Old 01-26-2014, 01:56 PM   #1
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Spring Rates Discussion: Stiffer Front or Stiffer Rear or Even/Square all around???
I am aware spring-rates only play part of a role in coilover & spring/shock combinations and designs; and that shock valving plays a huge role as well. But, I think we would all love to hear your opinions, experience and insight from both professionals & track/auto-x-hobbyists in regards to spring-rates. Specifically, which end should be stiffer, front or rear, or square/even both front and back.
I notice F&R ratio stiffness varies greatly with all the different manufacturers of coilovers and lowering springs. Anywhere from even square rates all around, to 2kg stiffer in the front, to 2kg stiffer in the rear.
Insight would be great as to why ...and also recommendations on what would be the ideal set-up for certain track/driving situations; and also the most ideal setup for universal/general use that can be used globally and for everything (of course with tradeoffs I'm sure).
ie: maybe stiffer in front to neutralize the car's natural oversteer, or stiffer in the rear for less rear sway or more oversteer, or square/even all round because maybe the car is already well balanced and maybe to have a broader free range and ability to tune the adj valving to the users liking, etc., etc.?
This will be good info for those wanting to buy, or experiment with, custom spring rates for their coilovers (whom offer custom spring rates; ie: Tein, Ohlins, etc.) and also Ground Control coilover sleeve springs (custom spring rates) or their CO kits.
A better coilover (Tein SRC or MFlex, Ohlins, KW, etc.) would defo be nicer; but those are out of the price range for a lot of people. Which in turn, makes it very attractive to go for the GC springs/sleeves with B8's, or perhaps even the GC/Koni kit; as these are the most affordable spring/shock combo that offers real stiff/custom rates along with high quality, heavy duty valving and sound like the most performance/bang for the buck.
fooddude is offline   Reply With Quote
Old 01-26-2014, 02:08 PM   #2
fooddude
I read past posts that GC has a recommended F6.6kg R7.7kg for their kit. Would this specifically be because of the Koni's particular valving? Would the B8's be vastly different and be better with diff rates?
I am interested in a 6/6, 7/7 or 8/8, or maybe a stiffer front 8/6 or 9/7. Would this work well with the B8's or are these too stiff for the B8's to handle or are they completely not valved to handle a square or stiffer front set-up? ...I am sure this will be hard to answer without testing these rates first-hand and/or a deep knowledge of how the B8's valving work and were designed, he he.
Old 01-26-2014, 05:28 PM   #3
Racecomp Engineering
One thing I see all the time and is incorrect is people assume a BRZ with 5 kg/mm rates front and rear will have the same exact balance (but different limits) as a car with 10 kg/mm rates front and rear. Increasing both ends by the same amount may alter the balance of the car. Like all cars, the front and rear are very different obviously so things change in different ways at both ends.
For us on the softer side of things we like to keep the rates even. We want to keep the car off the bumpstops up front especially to keep handling natural and linear as well as avoid sudden loss of grip. This also helps keep the rear end in check. Additionally, keeping the front end happy geometry-wise means you still have enough front grip to keep the car from understeering. It can be fun, fast, and easy to drive.
For very firm set-ups with fewer compromises we sometimes go with a firmer rear, but it depends on the system. Cars at this level are usually less bumpstop-active and may run with smaller swaybars. Roll is limited enough that large dynamic changes are less of a concern (for a well set-up car). There is still some room for driver preference for balance.
There are still other variables affecting balance...alignment of course but ride height is an often overlooked factor.
- Andy
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
Captain Snooze (01-26-2014), Skyllz (01-26-2014), wparsons (01-27-2014)
Old 01-26-2014, 05:43 PM   #4
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Failing to account for the motion ratio
....The BRZ/FRS has a multi-link rear suspension. The rear spring is mounted inwards on the control arm just a little bit. Unlike the front strut which is mounted at the hub, a 5 kg/mm spring rate in the rear does not mean a 5 kg/mm rate "at the wheel"......... For the front BRZ/FRS with the strut based suspension, it's close to 1. For the rear, it's around 0.75.
Heavily shortened by me.
