Old 01-19-2014, 04:28 PM   #379
stugray
Drives: 2013 GBS BRZ Limited
Thanks again!
Now I have the latest ECUFlash and the "write calibration and code area using OEM method" button is now highlighted so I assume I am ready to try.
Last question (hopefully): If I write the OFT "Stage 1 ZA1JA01C" what will the Cal ID read if it gets read by the dealer?
Hopefully just "ZA1JA01C".
Finally - has anyone on this forum actually written one of the OFT ROMs using ECUFlash?
I just want a warm fuzzy or two before I pull the trigger.
Old 01-19-2014, 04:35 PM   #380
utekineir
blowhard
Drives: frs, project forester
Thanks again!
utekineir is offline   Reply With Quote
Old 01-19-2014, 04:43 PM   #381
stugray
Except in this case the "Fight Club" has spoken openly about how open their "flight club" products are and how users should have no trouble using their "fight club" products with other hardware.
If I have to jump through any more hoops than I have already I will tell people to just "Buy the damn fight club product" and forget the hassle of using the tactrix.
For someone who makes over $100 an hour, spending over 50 hours trying to learn how to make the tactrix solution work is making less and less sense every day when the alternative works right out of the box for only 3X as much $$
Old 01-19-2014, 05:23 PM   #382
stugray
Originally Posted by utekineir View Post
It takes roughly 5 minutes to make it work and it's in this thread. Put the right definitions in the right places, correct the check sums and go.
It does NOT take 5 minutes.
AND I have been watching & waiting since September....
Even your simple explanation above:
"Put the right definitions in the right places, correct the check sums and go."
Is not explained in detail
BTW - I Bought the tactrix because it can log innovate data.
Old 01-19-2014, 05:56 PM   #383
utekineir
blowhard
I don't work for nasa, don't have fancy programming experience, haven't even stayed in a holiday inn. Nor do I feel the need to ****swing about my income or the value of my time when asking about using free tunes and free software with a $100 (used) cable on a forum. That's just bad manners (I'm doing just fine btw).
There is enough info to figure out how to make what you want work in a relatively short amount of time using the posts in this thread and the one linked in the op of this thread. It's all there. I know this because by most standards I'm a moron and I've had it working for awhile.
You're missing something, are you making sure the definitions you are adding for ecu flash and rom raider are saved as .xml? Have you downloaded the appropriate definitions and put them in the right places?
Old 01-19-2014, 06:57 PM   #384
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Congratulations on making over $100 an hour and spending your time with the cheapest solution on an economy platform. I salute your jew dedication
Thanks for the antisemitism asshole.
The Following User Says Thank You to EAGLE5 For This Useful Post:
utekineir (01-19-2014)
Old 01-19-2014, 07:02 PM   #385
utekineir
blowhard
I'm actually pro-semitism.
But like ray Lolita and deniro in goodfellas I can never be "made".
Old 01-19-2014, 07:21 PM   #386
stugray
I DO work for NASA,and I DO have fancy programming experience.
Maybe that is why I know enough to understand the risks doing this and that the documentation is in no way "comprehensive".
( I have personally witnessed "Bricking" a 500 million dollar spacecraft millions of miles from Earth)
I understand that it is a DIY thread and the people making it all work are not highly paid automotive engineers work in a fancy office building.
I appreciate the work they do.
The POINT I was making is that IN HINDSIGHT I would probably just buy the OFT and be done with it.
And I dont even know what "****swing about my income" means....
I guess you're just butt hurt that professionals get paid well??
Old 01-19-2014, 07:22 PM   #387
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Whoever's paying you $100/hour, I hope it's not for a technical position. It's really not that hard, and all the information you need has been repeated at least once in this thread.
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
Old 01-19-2014, 07:29 PM   #388
utekineir
blowhard
Richard swinging was the phrase
I had a paid off house at 30, work my own hours and only answer to a checking balance. Doesn't mean it needs to be waved around on a forum to people that don't care.
There are no gold stars for posting what you make or what your time is worth online.
Old 01-19-2014, 07:36 PM   #389
stugray
It is not that hard, but did you forget about all the early discussion about:
the conversions in ECU Editor being wrong
the padding or not padding the first X bytes
Checksums being wrong
More than one user "bricking their ECU"
Saving in Bin vs Hex
etc. , etc.
I guess part of my frustration about the tactrix has nothing to do with Flashing and about logging innovate data without an OBD port, so the 50 hours was mostly trying to get the unit to do that.
And I a am C&DH (command & data handling) engineer for NASA spacecraft that cost over $1 billion each. So I have not only "flashed" a LOT of expensive hardware, but I have done it to spacecraft that were a long ways away.
My primary job is writing procedures for loading flight software.
So as I said: maybe due to my job, I am overly anal about getting the instructions right instead of "just do it".
Old 01-19-2014, 07:41 PM   #390
reardrv
Drives: 2013 Subaru BRZ
Well maybe instead of arguing someone could try to explain it so a welder making $18 an hour like myself can understand it.
reardrv is offline   Reply With Quote
The Following User Says Thank You to reardrv For This Useful Post:
Old 01-19-2014, 07:44 PM   #391
utekineir
blowhard
If a guy that handles software updates for billion dollar spacecraft in galaxies far far away can't get it what hope do us morons have?
Hardest part is saving the definition files as .xml instead of as txt.
Old 01-19-2014, 08:17 PM   #392
reardrv
Lol... Well I can figure the XML part out, still can't get it to work right. It keeps saying I'm trying to read an unknown ROM image. I've run into this issue before trying to get it to work on my old 09 WRX when those definitions just came out. I'm trying to read the OFT ROM's and I can do it just fine on RomRaider, just not on ECUflash. Maybe someone more knowledgeable than myself can do a write up in the DIY section?
Close iJason Member's Car Journals 1 08-04-2013 09:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 03:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 02:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 10:40 AM
