light on the situation. I hope someone can figure this out so I can install whatever it is all at once.
Are you maxed out on the BR Coils too? I like the ride posture.
The Following User Says Thank You to chris x sway For This Useful Post:
JordanWho (02-03-2014)
Old 02-03-2014, 10:21 AM   #373
JordanWho
JordanWho's Avatar
Not even close. I have BC BR's but they are the extreme drop spec so they go REALLY low. More than what I ever needed.
chris x sway (02-04-2014)
Old 02-03-2014, 12:29 PM   #374
TylerLieberman
Drives: '24 GR86
Diff and subframe risers raise the whole assembly by 20mm.
Old 02-03-2014, 12:34 PM   #375
JordanWho
JordanWho's Avatar
Well there you go.
Sold
Old 02-03-2014, 12:59 PM   #376
TylerLieberman
Drives: '24 GR86
17s are just going to naturally let the car sit lower too. Slamming on 17s will give you a lower height than slamming on 18s. That's probably why you're having so many issues.
I'm on 17s now and just BARELY tuck the ver top of the rear tire. I'm going to 18s in the rear and will get it to where the rear is about an inch above the rim. Coupled with the LCAs, risers, and axles, I shouldn't have any issues. I just had really grippy setups and beat the shit out of the car when I drift it. Probably what cause it to fail so fast.
I'll just bump up tire pressure to like 70psi with almost no rear camber haha. Sssssssmoooooooke
Old 02-03-2014, 01:31 PM   #377
JordanWho
JordanWho's Avatar
To get that 20mm, do you need both sub frame and diff riser kits or will the diff riser kit give you the 20mm by itself?
Old 02-03-2014, 01:34 PM   #378
TylerLieberman
Drives: '24 GR86
Idk for sure. The diff risers do raise the diff up within the subframe, but in order to install it, you gotta pull the subframe anyways. I'd just do it all at once since the subframe is already off. $200 USD for both sets.
More than worth it. Now PBM just needs to release their knuckle kit and a rear drop spindle setup
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 01:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 09:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 05:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 05:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 03:02 AM
