Old 01-26-2014, 01:04 PM   #1
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Trunk light out
My trunk light no longer comes on when the trunk is open. I'm trying to check the fuses but not clear which fuse goes to the trunk light.
Any recommendations on what to do?
Sent from my Nexus 7 using Tapatalk 2
mit_peid is offline   Reply With Quote
Old 01-26-2014, 01:14 PM   #2
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
i'd probably try replacing the bulb first if you haven't already done so
mezdup is offline   Reply With Quote
Old 01-26-2014, 01:17 PM   #3
mit_peid
Boosted Noob
mit_peid's Avatar
Bulb looks ok. Haven't tried another bulb yet tho.
Old 01-26-2014, 02:18 PM   #4
White64Goat
Check it with a multimeter to see if you even have power at the socket.
Old 01-26-2014, 03:03 PM   #5
mit_peid
Boosted Noob
mit_peid's Avatar
Went to get a new bulb at Pep Boys still didn't work. I actually also tested the old bulb on a 12VDC power supply and it did come on so it wasn't the bulb (should have done this before spending $5 on a couple new bulbs). Seems like it isn't getting power for some reason. Must be either the fuse or the sensor/latch that senses the trunk is open.
Old 01-26-2014, 03:24 PM   #6
HapaHaole
Drives: Grocery cart
Is the trunk open light on the dash on when when the trunk is open? And is your dome light set to door mode?
HapaHaole is offline   Reply With Quote
Old 01-26-2014, 03:25 PM   #7
HapaHaole
The sensor is on the trunk latch. Fuse is the 20A dome fuse same one for the interior dome lights.
The Following User Says Thank You to HapaHaole For This Useful Post:
mit_peid (01-26-2014)
Old 01-26-2014, 03:32 PM   #8
mit_peid
Boosted Noob
mit_peid's Avatar
Great question. When the trunk is open, the door/trunk open light no longer comes on (it did before). As a side note, since I put some dynamat in the trunk lid and my 5-axis spoiler, the extra weight on the trunk lid gives the struts some more work (sometimes I can't even tell it is open). So where is the latch/sensor that tells the car the trunk is open?
Old 01-26-2014, 03:41 PM   #9
HapaHaole
The sensor sends a signal to the body control module the turns on the light for the cluster and provides the ground for the light in the trunk. That sensor is part of the latch that releases the trunk to open.
Old 01-26-2014, 03:49 PM   #10
HapaHaole
Does your dome light work?
Old 01-26-2014, 05:16 PM   #11
mit_peid
Boosted Noob
mit_peid's Avatar
Yeah it does.
Old 01-26-2014, 09:20 PM   #12
HapaHaole
I Just checked my brz, the connector and wire are on the trunk lid you will see the connector on the passenger side of the latch release.
Old 01-26-2014, 09:20 PM   #13
HapaHaole
Yeah it does.
Then then your trunk light fuse is good. It just needs that switch signal.
Old 02-02-2014, 11:38 AM   #14
mit_peid
Boosted Noob
mit_peid's Avatar
Going to spend some more time today looking for the source of the trunk switch signal. For the front driver/passenger doors, it is the little black rubber knob thing that triggers the signal (I believe), but not sure what I'm looking for in the trunk.
Zeta Performance - Lights (HID, LEDs, LED Taillights, LED Reverse Light, Trunk Light) ZetaPerformance Exterior Parts - Lighting 172 11-13-2015 11:25 AM
replacing trunk light on FRS jdair28 Cosmetic Modification (Interior/Exterior/Lighting) 7 11-08-2013 01:29 PM
Anyone know if trunk light has a fuse? convoy Cosmetic Modification (Interior/Exterior/Lighting) 2 04-15-2013 06:57 PM
Auto-Hauss Dual Trunk Light Introuctory Price! Light Up The Rest Of Your Trunk! Auto-Hauss Interior Parts (Incl. Lighting) 10 03-11-2013 11:55 PM
