Old 01-20-2014, 01:07 PM   #1
AtlasMick
Drives: FR-S 2013 Asphalt
Widebody correct fitment
Sort of at an Impasse here.
Ordered Lux motion Widebody kit but cannot come to a decision for wheels.
I'd like to have wide tires, as opposed to wide "wheels." I see lots of people running 10-11" wide wheels, but 265 tires. I'm looking to run 285 to 315 depending on what will fit under the widebody best and provide the best selection/value of tires.
Does anyone have any ideas? The lux motion kit is +100mm front +120mm rear on clearance.
Eventually I would like to go with air suspension and I'm not certain how much extra clearance of the suspension is required with that and a 1" drop.
AtlasMick is offline   Reply With Quote
Old 01-20-2014, 01:50 PM   #2
Frostyman
Drives: 2013 Raven FRS
There's a calculator online, that suggested with stock suspension, you could fit 13 inch wide wheels in the back without rubbing, assuming the correct offsets, and stock ride height. I know it's not enough, but it's a place to start I suppose?
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
Old 01-20-2014, 02:24 PM   #3
AtlasMick
I used Rimsntires.com calculator. I got these figures, for wheels. I don't know how much further you could go towards the suspension before rubbing air suspension components. Maybe someone with Airrex or Air Lift could chime in?
100 tire choices (215/45R17 +0% 97mm sidewall *Stock*
21 tire choices (285/30R18) +0.5% 86mm sidewall
19 tire choices (295/30R18) +1.5% 89mm sidewall
3 tire choices (315/25R19) +2.3% 79mm sidewall
12 tire choices (335/30R18) +5.3% 101mm sidewall
21 tire choices (305/30R19) +6.5% 92mm sidewall
Old 01-20-2014, 02:27 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
You need to start with basic information first... such as what alignment, ride height, etc the car will be at.
Then figure out what width the body is going to be at over stock, and then lastly look at current fitment of wheels on stock body for context.
It's hard to provide advice on tire/wheel sizing when you can run anywhere from zero to -3 camber and have a huge difference in fitment.
-alex
AtlasMick (01-20-2014)
Offset and fitment on Varis Widebody davidshu0327 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 03-31-2020 11:20 PM
Which EL Header Correct Torque Dip Best? slava Engine, Exhaust, Transmission 56 02-20-2019 08:50 AM
Correct oil filter for 86? 130 or 160/15A? kharn83 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-27-2013 02:28 AM
Do these look correct for our car? 9005 Replacement BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 1 06-24-2013 12:15 PM
correct idle rpm after warmup StormTrooper Issues | Warranty | Recalls / TSB 11 04-27-2013 08:00 PM
