Old 01-21-2014, 01:31 PM   #2479
MAPerformance
Drives: Asphalt FRS
Originally Posted by transition View Post
Anyone have access to a lift? I've got headers/exhaust/springs etc to install and it would be a hell of a lot easier if i could use borrow/rent someones setup.
I might be able to rent you one of our lifts over the weekend for pretty cheap. Would you need some tools too? Or will you be providing yours?
MAPerformance is offline   Reply With Quote
Old 01-21-2014, 02:04 PM   #2480
transition
Wow that would be incredible. Still waiting for some parts to arrive - might be a couple weeks. I was planning on coming over to do a baseline pull once the roads clear up a bit - the BRZ is hibernating presently.
As far as tools go i'm fully equipped. If you don't mind i'll send you a PM when I'm prepared to see if we can work out a deal. I haven't been over to the new shop yet - would love to check it out.
transition is offline   Reply With Quote
The Following User Says Thank You to transition For This Useful Post:
Starscream15 (01-23-2014)
Old 01-21-2014, 02:17 PM   #2481
MAPerformance
Drives: Asphalt FRS
No problem man. Shoot me a PM when you get all of your parts, and when the weather is more cooperative. We can set up a Saturday/Sunday to play with some cars
Old 01-23-2014, 12:26 PM   #2482
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
GD Ian, if you guys are willing to rent out a lift for a bit on a weekend, I am surely in. I need to get my Front-pipe and header in soon
Starscream15 is offline   Reply With Quote
Old 01-23-2014, 12:30 PM   #2483
Starscream15
Originally Posted by jdnguyen View Post
Hello! I've had my FRS a little over a week now and I have already ordered eibach sportlines! I couldn't stand the wheel gap. I'm half tempted to order the stance lower control arms, a set of gram lights 57dr 18x8.5/9.5, perrin drop in filter, and perrin light weight crank pulley. Its so hard not to start blowing money on this car!
They were pretty easy to do. Make sure you get a pass-through Ratchet before you start tearing the car apart. You need it to remove the top hat if you're using spring compressors. It's a little trixy to do, trying to hold the allen wrench while you loosten the top hat nut. Trust me, I learned this the hard way..
Make sure you don't allow the top half of the strut to rotate, you will likely ruin the seals and lose strut compression.
Old 01-23-2014, 12:32 PM   #2484
MAPerformance
Drives: Asphalt FRS
We should just have a get together/meet one weekend and all do some wrenching. Just a thought
The Following User Says Thank You to MAPerformance For This Useful Post:
neutron256 (01-24-2014)
Old 01-23-2014, 12:35 PM   #2485
Starscream15
Count me in, most definitely. Always easier to work with more hands.
Old 01-23-2014, 12:44 PM   #2486
MAPerformance
Drives: Asphalt FRS
Maybe once the weather starts cooperating, we can plan a meet and spend the day at the shop, order some pizzas and such. I think it could be fun!
Old 01-23-2014, 12:49 PM   #2487
Starscream15
Thumbs up
Hell Yes.
The Following User Says Thank You to Starscream15 For This Useful Post:
MAPerformance (01-23-2014)
Old 01-23-2014, 12:58 PM   #2488
MAPerformance
Drives: Asphalt FRS
Hell Yes.
And drive the boosted FRS around of course
Old 01-23-2014, 01:00 PM   #2489
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
I'm sure nobody has ever done a burnout on the road in front of the shop.
JohnJuan is offline   Reply With Quote
Old 01-23-2014, 01:04 PM   #2490
Starscream15
I wish I had an extra 5g laying around, I would have that damned innovate kit.
Old 01-23-2014, 01:13 PM   #2491
MAPerformance
Drives: Asphalt FRS
Nope. Nobody. Ever.
Old 01-23-2014, 02:07 PM   #2492
transition
For reference here are two threads that i found to be most informative if you're doing strings or struts.
Replacing Struts and Installing Coil Springs
..and some other good relevant tips here as well:
A simpler spring/strut install DIY -- no compressor needed
Check in, eh? NorthFool CANADA 24 02-23-2012 08:32 AM
*NSFW* "Check Out My Subaru" on You Tube Axel Other Vehicles & General Automotive Discussions 4 01-17-2010 06:56 PM
how do you check a site 4agze Off-Topic Lounge [WARNING: NO POLITICS] 3 11-21-2009 10:27 PM
Video of FT-86 @ TMS from Edmunds. Check out how small the car is next to people. JDMinc FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 10-25-2009 09:53 PM