If you have 4k springs all round the difference is only 1.76k but if you are running 12k all round the difference is 5.28k.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
fooddude (01-26-2014), Racecomp Engineering (01-26-2014)
Old 01-26-2014, 05:53 PM   #5
There's the motion ratio but also things like camber curve, roll centers, bump travel, etc that are different and change differently front and rear. So there's a whole bunch of stuff to look at.
- Andy
Old 01-26-2014, 06:24 PM   #6
fooddude
Ah, I see. Nice info on the motion ratio! The steeper curve in F/R ratio difference as you increase rates makes perfect sense. I was wondering why so many coilover makers (KW, GC kit, Tein, RSR, etc.) have much stiffer rear rates. But now at the same time, I still wonder why others have a much stiffer front (HKS, Apex, Blitz, etc.). Did the latter take into account this motion ratio and those other things, or did they just guess and slap on anything for testing? But, I think this would be common sense for these engineers though; as many many cars have very similar setups (ie: front strut at hub, rear shock slightly inwards on lca).
Maybe the coilovers that took long to develop and were released very late (as opposed to very early and right when the car was available) would have the most R&D and might be the best choices. ie: Ohlins Road and Track, Bilstein, etc. only just got recently announced (obviously a lot of R&D went into these)...vs, HKS and other coilovers (which were announced only a few months after the car was released?? lol)
Companies like Ohlins and Bilstein did actual first hand R&D on the exact FRS/BRZ platform...and perhaps, maybe, companies like HKS, Tein, etc., didn't and based it more on their past data/experience with other similar cars?
Old 01-26-2014, 06:56 PM   #7
Captain Snooze
Drives: Red Herring
Originally Posted by fooddude View Post
Maybe the coilovers that took long to develop and were released very late...................
................maybe, companies like HKS, Tein, etc., didn't and based it more on their past data/experience with other similar cars?
Bunch of throw away lines coming up:
Everything's a compromise.
There is no one correct way.
Different people want different outcomes/results.
I like chocolate.
The Following 4 Users Say Thank You to Captain Snooze For This Useful Post:
Mikem53 (01-26-2014), mou (01-27-2014), Racecomp Engineering (01-26-2014), wparsons (01-27-2014)
Old 01-26-2014, 07:38 PM   #8
It's difficult to know what every company did and why and how long they were working on it. I wouldn't assume that companies that came out with products later did any more R&D than companies that had stuff available earlier. Ohlins and Bilstein for example may have just had more on their plate when the car was released and didn't get around to jumping in until later.
Bilstein more likely was waiting to see what the market would be like, especially for their struts. That's a huge up front tooling cost for them, a lot more than coilovers. They didn't have an application for Subaru Impreza at all for a long time. They do now because they make them exclusively for our sister brand GTWORX.
That said, it wouldn't surprise me if a lot of companies just made lower mounts and camber plates that fit, added the same damper bodies with the same valving they use on other cars, and picked spring rates out of a hat.
But like Captain Snooze said, there isn't 1 right way and different applications call for different set-ups. Some companies have certain tendencies (building for safe understeer) while others don't, or even go back and forth. Some are building for street guys/gals while others are going for more track oriented set-ups.
I've thought about this a lot actually and I've sort of given up trying to figure out why certain companies do certain things. When the GR Impreza came out with a completely new rear suspension, a lot of companies used the same spring rates that they used on the older GD Impreza. I never got a good explanation as to why. Eventually I saw many of them switch to different rates.
The EVO 8/9 was interesting too. Most lowering springs (like OEM) were rear biased because of the rear motion ratio being lower than front. But most coilovers were front biased for....well no one knows why. Some would say it was the JDM way of doing things but no one knows what the time attack EVOs were doing in Japan and anyone who was fast here and knew what they were doing certainly weren't running front biased rates. I think most companies making lowering springs just took the OEM rates and added 10%. Companies making coilovers were just looking at weight distribution. When the EVO X came out, the market was more educated, and a lot of companies changed their line of thinking.
- Andy
feldy (01-27-2014)
Old 01-26-2014, 07:51 PM   #9
Suberman
Drives: Subaru BRZ Sport Tech Satin White
It is a very complex problem with more than one correct answer.
The key to satisfaction when upgrading suspension (and brakes) is to deal only with reputable manufacturers and parts suppliers who have done their homework properly.
