Old 01-21-2014, 01:31 PM   #15
gily25
Drives: Silica BRZ 6MT
How many miles are on the car?
I can't see any basic brake service costing $400 (bleed, fluid echange, etc.) but if you need 4 wheel brake service (pads/rotors); I can see that number being subjective (i.e. if only one axle needs pads) so maybe it's a rough estimate to prepare the ignorant.
gily25 is offline   Reply With Quote
Old 01-21-2014, 02:19 PM   #16
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
the brake service is machining the brake. i have almost 20000km(~12000miles) on my BRZ.
chenshuo is offline   Reply With Quote
Old 01-21-2014, 03:35 PM   #17
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I wouldn't machine the rotors unless you're getting vibrations while braking.
Unless you're having braking issues, I would skip this service.
I would do the brake fluid exchange every 2 years, it's 75 dollars usually and that's about it. Unless the brake pads are worn out or the rotors are warped, it's not time to do any brake servicing.
I would also skip any inspection as well. It's not worth it.
The Following User Says Thank You to N1rve For This Useful Post:
Kwisak (01-21-2014)
Old 01-22-2014, 04:00 AM   #18
Euro7R
Drives: 2013 Subaru BRZ
Same situation as OP. I can't justify being charged so much when they aren't actually replacing something. Our cars are still new to spend so much servicing this early.
Euro7R is offline   Reply With Quote
Old 01-22-2014, 10:43 AM   #19
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
I agree, PO. And be very specific and ask what materials and WHY! Make sure it is all done. I have even asked for the empty oil containers to show me what oil is/was used. I kept the empty container.
Originally Posted by SirBrass View Post
I'd say call and ask what the $400 is used on.
BRZfan is offline   Reply With Quote
Old 01-22-2014, 01:44 PM   #20
Inextirpable
Awesome
Inextirpable's Avatar
Drives: World Rally Blue Subaru BRZ
When I took it in for service at 20,000KM they did not do anything like that to my vehicle. Just the usual oil change and walk around the car. Should I be worried or relieved?
Inextirpable is offline   Reply With Quote
Old 01-22-2014, 02:28 PM   #21
djdnz
1337
Drives: 2013 BRZ WRB S/C
The Canadian owners manual is pretty overkill with their maintenance schedule.
djdnz is offline   Reply With Quote
Old 01-22-2014, 02:31 PM   #22
N1rve
N1rve's Avatar
Both It means that they don't care or they don't want to up sale you. LOL
Old 01-22-2014, 10:28 PM   #23
fistpoint
Drives: Supercharged Golf Cart
I'll give it another shot to try and save my fellow Hachi drivers some money.
My RSX needs brakes. My local Honda charges $199 for the fronts, $199 for the backs any day of the week. On sale, that prices drops to $175 each, total $350-400 depending on sale or not.
Your $400 service this time includes about $50 for the oil change, and the remaining $350 to LOOK at your brakes, then maybe machine the rotors? Did you know just about any auto parts store around you will turn your rotors for between $5 and $10 each if you bring them in?
So, they're basically charging you the full price of machining all 4 rotors, replacing all 4 pads and packing them full of grease. You're paying for an entire 4 wheel brake job but only getting the cheapest part done(machining rotors, total cost $20-$40).
Like the guy a few posts above me said, if your rotors needed machining, you most definitely would know about it without them telling you because your car would shudder when you brake.
Save that extra $350 for when you get the entire 4 wheel brake job done when it's needed. Call them up and ask how much a full brake job costs, you'll see. It should be close to what they're already asking.
fistpoint is offline   Reply With Quote
The Following User Says Thank You to fistpoint For This Useful Post:
ZionsWrath (01-22-2014)
Old 01-22-2014, 10:52 PM   #24
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Reading the manual suggest your new car requires more maintenance than a used car. I don't know if you have provincial inspections in Ontario but here it's a yearly thing and they do check brakes and suspension (and it's 35$!), redundant.
I'm not bringing my car to the dealer unless it's broken, that's just me. I can take care of it myself.
Rayme is offline   Reply With Quote
The Following User Says Thank You to Rayme For This Useful Post:
Old 01-22-2014, 10:57 PM   #25
ZionsWrath
Thanks
ZionsWrath's Avatar
Just change the brake fluid at 30k unless you are tracking your car. Make sure to change it though, I never did it in my last car. Hand countless brake problems after that. I had to replace like 6 calipers. 2 sets of rotors. But now I'm good at disc brake service lol.
Old 01-23-2014, 02:20 AM   #26
N1rve
N1rve's Avatar
I wouldn't let brake fluid sit in the car too long, hence the recommendation of 2 years. Brake fluid is hygroscopic which can lead to corrosion in your brake lines. This can damage your ABS sensors.
If you hear people say "i've never changed my brake fluid on my car"... well their car isn't from this century or have all these sensors in their cars now.
Opie (06-20-2014)
Old 01-23-2014, 02:52 AM   #27
ZionsWrath
Thanks
ZionsWrath's Avatar
Yea i meant that not changing it caused prblems. Sticking calipers warped rotors. I learned lesson
Old 01-23-2014, 01:29 PM   #28
frslee
Just drive it
Drives: 13' FR-S
Please don't spend $400.
frslee is offline   Reply With Quote
First service at Dealer xXDeathMaliCeXx Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 08-24-2013 07:56 PM
Dealer service RevoG Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 06-25-2013 11:13 PM
What is a dealer service fee? Bg8780 BRZ First-Gen (2012+) — General Topics 27 02-01-2013 04:28 AM
First Dealer Service Umbie BRZ First-Gen (2012+) — General Topics 7 12-12-2012 10:50 AM
Best Dealer for Service in ATL kaitak98 Southeast 9 10-11-2012 10:26 AM
