Old 01-29-2014, 11:15 PM   #1
frslee
Just drive it
Drives: 13' FR-S
Ahh.. pulled over for having HID..
Hello guys,
I'm one unlucky SOB. Police pulled me over for having an HID lights.. he stated that the lights were glaring and dazzling. It's good that I got a warning for this one. I'll have to go through repair order and get it signed by authorized inspection center.
I think the glare he's describing is coming from the the top portion in the picture. I just picked one from google image, so forgive me if I'm using someone's picture..
I remember reading a thread showing how to minimize the extra glare on top by pushing the top part inside the projector? Am I correct? At this point I don't want to spend hundreds of dollars on new housing.. I do admit that my lights are freaking bright (55w 5000k), but I've never had a problem with police with this since my first hid on halogen housing...
I'll have to swap it with halogens and get it inspected, then figure something out... I thought about using Sylvania silverstar line bulbs, but I'm not sure how good the output would be.
Any suggestions or knowhow to minimize the glare would be appreciated.
frslee is offline   Reply With Quote
Old 01-29-2014, 11:44 PM   #2
mush
mush's Avatar
bad luck indeed
theres a lot of trucks here with BLUE hid kits that glares like the sun
The Following User Says Thank You to mush For This Useful Post:
B L U E S L A T E (01-30-2014)
Old 01-30-2014, 12:07 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
get a 35w kit-- that would be a good start to reducing the glare.
Gixxersixxerman (02-01-2014)
Old 01-30-2014, 12:09 AM   #4
sirsol66
Drives: 2013 FRS- Hot Lava
Get a 35W kit, bend your squirrel finders down, and aim your lights down a bit.
Or get a proper retrofit. One's cheap, ones effective.
sirsol66 is offline   Reply With Quote
The Following User Says Thank You to sirsol66 For This Useful Post:
Old 01-30-2014, 12:12 AM   #5
frslee
Just drive it
Drives: 13' FR-S
Ah, lowering the aim would work. There's a spot that you can turn using screw driver right?
Old 01-30-2014, 12:19 AM   #6
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Glad he pulled you over, it is dangerous and annoying.
So if you knew your lights were bright did you just not care about others or are you special?
Scion drivers get called ricers for these kinds of mods; do it right or dont.
chulooz is offline   Reply With Quote
The Following 21 Users Say Thank You to chulooz For This Useful Post:
86-tundra (01-31-2014), Ammonia (02-01-2014), blue cat (02-02-2014), chas3wba0 (03-31-2014), Chee-Hu (01-31-2014), deliroast (04-01-2014), frslee (01-30-2014), Gixxersixxerman (02-01-2014), gutbuster (04-22-2014), headlikeahole (03-31-2014), JTM (02-12-2014), juliog (01-30-2014), Lonewolf (01-30-2014), nalc (01-30-2014), onabulletride (02-02-2014), Poodles (01-31-2014), Pyrefyre (04-02-2014), rxpx2012 (01-30-2014), Turbo95eg6 (01-30-2014), woode (02-01-2014), wrb (01-30-2014)
Old 01-30-2014, 12:36 AM   #7
frslee
Just drive it
Drives: 13' FR-S
Thank you for the advice. I wouldn't consider myself as a dangerous or annoying person. Okay, it's my fault that having an overpowered HID in "SCION" may offend other people, but if you think you're glad that I was pulled over, then I can take that. Since everything has happened and I need to find a solution, I'm looking for an answer to remove the top glare from the light output. If I were to remove the glare, then the light output would be very close to as any other factory OEM HID bulbs. Now I just found few information on how to remove the glare by pushing down a small metal plate called "Squirrel Finder". Whenever I get a chance, I'll try that and post a picture comparing that to other factory HID output so you can compare and possibly accept my effort not to glare other drivers. So please do not consider me as a scion ricer... again, I appreciate your honest response.
Old 01-30-2014, 12:37 AM   #8
chulooz
Registered you sir
chulooz's Avatar
Ill try not too, getting help is the first step. SEARCHING is the second. Good luck here
Old 01-30-2014, 12:37 AM   #9
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Sticky requested, there's a white FRS i see on the highway all the time and his HID's are fucking horrible.
Good luck.
The Following User Says Thank You to dem00n For This Useful Post:
SkAsphalt (01-30-2014)
Old 01-30-2014, 12:49 AM   #10
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
Bad luck.
I've seen a lot worse and cops don't bat an eye where I live. Theres a Neon SRT4 with purple freakin headlights in my town.
sprintertrueno86 is offline   Reply With Quote
Old 01-30-2014, 01:06 AM   #11
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
If you don't wanna have to the resort to the stock bulbs, retrofit it to an HID projector so that you can have your HIDs still.
husker741 is offline   Reply With Quote
Old 01-30-2014, 01:25 AM   #12
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
No, don't do any of the first sentence. Either do a full retrofit, buy a proper set of headlights, or put your damn incandescents back in.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
The Following 5 Users Say Thank You to Acree For This Useful Post:
Deathalo (02-01-2014), Gixxersixxerman (02-01-2014), JTM (02-12-2014), SirBrass (01-30-2014), SkAsphalt (01-30-2014)
Old 01-30-2014, 01:38 AM   #13
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Bad luck..i have 8000K HID installed for over a year, no problem..cops seem don't care about it.
Old 01-30-2014, 01:50 AM   #14
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
I'd do 35W, that definitely looks like it would glare the hell outta me lol.
Pulled over for the first time. Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 22 01-25-2013 03:03 PM
Getting pulled over Jtymay92 Scion FR-S / Toyota 86 GT86 General Forum 66 01-10-2013 04:57 PM
Have you been pulled over yet? shire1976 AUSTRALIA 47 09-23-2012 07:44 AM
First BRZ to get pulled over in NJ!! engee NY / NJ / CT / PA 33 08-28-2012 01:05 PM
Just got pulled over Partial Stall BRZ First-Gen (2012+) — General Topics 6 06-22-2012 11:20 AM
