Old 01-23-2014, 04:01 PM   #15
mkivsoopra
Originally Posted by mkivsoopra View Post
It's taking forever.... He's supposedly gonna ship it this week. Grrr
woohoo.. just got the DHL tracking number. I hope it's legit.
mkivsoopra is offline   Reply With Quote
The Following User Says Thank You to mkivsoopra For This Useful Post:
nzer (01-23-2014)
Old 01-27-2014, 06:29 PM   #16
mkivsoopra
Ok, I can confirm that this unit works with the USB ELM327 out of the box. However, I did notice some connectivity issues when closing the app and re-opening it, and what seemed like missed data while it's running. I'll have to play with it more in the next few days. I had very limited time with it today. Perhaps I may need to try a different USB ELM327 unit.
Other than that, the interface is very responsive and much better than the clunky OEM Subaru one.
The Following 4 Users Say Thank You to mkivsoopra For This Useful Post:
amram (04-06-2014), gdrider77 (01-27-2014), nzer (01-27-2014), Trap63 (01-29-2014)
Old 01-27-2014, 08:01 PM   #17
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
how the hell did you buy that. I have tried about 5-6 times over the past few months to order one, and can never get past the checkout phase. I get google checkout and it never goes anywhere....damn that site sucks. Anywhere else to purchase this?
gdrider77 is offline   Reply With Quote
Old 01-27-2014, 08:02 PM   #18
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Very nice! Regarding the missing data while it is running... It wouldn't surprise me a bit if the OBD connection itself is the culprit. I have to perform all kinds of cable gymnastics with my Ecutek cable to get an uninterrupted data stream (have to wrap the cable around the steering column once to put lateral pressure on the connection). It's amazing how some industries have adopted more robust connection technologies yet we are still stuck with this plastic garbage on a 25k automobile. Congrats on the new radio! I look forward to seeing your feedback as you get some time with it.
pixel67 is offline   Reply With Quote
The Following User Says Thank You to pixel67 For This Useful Post:
chanomatik (04-23-2014)
Old 01-27-2014, 08:17 PM   #19
mkivsoopra
I actually had trouble with the tradesolution site as well: http://www.tradesolution.hk/e/ptxweb...duct/1274.html
I remember going through the payment process and the page appeared to be half-broken. The paypal portion went through, though, so I contacted the vendor after that. I don't know if the order officially went through, but I had the paypal receipt and worked with the vendor with that. The vendor stalled for about 3 weeks, but finally shipped it 5 days ago. He blamed the delay on supply issues since the unit was a new model. Hopefully they have that sorted out and can have them shipped out promptly now.
I never had issues with my EcuTek cable and this same USB ELM327 worked fine with my generic Android 4.1 tablet. Hopefully, it's nothing major and can be sorted out!
Old 01-27-2014, 08:19 PM   #20
gdrider77
gdrider77's Avatar
I actually just completed the order via paypal, so hopefully it wont take forever to actually arrive. Now i just need to order a elm327 to usb adapter
The Following User Says Thank You to gdrider77 For This Useful Post:
mkivsoopra (01-27-2014)
Old 01-27-2014, 09:52 PM   #21
coyote
coyote's Avatar
Drives: Slowly
When you get the chance, it would also be useful to test:
Google Play Services - Can you update to the latest version?
This has many implications, but a couple I have found are access to advanced maps and nav functionality and possibly also being able to get a more useful way to manage phone contacts (which is shit on this device).
SD card support - Can you use the SD card to store Google Play Music data?
This is standard on KitKat and also some older roms and makes Play Music usable by being able to store all your music on SD card by making a setting, rather than having to stream it.
coyote is offline   Reply With Quote
Old 01-28-2014, 04:37 AM   #22
mkivsoopra
Ok, had a few minutes to button everything up tonight. I have the Rydeen Duo Mini reverse camera and spliced the camera's power wire into the car's orange-white wire, and then tying that to the reverse signal that goes into the deck. One difference that I noticed was that the deck only switches to the reverse camera view when the ignition is in the ON position, not ACC. Not a big deal, but I thought I'd mention that.
Originally Posted by nzer View Post
RaceChrono requires a couple of google map files to run and may need root to stall but you never know.
Play Store lists RaceChrono as incompatible for this device, but I was able to install it using the included APK Installer app. I downloaded Google Maps directly from the Play Store. RaceChrono loads fine, but I haven't tried to do anything with it, since I haven't driven the car yet.
Google Play Services - How do I check? Please bear with me... I'm a software guy, but I've only played with iOS up until now.
