| Software Tuning Discuss all software tuning topics. |
#29 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
| The Following User Says Thank You to Luckrider For This Useful Post: | 1086 (01-24-2014) |
#30 | |
Drives: 2013 FR-S Argento
I'll post up some logs in a bit.
#31 |
Drives: UM86 - 6MT
How many miles have you driven on a straight tank of only E85 thus far?
#32 | |
My point was that I am *sure* that I am not running full E85. I had some gas in my tank. My car starts just fine in 9 degree F weather. My fuel trims are minimally adjusted. My IAM is fine. Just seems to me that if I were running something like 60% ethanol on a tune that's ideal for 85% ethanol, I'd see bigger timing corrections and bigger fuel trims in my logs.... |
#33 |
Hmmmm probably 150 - yeah I know it takes the ECU a bit to adjust itself. But logs seem stable... And it's not a straight tank of E85 - heck I'm not even sure what ethanol content the filling station is running. It's winter and I imagine I'm far enough north that the may run lower ethanol content at their ethanol pumps? Definitely had a gallon or two of 93 in the tank when I filled up.
#34 |
Drives: UM86 - 6MT
Right, well that right there could easily be holding back 10 horsepower give or take. I am in California, so our 'winter blend' could be totally different - which is likely the case. The E85 station I use has a label telling you the minimum ethanol content (70% for me), idk about others though.
I noticed that once I had a full tank of only E85 (nothing else) there was a noticeable difference vs. an 80%/20% mixture of E85/91 |
#35 | |
| The Following User Says Thank You to bfrank1972 For This Useful Post: | 1086 (01-24-2014) |
#36 | |
#37 |
Boosted
Drives: Not a supra....yet
Oh i forgot you guys have the epic OFT that magically adjusts its self, ma bad Sent from my IBrick
#38 |
Logs on my E85 'mix', 3rd gear run to redline, about 25 degres F (1.42 E85 EL map, completely stock car sans washable air filter in stock airbox).
http://www.datazap.me/u/bfrank1972/f...zoom=4094-4492 I'm still learning this stuff - but it looks terrific to me. @shiv@vishnu how does it look? FYI I have absolutely no problems starting the car whatsoever using the OTS 1.42 E85 EL maps even at 9 degrees F - though I do get misses and some minor intake backfire for a minute or so during cold idle cycle. Also a question related to HP output - is it possible use MAF voltage logs to extrapolate HP increase? For instance, say I want to judge relative HP increase from the 91 stage 1 map to the E85 EL map I have - can I compare a MAF voltage log from the stage 1 map to a MAF voltage log from the E85 map and estimate a percent increase over the power curve? |
#39 |
Drives: 2013 White BRZ Limited, Ford Raptor
Can someone who did the flex fuel kit who wired the kit into the ECU please link me to the correct diagram showing where to wire into the content analyzer?
#40 |
Drives: 2008 Civic Si
Starting actual 85% ethanol in those temps is pretty much impossible. It's too much ethanol content to get proper atomization of the fuel to crank. This is why winter ethanol blends are between e60 and e70.
| The Following User Says Thank You to w00t692 For This Useful Post: | CaptainSlow (01-31-2014) |
#41 |
Your local stations actually have E85? The ones around here are running a winter blend of around E70. I ran through one tank of that and went back to 93 until spring.
My thing is that I can't use the extra power when the roads are covered in snow and the tires are hard as rocks, so there really isn't any point in running E85 until it warms up. It might be cheaper, but the mileage reduction balances things out pretty evenly, so it really comes down to power for me. That, and I'm not willing to risk any engine trouble from running less than 85% ethanol
Ultramarine 2013 Scion FR-S 6MT
#42 |
Winter blend is certainly not e60 to e70 as all pumps around here (the few that we have) say 70% minimum. I myself have not been having major issues, but I have been working on making cold starts better for people with higher e% fuels.
As far as atomization is concerned, that isn't the problem, the problem is the flash point (the temperature at which the fuel turns to vapor) of e85 is way higher than gas. |
| ONE FREAKING WEEK!!!! | Xlr8 | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 10-23-2013 04:29 PM |
| FR-S/BRZ Week – Exciting Week For Owners | 86_Insider | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 08-09-2013 06:38 PM |
| ETA = This week! | VADER | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-20-2012 06:18 PM |
| MY GF's FRS confirmed for last week of May or first week of June | clayrush | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 04-19-2012 04:45 PM |
