Old 01-27-2014, 05:18 PM   #43
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by mav1178 View Post
It may help if you posted the distance between the mount holes on your seats, this way it can be cross-referenced to other seat rails.
I know Bride seats offers a bracket that allows their rails to be used with Recaro buckets.
I'm running a Zeta III + Bride rail myself.
-alex
You are right.. but I am using side rail brackets..which are a touch wider than most.. I am pretty sure the bottom mounts are standard size... I will check it for you but it might be a bit..-8 outside.. and my garage isn't heated..
Bill
Scooby South is offline   Reply With Quote
Old 01-27-2014, 06:12 PM   #44
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
You may want to check the types of rails that Bride offers:
http://bride-jp.net/products/super-seat-rail/body/
Depending on the size of your seat you may end up going with an "unconventional" seat rail.
The Bride rail for our cars more or less look like this:
(pic is of a HP10 G20/Primera LH rail)
-alex
Scooby South (01-31-2014)
Old 01-31-2014, 04:14 AM   #45
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
Originally Posted by spitfire481 View Post
The drivers seat just needs a resistor stuck into the airbag connector that comes out from under the carpet underneath of the seat. Nothing else. The passenger seat needs the same airbag plug resistored, but also needs the weight sensor transferred over into the new seat, underneath of the fabric/lower foam. I think there MIGHT be a way to turn off the passenger weight sensor through Toyota techstream software. More than likely it will still show a fault since it is not plugged in and will still show an open circuit
sry! another questions!! how did you get the weight sensor out? what does it look like?
im sry bro!! i swear this could possibly be the last question
umpadupa is offline   Reply With Quote
Old 01-31-2014, 10:28 AM   #46
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
It's a plastic pad pretty much. Covers the flat area on the lower seat cushion. You have to remove the lower seat fabric then separate it from the foam
The Following 4 Users Say Thank You to spitfire481 For This Useful Post:
Lawnik (08-06-2014), Scooby South (01-31-2014), SexyPirates (06-21-2021), umpadupa (01-31-2014)
Old 01-31-2014, 10:33 AM   #47
jadewbj
jadewbj's Avatar
http://www.jadecrew.com/custom-recar...seats-in-fr-s/
Link shows how I did it.
This is the sensor. To get it out you need to remove a few hog clips on the stock seat cover and you can pull it out.
The covers on the recaros were harder to get off so I did not install it in the new seat. Instead I rolled it up and tucked it under the carpet of the pass seat. It turns the airbag on all the time and the seatbelt chime goes off. I had the dealer turn the sound off.
jadewbj is offline   Reply With Quote
The Following 2 Users Say Thank You to jadewbj For This Useful Post:
Scooby South (01-31-2014), umpadupa (01-31-2014)
Old 01-31-2014, 10:40 AM   #48
Scooby South
Conedancer
Thanks Alex.. thats helps alot.
This is the seat I have. I will check the mounting holes for the sidebracket.. should be standard.. problem I am having is the width that the brackets mounts to the sides.. and has smooth slider operation..
Bill
Old 01-31-2014, 11:52 AM   #49
mav1178
mav1178's Avatar
Bill
What seat is that? If it helps I'll take some pics and measurements of my rails this weekend.
-alex
Old 01-31-2014, 12:50 PM   #50
Scooby South
Conedancer
Corbeau FX1W
Maybe I am not understanding which measurement ??? Sorry for the confusion.
Bill
Old 01-31-2014, 04:50 PM   #51
mav1178
mav1178's Avatar
Side mount seats will need to have rails that look like this:
(From Zilvia.net)
Two things come to mind:
1) width of seat, whether this will fit into the seat rail width (the brackets can only move so much)
2) distance between the two mounting holes on the side of the seat. Some seat brackets have slotted holes that can allow a variety of bucket seats to be used, some seat brackets don't have this option.
There is a third option: using a Bride/Nagisa/Buddy Club/etc rail, and fabricating your own L-bracket.
Either way I'll get the measurements and post them for reference this weekend.
-alex
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
8R6 (07-04-2015), Scooby South (01-31-2014), SuperTom (06-19-2018)
Old 01-31-2014, 04:51 PM   #52
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Id like opinions on no name seats ?
Nothing like a bride rip off with bride fabric. Just a black bucket seat
Sent from my IBrick
Old 01-31-2014, 05:47 PM   #53
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
So to access the passenger weight sensor i'll have to rip apart the passenger's seat?
JackSmiley is offline   Reply With Quote
Old 01-31-2014, 07:00 PM   #54
Scooby South
Conedancer
(From Zilvia.net)
-alex
The ones I am using is on the left. But even with max adjustment.. the sliders don't fit correctly to floor of the car...the sliders are Pinched limiting movement.. so the side rails themselves will need more adjust to go wider to accommodate the seat itself. more "Z" to be able to actually mount the seat to the car..then there's the narrow tunnel on the 86 limiting the size of seat you can actually put in, for full range of adjustment...
Hope that made sense..
Bill
Old 01-31-2014, 10:33 PM   #55
umpadupa
umpadupa's Avatar
i think so! but we need a pro to chime in. So, without the sensor, whats gonna happen? malfunction? no pass airbag?
PS: @jadewbj & @spitfire481
u guys are genius
EDIT: http://www.club-tc.com/threads/remov...lt-warning.67/
maybe this will work for scions!
Old 01-31-2014, 11:17 PM   #56
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by Ryaquinn View Post
Attachment 60068
Buddy Club P1 with buddy club side rails
In comparison to stock how is seating height? I realize stock is adjustable but trying to get an idea. What height are you and what's your impressions this far on this seat comfort wise etc....
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 03:47 PM
SOLD: Used (But Like New Cond.) Stock FR-S Seats w/ rails (Both Seats) Vicious LED Interior Parts (Incl. Lighting) 16 07-21-2013 06:45 PM
WTT: My FRS seats for your BRZ Premium Seats Hanakuso Interior Parts (Incl. Lighting) 17 03-04-2013 01:37 PM
Aftermarket Seats sets off SRS light? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 1 08-25-2012 05:09 PM
Please post FR-S w/ aftermarket leather seat pics ngabdala Scion FR-S / Toyota 86 GT86 General Forum 6 05-31-2012 09:51 AM