Google Play Music offline SD card support - No. The Storage Location option is not there (unless there's a different way?)
The Following 2 Users Say Thank You to mkivsoopra For This Useful Post:
coyote (03-11-2014), nzer (01-28-2014)
Old 01-28-2014, 04:51 AM   #23
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Under Settings>Apps>Google Play Services
Should have the version number.
The Following User Says Thank You to Andrew025 For This Useful Post:
mkivsoopra (01-28-2014)
Old 01-29-2014, 04:23 AM   #24
mkivsoopra
Ok, small update...
-Google Play services is currently on version 3.2.66 (845702-32). Doesn't update the normal way, but someone on XDA was able to sideload the latest version: http://forum.xda-developers.com/show...6#post49780846 (i haven't tried this)
-The included GPS app works, but leaves much to be desired.
-I was able to run Torque with the radio playing music and GPS giving background voice navigation directions. Working as one would expect.
-I'm able to switch between apps and open/close Torque without the connectivity issues that I saw the other day, but I'm still getting a choppy data stream.. will try a different USB ELM327
-The deck is OEM-fit, but it's sunk in about a 1/4". I think some spacers behind the bolts would push it back out nicely
nzer (01-29-2014)
Old 01-29-2014, 04:31 AM   #25
gdrider77
gdrider77's Avatar
I'm real interested in what elm module you get working. Please keep us updated. Will the elm Bluetooth work on this? Or only the USB version.
Old 01-29-2014, 04:48 AM   #26
mkivsoopra
I just placed an order for the ScanTool one.. it's on sale! Hopefully, this will do the trick.
[ame="http://www.amazon.com/ScanTool-425801-Interface-Diagnostic-Software/dp/B005ZWM0R4"]ScanTool 425801 OBDLink SX OBD-II Scan Tool USB Interface with OBDwiz Diagnostic Software : Amazon.com : Automotive[/ame]
Based on what I've read, Bluetooth ELM327 will not work yet. The firmware is encrypted, so it's not straight forward for the community to enable that functionality. I actually prefer the USB connection since the ELM327 is powered (or switched) by the USB instead of continually drawing power from the OBD port.
keen as (02-14-2014)
Old 01-29-2014, 01:56 PM   #27
gdrider77
gdrider77's Avatar
Nice, yeah that one looks good. I would prefer the usb version as swell, it it works. Suppose to be faster and no power draw. I left my bluetooth plugged in before and it killed my battery after a few days./
Old 01-31-2014, 04:17 AM   #28
mkivsoopra
Ok, so I did a bunch of testing with the ScanTool OBDLink SX.... it's better, but not perfect. It's noticeably faster than the generic one I had, but it still pauses once in a while. I've actually never used a bluetooth ELM327, so I'm not sure how it compares. Is this normal?
I think this setup is ok for FYI type of information, but not critical info that changes rapidly. I'll be using it mainly for things like coolant temp, oil temp, etc, so it's fine for me. I'll be using an AEM failsafe for boost and AFR.
I finally got to play with some of the multimedia capabilities of this unit. Here's a quick summary:
Sirius XM: Not supported
HD radio: Not supported
Analog radio: Average. I've always had poor reception with my Subaru shark fin antenna, so that might be the reason.
MP3 music from SD card/USB drive: Ok
Streaming from Play/Pandora/etc: Ok, depending on your connection and stream
Bluetooth A2DP: POOR audio quality when connected to my iPhone 5s. Have not tried any other phones yet. Same phone doing A2DP to my stock BRZ head unit was great. Update: Tested on my iPhone 5, same thing.
iPod connection: Not tested yet
DVD video:: Ok
Video from SD card/USB drive: Not tested yet
Video AUX input: Probably won't test...
I'll update this post when I get around to the other things.
And here's how it looks like during the day and night with Torque Pro running:
amram (04-06-2014), keen as (02-14-2014)
Android Head Unit - LED Colour Change - T7019A (and TUN21A) Tech DIY (Do-It-Yourself) Guides 57 10-11-2013 12:10 AM
T7019A Android 2.3 Unpacking Trap63 Electronics | Audio | NAV | Infotainment 18 09-19-2013 01:42 PM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 06:05 PM
DIY - External microphone for Android HU - (T7019A) Trap63 DIY (Do-It-Yourself) Guides 6 08-20-2013 09:00 AM
Android Head Unit - LED Colour Change - T7019A (and TUN21A) Tech Electronics | Audio | NAV | Infotainment 2 07-18-2013 07:17 PM
