Koji_Online
Old 01-10-2014, 04:32 PM   #365
chas3wba0
chas3wba0's Avatar
Drives: Yes
Originally Posted by 1Cor10:23 View Post
Maybe I should take a look as well, I feel like the effect seems to be a bit muted since I first made the adjustment. Thought it might be in my head/getting more used to the lower grab but perhaps it's a bit loose - we'll see!
It's probably just you getting used to the new engagement point. It's a spindle rod, so the nut being loose shouldn't necessarily allow the rod to rotate that freely by itself, it's just for added security and robustness. When I checked, I didn't notice any change in the pedal height.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following User Says Thank You to chas3wba0 For This Useful Post:
1Cor10:23 (01-10-2014)
Old 01-10-2014, 06:19 PM   #366
gonzo
Drives: frs
When the pedal is lowered, my pedal has 2-3 mm dead space at the top. It seems the pedal can be pushed in and pulled out of this deadspace without it moving the clutch plates.
Is it okay to move the cruise control sensor into the pedal to get rid of this wiggle space? It doesn't seem to be enough pressure to begin disengaging the clutch, but it does get rid of that annoying empty feeling at the top.
Thoughts?
gonzo is offline   Reply With Quote
Old 01-18-2014, 03:52 PM   #367
cparr350
Drives: swp limited
Thoughts?
i had the same question
cparr350 is offline   Reply With Quote
Old 01-18-2014, 04:18 PM   #368
vincent201089
vincent201089's Avatar
Drives: frs
^^^^^ same here. I dont know if it was like that before but I could press the clutch pedal in for few mm. Other than that. I already got used to the new height.
vincent201089 is offline   Reply With Quote
Old 01-18-2014, 05:49 PM   #369
chas3wba0
chas3wba0's Avatar
Drives: Yes
Thoughts?
I think that means you lowered it too much. I noticed it too when I lowered it more than ~2mm below the brake pedal; the clutch just felt a lot less springy and I wasn't feeling it, so I raised it to almost level with the brake pedal and now it's perfectly solid. May have something to do with the orientation of the spring for the clutch pedal.
vincent201089 (01-18-2014)
Old 01-18-2014, 06:22 PM   #370
vincent201089
Drives: frs
My clutch is not lower than the breake pedal. It has same height even higher. Anyway, I'll check tomorrow.
Old 01-24-2014, 07:03 PM   #371
Indestruct
Drives: 2013 SWP Limited BRZ, MT
After driving around for a year and a half i finally got to lowering my clutch pedal. At first i made it lower than the brake pedal, and although the engagement feels best here, I missed the compound bow springiness of the clutch. I made it flush or slighly higher than the brake pedal and got the springiness is back... This is where I'm keeping it. In-between normal and absurdly high.
Indestruct is offline   Reply With Quote
The Following User Says Thank You to Indestruct For This Useful Post:
ericmpena (01-26-2014)
Old 01-26-2014, 09:28 AM   #372
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
It's never bothered me how high the clutch sat until I read this thread. Now I HAVE to adjust it! Thanks!
ericmpena is offline   Reply With Quote
Old 01-26-2014, 10:09 AM   #373
jonbonazza
After driving mine for 8 months, my clutch releases at almost the very top of the throw. Never had this happen in any other MT i have driven. What does this mean?
Sent from my Nexus 4 using Tapatalk
jonbonazza is offline   Reply With Quote
The Following User Says Thank You to jonbonazza For This Useful Post:
FirestormFlex (04-18-2016)
Old 01-26-2014, 10:27 AM   #374
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
After driving with my seat nearly all the way forward to help get my drunken idgit friends home, I can really appreciate this adjustment.
Deadspool is offline   Reply With Quote
The Following User Says Thank You to Deadspool For This Useful Post:
gonzo (01-26-2014)
Old 02-03-2014, 02:47 PM   #375
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
I'm so used to the stock setting now, but still plan on doing it this summer... funny thing is I was all ready to go for adjusting it 2nd week of buying the car last year, but I did not have the correct wrench size out of all my wrenches and decided to just deal with it.
Myv is offline   Reply With Quote
Old 02-03-2014, 07:44 PM   #376
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Did this today. Tried all sorts of things.
But then I got it to the point I wanted, and the clutch started making a click noise when I put it in and pulled it out. Not like transmission noise, or anything like that. It was purely a pop like a part of the clutch assembly. It's not terrible loud, or sounds bad, but it's a bit obnoxious.
I went back to stock height and am still getting it. I didn't move the sensor at all.
any thoughts? It's definitely in the cabin. It seems like it may have something to do with the cylinder.
86-tundra is offline   Reply With Quote
Old 02-04-2014, 05:28 AM   #377
JB86'd
JB86'd's Avatar
Drives: JAWS
Mine did the same thing...it doesn't sound bad but I was slightly concerned as well, and it's pretty annoying constantly hearing it. I haven't pinpointed the location either.
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
86-tundra (02-04-2014)
Old 02-04-2014, 10:21 AM   #378
86-tundra
Troll Hunter
86-tundra's Avatar
Glad I'm not the only one. I posted a thread in the Issues subforum
http://www.ft86club.com/forums/showthread.php?t=57383
theres a video there too
The Following User Says Thank You to 86-tundra For This Useful Post:
ericmpena (02-04-2014)
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
