#3025 |
Drives: 2013 BRZ limited SWP
I had a Gates RB shred on a 70mm pulley. I am back on the stock 75mm pulley with the standard Gates belt and haven't had any issues. I do have a spare belt in the trunk just in case though.
On another note does anyone know of any vendors with the intercooler upgrade kit in stock. I ordered mine last week from Innovate and I just found out they are about 6 weeks out. Initially they said probably around 2 weeks and I was fine with that but if someone has one in stock I will cancel my order and pick one up now. Sent from my DROID RAZR using Tapatalk |
#3026 |
Drives: 2013 Asphalt FRS
If I had a wideband all my issues would have be solved months ago.
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
#3027 | |
Drives: Subaru BRZ
#3028 | |
WUB WUB
Drives: 2013 Firestorm
Sent from my VS840 4G using Tapatalk
#3029 |
Just the tip
I have the Perrin 2.5 inch intake. I got it way before they released the 3" so it's hard to justify depending money on the bigger one unless someone will buy my 2.5 for a decent price.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#3030 |
@wrxgoose i'd check the idler pulley and all pulleys. Make sure they're all moving smooth and not occasionally missing a bit causing the belt to flex left/right. I haven't had an issue with mine and no sign of any damage.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#3031 | |
Drives: 2013 SWP BRZ
Cooler and more consistent temps = being able to run more timing = more power. There is a reason the intercooler kit makes more power than the non-ic kit. |
#3032 | |
#3033 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Ive changed belts, pulleys 75 to 72 to 70mm no issues. the Charger pulleys sidewalls grooves should not allow a belt to jump.
the belt runs from alternator round to the SC, so possibly check your alternator pulley and the pulley below it, to ensure running straight. something else to check, did you put the washer before the idle pulley? |
#3034 |
It was a FA20club 70mm pulley. I kinda suspect that the pulley may have caused the belt to shred because the pulley was all hacked up when I received it. I should have sent it back but it took almost a month for me to receive it and I didn't want to wait for another one. I have a 70mm from raceseng (which looks flawless) that I picked up on Black Friday but I haven't installed it yet.
| The Following 2 Users Say Thank You to Area86 For This Useful Post: | CK_Bladesmith (02-19-2014), DriftEm (01-31-2014) |
#3035 | |
Just the tip
| The Following User Says Thank You to stockysnail For This Useful Post: | Area86 (01-31-2014) |
#3036 |
Drives: UK GT86
You go and tell me what I said was wrong..... and then rewrite what I said just in a different way. I reckon on a single pull, the charge temps between the 2 would not be that different to create a noticeable change in power if timing and fuelling were identical. The main reason there is a power difference is that tuners have to reduce timing (and possibly add fuel) due to the fact intake temps will continue to rise on the base kit. Thats the reliability aspect.
.: Stealth 86 :.
#3037 |
@stockysnail
Advice. If you change the intake before the MAF or at it DO NOT WOT. Your AFR will be off. Also I would not recommend installing the IC and driving around w.o a re-tune. If your already spending the money might as well wait and spend the $300 more for it. I don't want to tell you what my AFR was at when I switched up parts w.o hitting boost on my drive for my retune. The intercooler will restrict air flow. Its a give/take. This will lean out your AFR and produce more boost (i think) Now that your boosted you have to be more care full. Bobby tunes our car's really rich. You don't want to mod it with anything that will make it run more rich. When I went from the 3in Perrin intake to stock airbox + changed the header/FP it actually made my car run really really really rich. Also the ECU was pulling/giving timing which made for an unenjoyable drive... I can't wait for someone to release a 3in intake that actually has a MAF air straighteners. (I put it past jason at nameless) *update for my car* Next upgrades (all at once install for next winter project decided) If my SB is in good running condition I will be selling it. 1. Purchasing Crawford SB w/10:1 compression Or if Cosworth releases their block I might change my mind. 2. Nameless Full 3in Intake 3. Nameless EL Header 4. Nameless 3in OP/DP Combo (already have a gnarly 3in to dual 2in nameless proto catback to mate to these awesome new additions) 5. 69mm Pulley 6. AEM Meth injection 7. Innovate IC Upgrade kit 8. Re-tune @ PRE racing Hoping to make more then 280WHP and have a reliable engine for track use. 2015 shall be fun! Until then i'll live with the 240 WHP stock engine. at that point my car will be 100% complete. Undecided if I want to upgrade pump/injectors. If I do i'll be getting a flexfuel kit and running E85 and switch to ECUtek with a Driftoffice tune. Unless i can talk Bobby into continuing his tune on my car. If I do this then it will be balls to wall shooting for 320+WHP *it sucks my car had so many issues. Because I was so deep in labor fixing the damn thing buying/selling/swapping parts that I could of already had Injectors/Pump/Intercooler atm.........
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV Last edited by NickFRS; 01-31-2014 at 09:09 AM. |
#3038 | |
![]() either way, I wouldn't run on the non-ic tune for long. @NickFRS - why did you end up swapping back to the stock intake box? Based on your post i'm guessing it was screwing with the MAF too much? |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
