Old 01-16-2014, 03:14 PM   #29
greenguy101
VMFIC ORLANDO SCIKOTICS
greenguy101's Avatar
Originally Posted by markmatley View Post
I'm wondering how you pried apart the backing for the gauge cluster? I couldn't pry apart the backing to see if I could reach the led's. Did you have to just pull the needles?
I had a buddy of mine do it and it was over a year ago so you will have to forgive my memory loss but I am pretty sure it was just clipped together. And yes, just pry the needles off. Make sure you take a pic of the needle placement before you pry them off. This will be a reference photo for when you put the needles back on.
"Silence is acceptance so start talking or quit bitching!"
greenguy101 is offline   Reply With Quote
Old 01-17-2014, 08:50 PM   #30
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Thanks! I tried to pry apart the backing after taking every clip off. I guess I have to go balls to the wall and pry the needles off.
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 01-18-2014, 12:25 PM   #31
ALbadboy
ALbadboy's Avatar
Drives: 2013 Subaru BRZ Limited (WRB MT)
If you haven't taken the needles off yet, WAIT! The refrence photo is a good idea, but better yet, get some blue painters tape, turn the needle to it's stopping position, next lay a piece of tape down under the tip of the needle, then mark the position with a sharpie, lastly pry the needle off. The blue tape will leave no residue and you will have a more precise mark to go off of than a photo.
Source: I work as an Automotive Electronics Specialist and remanufacture a lot of gauges..
ALbadboy is offline   Reply With Quote
The Following 2 Users Say Thank You to ALbadboy For This Useful Post:
civicdrivr (01-18-2014), Pwolf (01-18-2014)
Old 01-18-2014, 09:18 PM   #32
markmatley
markmatley's Avatar
Yup this has already been done. I'm testing out the fuel gauge needle and how realistically it measures fuel level so I've got a bunch of little tape marks everywhere. Thanks again!
~Matt
Old 01-31-2014, 09:42 PM   #33
Blackrsx
Drives: Red FRS
Just completed the HVAC lights to red.
http://www.ft86club.com/forums/showt...t=8336&page=5/
Planning on trying the gauges next. Going to make it all red. Will try and take pics and post steps as much as I can.
Blackrsx is offline   Reply With Quote
Old 02-01-2014, 12:46 AM   #34
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
I'll just leave this right here.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 02-01-2014, 12:52 AM   #35
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
mmmmmmm that looks so good.
I did my traction control panel a few weekends ago but the blue leds I got aren't very bright.
Thinking I'm just going to do all white LEDs with blue film.
Pwolf is offline   Reply With Quote
Old 02-14-2014, 02:00 AM   #36
Blackrsx
Drives: Red FRS
I just did mine to red. Here is a quick DIY I wrote up.
The Following User Says Thank You to Blackrsx For This Useful Post:
Pwolf (02-14-2014)
Old 02-14-2014, 02:27 AM   #37
ALbadboy
ALbadboy's Avatar
Originally Posted by Blackrsx View Post
Hi Acree, is there data that is stored in each gauge cluster? Is there anything I need to look out for before installing a different gauge cluster in?
Your mileage is stored in your cluster. So if you put another one in the mileage won't be correct. Besides that our cars don't have automatic seats or steering wheel radio controls, etc. so everything will be plug n play.
Old 02-14-2014, 02:38 AM   #38
Blackrsx
Drives: Red FRS
Is there a way to get the new cluster to "sync" to what my mileage is now?
Old 02-14-2014, 02:43 AM   #39
ALbadboy
ALbadboy's Avatar
The only way to do that is to either do a chip transplant and swap it over which I highly recommend you leave that to someone with experience. Or get the Steelership to program it for you which will cost a lot. I'd do the transplant, but I've never analyzed our Instrument clusters before so I'd need to take a look at the circuit board. Honestly it would probably be a whole lot easier just to do the LEDs on the original Instrument cluster.
The Following User Says Thank You to ALbadboy For This Useful Post:
SirBrass (02-14-2014)
Old 02-14-2014, 02:45 AM   #40
Blackrsx
Drives: Red FRS
Yup. I think I'll end up doing that. Can I still plug this other cluster in to test if I like the new LEDs without it affecting anything? Thanks for the info.
Old 02-14-2014, 02:47 AM   #41
ALbadboy
ALbadboy's Avatar
That's a good idea. And yes of course, go right ahead. No problem man!
Blackrsx (02-14-2014)
Old 02-14-2014, 02:48 AM   #42
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
It's the most inexpensive solution, but also the riskiest.
The best way is probably to let a custom automotive shop handle it. That way the work is warrantied, so if they futz something up during the swap, it's on them to fix it or replace the cluster and make sure it is properly reprogrammed, without charging you for more than the originally requested work.
^GT5 Replay Photo Mode^
The Following User Says Thank You to SirBrass For This Useful Post:
Removing gauge cluster surround Gen Cosmetic Modification (Interior/Exterior/Lighting) 8 04-25-2013 11:28 AM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
Aftermarket gauge placement CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 22 08-18-2012 02:01 AM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 12:21 PM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 12:39 PM
