#995 |
Just drive it
Drives: 13' FR-S
@solidONE haha yeah, i know why we install tune, to get more power! but I was a bit concerned about the abrupt engine noise at that 4000 rpm, that was all
![]() I'm happy with the result. I can't wait to get a header and get stage 2 file.. |
#996 |
#997 |
Drives: FR-S Whiteout
both mid 2000 VQ's one G35 coupe, and Maxima.
edit: Add my neighbors Cayanne S to the kill list. I guess my 0-60 times are in the mid to low 5's at the moment.
#998 |
Drives: Argento Scion FRS
Quick question. Would the Vigilant CAI be compatible with he current maps or with it mess up the afrs too much. Thanks!
#999 | |
Drives: FT86
I have no idea what spec's a viglinant CAI has however their is a good writeup here on the stock Intake. http://www.ft86club.com/forums/showthread.php?t=56358 If this vigilant intake changes the diameter of the tube where the MAF sensor sits then its likely to need a specific re-tune of the MAF scaling parameters. I also believe the stock intake has "straighteners" to smooth the air flow through the MAF some aftermarket intakes don't and this can upset the maf scaling can be fixed but requires re-scale. It may come with scaling info. Seems stock intake it pretty good for N/A cars and not much gains to be had by aftermarket intakes. The consensus appears to be add 1. A quality drop in replacement filter 2. Maybe a "perrin" intake tube (only cause I have seen dyno results from a couple of sources that show small 2-3 whp gains) and it removes sound tube. 3. Cut the stock intake snorkel down and expand inlet (there is a how to do guide somewhere) These simple cheap mods would appear to get results very close to any aftermarket intake system on an N/A car Last edited by steve99; 01-25-2014 at 09:37 PM. |
#1000 |
Drives: Pavement MT GR86
Checkout the Grimmspeed intake thread in the exhaust section...
Right now they are testing all kinds of setups including stock, modded stock and different intakes.
GR86 MT premium
| The Following User Says Thank You to StormTrooper For This Useful Post: | solidONE (01-26-2014) |
#1001 |
If you can, go back to the stock Intake and modify it. Then sell your old intake to help pay for the OTF. Win, Win
#1002 |
I already have an OFT and running a Stage 1 map. I was just looking to see if I could get a better flowing intake. Specifically one that has the filter located inside the bumper instead of sol close to the engine. But I will not purchase it if it will negatively impact my performance.
#1003 | |
#1004 | |
#1005 | |
Drives: FT86
#1006 |
Drives: 2013 SWP BRZ
Is there any mounting solutions out for the OFT to keep an eye on live data while driving or on track? (i.e. oil temps, water temps, etc?)
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
| The Following User Says Thank You to smbstyle For This Useful Post: | JFBRZ711 (01-28-2014) |
#1007 |
Drives: 2013 Scion FR-S Raven
The FA20club CAI works very well with OFT v1.54 EL header gas tune. I will data log next week to provide IAT's with this tune. Previous data logging show only a two degree differential
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#1008 | |
Drives: Neptune GR86
I'm assuming you'll need one for a large phone, like a Note.
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 02:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 01:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
