#2675 |
Drives: 2013 SWP BRZ
Another thing worth note:
When I was removing the supercharger, I noticed a few bolts were "tight". 98% of the bolts I could take out by hand extremely easy once broken loose, but a few I had to use the allen key on it the whole time (and of course, the harder to reach ones). Putting the intercooler in and then reinstalling everything, the front retaining clip was not wanting to go on all the way. I finally got it on, but I had to push the retaining clip, pull up on the SC, and screw in the bolt. Yes The IC nipple was completely in and the o rings were fine, and it was installed straight. Just figured i'd make mention. |
#2676 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
IMO get yourself the garden type clamps as mentioned, work well.
The clips you show, was for the pipes onto the radiator, the kit still supplied the clamps as in whataboutbob's picture. Don't forget the coolant takes around 15 minutes to pump through, so keep squeezing the pipe to the front of the cooler to push out air bubbles. |
#2677 | |
I got 6 of the larger ones, then 2 smaller ones, and another set of 2 small ones. Guess I'll grab some worm clamps though I don't want to.. lol. Thanks for the tip on the coolant. I didn't realize that one coolant hose (the top line off the radiator) has to be squeezed through a very small area between the ac condenser. |
#2678 |
Also, as recommended by I believe Bob, I checked my oil level when I had the supercharger on my work bench.
Didn't even register any gear oil on the dipstick. I highly suggest everyone keep an eye out on their oil level. I only have about 9k on my kit IIRC. Can't remember if I installed it at 15k or 18k lol |
| The Following User Says Thank You to xxscaxx For This Useful Post: | whataboutbob (01-15-2014) |
#2679 | |
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#2680 |
Yeah I know. Just was taken back how little oil there was in it, and Sprintex calls for a 30k service, and i'm not even at the halfway point of that.
I'm still bent out of shape about these stupid clamps. LOL |
#2681 |
First things first. FT86club, if you ever go down again...
I don't know who you are, but I will find you, and I will kill you. back on topic. all the larger 26mm clamps provided in my innovate kit didn't fit. I had to buy 6 new worm drive clamps (ugh) to replace them with. I'm going to call up Innovate again and let them know. I don't like using the typical hose clamp because they dig into the damn lines. Unfortunately I had to buy these since its all I could find local and had to get my car up and running again, and I won't be changing them to the pressure clamps like they provided even if I got a set because that means unhooking all the lines which I'm definitely not about to do (I hate coolant..lol). Also, the smaller hose that goes from the coolant bottle to the top fitting on the heat exchanger is not the correct size. I got it on, but theres no way in hell its suppose to go on as tight as it did. I was nervous I was going to break the plastic fitting. I had to grease up the fitting to even get it on. Getting the air out of the system was a giant PITA. It took me over an hour to get it out. Luckily Innovate gives us how much coolant needs to go in the system because I would have thought it was filled numerous times lol. Work all the hoses, not just the front one, and when you can't get any more air out, turn the ignition to on and let the pump run and keep squeezing, that seemed to help a lot at the end. I should be getting tuned soon so I can't wait to see what I make on the 70mm pulley and most likely flex fuel. |
| The Following User Says Thank You to xxscaxx For This Useful Post: | shaunsweeney (01-15-2014) |
#2682 | |
Road Warrior
what did I say about air in the coolant..... Glad you on Does Innovate send you a 70mm pulley for the IC? Or you putting your own. |
#2683 | |
Drives: 86
Did Innovate have the idler pulley in stock? I screwed up big time tonight. I received a new bearing, which I was going to replace the squeaky one with. I tried popping the bearing out with a press, not realizing the bearing is recessed...held in by a lip on both sides. Unfortunately, I snapped the pulley in half! ![]() I'm not happy with myself right now. I leave Sat for a track event on Sunday. I'm REALLY hoping Innovate has these in stock, so I can request a next day air shipment. So, back to my question, does Innovate stock these? If they don't, does anyone else have them? Infamous? Anyone in the SoCal area willing to sell me one?? Thanks! |
#2684 | |
yeah it was a bitch thats for sure. I knew it would be a pain but I didn't think it was going to be that bad lol. No I upgraded to the 70mm a while back. Its already on, been on there for a while now. |
#2685 |
Road Warrior
I should have the 72.5 and 70mm Racseend pulleys here next week, want to check what difference they make.
Trying to establish what is safe boost on this kit, anyone know?.. |
#2686 |
Grip>Slip
installing the IC kit this weekend with @civicdrivr and possibly @Willsonk
| The Following User Says Thank You to xjohnx For This Useful Post: | civicdrivr (01-16-2014) |
#2687 | ||
The 70mm pulley increases boost to 11.5 psi The 72.5mm pulley increases boost to 10 psi 70mm is basically pushing this charger to the limit. Quote:
| The Following User Says Thank You to xxscaxx For This Useful Post: | whataboutbob (01-16-2014) |
#2688 |
Road Warrior
That's why I'm wondering if you have actually tested your boost with 70mm with the IC kit you may find you get more boost. Kits are the same so I not sure why I would get 12 psi and you 8 psi with a 75mm
I'm getting .7 bar 12 psi on 75mm Hence I want to do the trial to see what I get with the smaller pulleys and do it on the dyno to see the gains achieved. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
