Old 01-28-2014, 06:53 PM   #15
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
You could look into some Feal 441 coilovers that come with swift springs and camber plates $1350.
http://www.rallyracingsuspension.com/page16.php
Then add a Nameless Performance catted overpipe/frontpipe to the mix $419.
http://shop.namelessperformance.com/...e-factory-fit/
Add the two above parts to what you have with a tune and a proper alignment.
Alakazam!
Your car can be competitive nationally if you can drive
2superblus is offline   Reply With Quote
The Following 2 Users Say Thank You to 2superblus For This Useful Post:
GeorgeJFrick (01-29-2014), Kodi (01-29-2014)
Old 01-29-2014, 12:19 AM   #16
Kodi
Kodi's Avatar
Drives: Asphalt FR-S
Originally Posted by blkwrxwag View Post
Come out to Cal. Speedway for the next practice on Feb 8th. I have a full STX build, and we can chat.
Let me know if you need help signing up.
Thanks Max. I was registered for the last event there a few weeks ago, but didn't make it. I am signed up for the PCA autocross at ElToro on the 9th. I'll see if I can make it out to Fontana on the 8th.
Kodi is offline   Reply With Quote
Old 01-29-2014, 12:34 AM   #17
Kodi
Kodi's Avatar
Thank you all for the advice. I looked into the Feal 441s, but they were a bit more than I wanted to spend. I realize I will probably wind up buying "real coilovers" but I wanted to get a whole lot of seat time first, so I could actually drive better rather than having to worry about tuning the suspension. I planned on entering in CSR but I already had the tires, wheels, crash bolts and the tune, which would have pushed me into STX.
Old 01-29-2014, 01:15 AM   #18
BeRZ
BeRZ's Avatar
Drives: 2013 WRB BRZ
Hey Max, you'll be out there? I'm practically stock, and this will be my first time out there.
BeRZ is offline   Reply With Quote
Old 01-29-2014, 12:14 PM   #19
blkwrxwag
Drives: DS FRS
Yes, I will be there in the WRB BRZ with lots of stickers.
Come say hello and I'll help you out.
-Max H.
blkwrxwag is offline   Reply With Quote
The Following 3 Users Say Thank You to blkwrxwag For This Useful Post:
itzmik3 (02-03-2014), Kodi (02-03-2014), Scooby South (01-30-2014)
Old 02-03-2014, 09:32 PM   #20
Kodi
Kodi's Avatar
Thanks again for all of the tips.
I am installing Ground Control coilover sleeves and springs on the stock shocks and a Whiteline 20mm adjustable front swaybar. I have an appointment with Darrin at West End Alignment to get aligned and corner balanced.
I have two questions though.
What are the best ride height and alignment settings for a car that is a sometimes DD and autocross car?
Also, is there any advantage to using OEM crash bolts if I have Whiteline Com-C strut mounts?
Old 02-03-2014, 09:53 PM   #21
itzmik3
DBC Racing
itzmik3's Avatar
i will see you this weekend also
#194 SM
itzmik3 is offline   Reply With Quote
Old 02-03-2014, 09:56 PM   #22
itzmik3
DBC Racing
itzmik3's Avatar
if you do both thats gonna be a tough weekend on the tires.
i wish i was doing the PCA event, but prior obligations with SCCA
can't wait to be at el toro next month though. grip grip grip!
#194 SM
Old 02-04-2014, 10:50 AM   #23
piknockout
Drives: 2014 BRZ
There's benefit to using the crash bolts because you can get more camber (assuming that the tires aren't hitting the springs) and at the very least you can adjust it within a range to get it where you want it. Definitely use them if you have them.
I'm running the KW's, so they're already slotted to do more camber from the knuckle.
piknockout is offline   Reply With Quote
The Following 2 Users Say Thank You to piknockout For This Useful Post:
Kodi (02-04-2014), Scooby South (02-04-2014)
Borla UEL basic thoughts/ review loogs Engine, Exhaust, Transmission 39 09-28-2013 02:18 PM
What basic tool set to get? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 5 09-05-2013 12:46 PM
Visual Basic and SQL Trashed675 Off-Topic Lounge [WARNING: NO POLITICS] 10 06-10-2013 01:18 PM
GC basic coilovers / Cusco Strut bar Evilbrz151 Brakes, Suspension, Chassis 3 03-29-2013 10:35 PM
