#15 |
Drives: Attitude
It's a flat engine, it *will* have oil starvation issues in high-g lateral loading.
| The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post: | PoorMansRacing (01-28-2014), ZionsWrath (01-14-2014) |
#16 | |
That Guy
Drives: 2013 asphalt FRS MT
I'm not completely sure, but in hudraulics the oil in the pan and the drain are both at atmospheric pressure. Following that, as long as the turbo is mounted above the drain that shouldn't be an issue. |
| The Following User Says Thank You to Calum For This Useful Post: | ZionsWrath (01-14-2014) |
#17 | |
Drives: AE86, 2x GT86, TE27
The TR86 race cars had the same problem during development. TRNZ developed a few prototypes before coming up with a pan and pickup modification. THey're going to release it to the market soon. I'm trying to decide whether to get that, or do a drysump. Buddy of mine has his own fab business, and wants to do a whole drysump/subframe setup for me, then offer it to the market. Heres a pic of his own setup for his sti drift car. ![]() ![]()
| The Following 3 Users Say Thank You to diss7 For This Useful Post: |
#18 | ||
Drives: Subaru BRZ, Toyota MR2 Turbo
| The Following 6 Users Say Thank You to Jeff@Racer X Fab For This Useful Post: | B L U E S L A T E (01-28-2014), bakerr6 (01-14-2014), Calum (01-14-2014), normancw (01-14-2014), The Slow One (01-14-2014), ZionsWrath (01-14-2014) |
#19 |
Drives: 2013 raven black fr-s
Send me a pm when you get this finished. If it's around that area, go ahead and send me an invoice while you are at it lol.
| The Following User Says Thank You to bakerr6 For This Useful Post: | ZionsWrath (01-14-2014) |
#20 |
Drives: Attitude
Subaru dry sump setups are mad money - even on NASIOC you rarely ever hear about it because it costs over ~$5K USD to do properly AND the parts development is mum/hush-hush/all custom. Typically race car only stuff.
#22 |
Because compromise ®
Drives: Red Herring
Would someone be so kind as to tell me what these two holes are for?
#23 |
| The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post: | Captain Snooze (01-14-2014) |
#24 |
You're right. Just look at the parts, before any custom work is done. Pump, good fitting and lines, tank, there's $3k right there.
#25 |
Oil pan update
Looks like we are wrapping up a final design, and have built a few prototypes that we were not happy with. This oil pan will work with the OEM manifold, and should be compatible with aftermarket exhaust manifolds. We will offer an incentive once the final product is released for those that are interested.
The final design resembles the OEM pan with a few exceptions. Increased capacity, turbo oil drain port (can be plugged), baffle plate that captures oil by the pick up, and uses an o-ring seal on the flange. Here are a few pictures of the design. I will post up the actual pan hopefully later today. ![]() ![]()
| The Following 4 Users Say Thank You to Jeff@Racer X Fab For This Useful Post: |
#26 |
#27 |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I would love to run a larger oil pan, but my class in the SCCA doesn't allow for a modified windage tray or pickup. I'm assuming yours has a new windage tray
#28 |
Drives: 2015 WRX
| Racer X Fabrication air intake design and development! | Jeff@Racer X Fab | Engine, Exhaust, Transmission | 45 | 08-01-2019 12:29 PM |
| Racer X Fabrication suspension parts, and development | Jeff@Racer X Fab | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 134 | 09-01-2016 05:02 AM |
| Racer X Fabrication Suspension group buy: UCA, Rear LCA, Front LCA and more!! | Jeff@Racer X Fab | Groupbuys | 74 | 06-23-2014 09:08 AM |
| Racer X Fabrication: Upper rear control arms, in stock/ready to ship!! | Jeff@Racer X Fab | Brakes, Suspension, Chassis | 25 | 01-24-2014 11:42 AM |
| Racer X Fabrication, New vendor intro | Jeff@Racer X Fab | Announcements, Contests, Giveaways | 0 | 03-12-2013 11:50 AM |