Factory suspension engineers have huge resources to design and manufacture these systems. The same big aftermarket manufacturers of springs, dampers and brakes also supply the car makers. Key to this is the car manufacturer relies heavily on their suppliers to do some or sometimes all of the engineering on different sub systems in the cars.
It would be good to be able to read or see a video comparing the various aftermarket suspension set ups. However, to be useful you would need to have an idea about what you expect from your planned modifications. There are so many ways to set up a car that you need to develop an idea of how you want yours to behave before you go shopping.
Suberman is offline   Reply With Quote
Old 01-26-2014, 08:34 PM   #10
Captain Snooze
Drives: Red Herring
This.
Old 01-26-2014, 09:54 PM   #11
mrk1
Drives: Sterling BRZ Ltd
Certainly a personally preference. My car is under going a turbo conversion and the new found power is making me rethink my suspension setup since rear end traction will have a new found importance. Also I will be driving the car differently with the power. Ultimately I've just jumping in and will change it up a few times before finding what works for me.
Linear vs Progressive is another point that needs to be considered. I like linear myself.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-27-2014, 03:02 AM   #12
fooddude
- Andy
Yes...and this is what I am worried about (and I am sure everyone else too) and why I mentioned r&d time and how could some companies release coilovers a few weeks after the frx/brz just hit the dealers (a bit tooo fast, no?). No one wants to spend their hard earned money(which isn't exactly just a few hundred dollars) on a half-@ssed engineered, nor lazily/hastily designed, $2-3k coilover system, where the "well-known named suspension company" just reused the same dampers/valvings from their other older models + a spring rates that sounds like it'd work , etc., etc. Makes me wary how Tein, HKS, etc. could release coilovers so quickly. I really hope they aren't doing this..lol.
- Andy
Yes, I am wondering why so many JDM rates are so front bias, while US/Europe brands are the opposite.
But, after reading many threads on here with track experience from diff people and diff coilover/spring/strut setups ..I see some similarities in what people want and it might make sense. ie: I read some wanting to get a stiffer front sway bar, or others wanting to ditch the rear sway bar completely, and others wanting to get softer rear spring rates for more grip because stiffer rear gets too playful/squirmy under acceleration, etc... which are all reasons gravitating towards, and having a similar result, to going for and having a stiffer front spring rate. So maybe the JDM company's front rate bias tendencies have something going for them and are saying something?
Old 01-27-2014, 09:11 AM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
Already mentioned, bears repeating: Wheel rate is what is important. Spring rate is a *means* to get the desired WHEEL rate. It is the wheel rate that determines natural frequencies and handling characteristics.
Given the motion ratios, I can't imagine that stiffer front springs would be a good idea.
Front motion ratio is ~.95, rear is ~.75.
That means that front wheel rate is (.95)^2 or 0.90 x spring rate, while rear wheel rate is (.75)^2 or .56 x rear spring rate.
To have equal wheel rates, rear springs would have to be (.90/.56) = 1.6x stiffer than fronts.
A set of springs balanced for the car's 54/46 weight distribution would suggest a front wheel rate 1.17x stiffer than rear wheel rate.
To achieve that you'd still need stiffer rear springs, 1.37x stiffer than fronts.
I would think that same stiffness springs all around would be too much front bias. My preference would be to start with rear springs significantly stiffer than fronts.
Even "weird" setups can be made to work, but in my experience I've generally ended up with the wheel rates biased to the rear relative to the weight distribution, and balanced with stiffer front sway and sometimes even removed or disconnected the rear sway.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Calum (01-27-2014), CSG Mike (01-27-2014), wparsons (01-27-2014)
Old 01-27-2014, 09:21 AM   #14
u/Josh
Drives: GBS Limited 6MT
How does the changing roll centers when lowering the car play into this?
u/Josh is offline   Reply With Quote
Spring Rates - Track / Autocross Dave-ROR Tracking / Autocross / HPDE / Drifting 83 05-16-2023 05:56 PM
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 03:56 PM
Coilover spring rates for comfort Barbecue Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-13-2013 12:09 AM
Spring rates for Super charged FRS jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-21-2013 10:32 PM
Weird GT 86 factory spring rates in GT5? Spec-Al Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 03-27-2012 03:30 PM
