Old 11-07-2013, 05:51 PM   #43
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
Originally Posted by NewR View Post
Thank you! Got your PM and email.
Need to do more Youtube search on this system for more sound samples.
Would you say that the non-resonated is more "raspy" than the resonated setup?
It definitely is raspier especially so if you are planning on doing a header, overpipe and midpipe later. Resonated has a deeper tone for sure.
PrimeMotoring is offline   Reply With Quote
Old 12-04-2013, 01:15 AM   #44
1BadFA20
Drives: '92 GS-R, '02 RSX-S, '14 BRZ
I just installed the 3 inch front pipe catted and 3 inch resonated catback.
I'll say this, I've had Hondas all my life and my share of exhausts to go with. But the sound this car makes with the Perrin parts installed is EXACTLY what I was looking for. It's got a deeper tone on start up. Once warmed up sounds damn near like stock. Giving just a bit of gas makes it rumble. No highway drove, no turning the radio up to drown it out, no raspiness, no fat can or tin can sounds. I can lay into it and carry on a conversation as if nothing. I mean I am extremely pleased with these parts. I can't wait to turbo it and make it a sleeper beast!!!!!
1BadFA20 is offline   Reply With Quote
The Following User Says Thank You to 1BadFA20 For This Useful Post:
flippy (01-28-2014)
Old 12-27-2013, 06:45 AM   #45
JohnAyySays
JohnAyySays's Avatar
Drives: Scion FR-S Whiteout
Was wondering if you could post some sound clips?(:
JohnAyySays is offline   Reply With Quote
The Following User Says Thank You to JohnAyySays For This Useful Post:
Urmyson (12-27-2013)
Old 12-28-2013, 11:21 PM   #46
John92
Drives: White scion frs
[ame]http://youtu.be/MkdkAUdDHds[/ame]
here you go, all the setups I've run ill post some drive bye videos later on.
John92 is offline   Reply With Quote
The Following User Says Thank You to John92 For This Useful Post:
ramiram1984 (12-28-2013)
Old 01-14-2014, 01:33 AM   #47
NinjaRxMan
NinjaRxMan's Avatar
Installed the 3 inch exhaust over the weekend and WOW does it sound great! Install wasn't too bad...did it by myself. Probably would have taken less time if there was a second person helping. Perrin does make a great quality product and I am glad i chose this vs their 2.5 inch exhaust.
Old 01-14-2014, 01:40 AM   #48
NinjaRxMan
NinjaRxMan's Avatar
Sent from my SGH-T999
Old 01-16-2014, 09:00 AM   #49
Batspeed
Drives: Toyota 86 GTS
installed one too
hi, I also installed a perrin 3 inch resonated cat back on the 14 January. My install took 2.5 hours with the extra time spent trying to align the rear tips. I was concerned with the mid pipe touching the wall of the chassis transmission tunnel, but i think Perrin has revised their design slightly because there is now ample clearance.
How does it sound? when i first started it up, I thought it was too loud, Now after 2 days of use, I've gotten use to it and think its about the right volume. Its sounds really deep, and mixed with the slightly raspy midrange sound piped from the engine, its a great tonal combination. Its a refined rumble.
For those deciding between the 2.5 and the 3 inch, i recomend go the 3 inch.
Batspeed is offline   Reply With Quote
The Following 2 Users Say Thank You to Batspeed For This Useful Post:
Boom (01-16-2014), flippy (01-28-2014)
Old 01-16-2014, 03:14 PM   #50
Bitbang
Drives: 2013 FR-S Series10 6M/T
How much would a Resonated 3inch shipped to 92126 be?
Bitbang is offline   Reply With Quote
Old 01-28-2014, 02:32 PM   #51
Batspeed
January 28 update - With approximately 2 weeks of use (500kms), I believe the exhaust has gone quieter by maybe 15%. I am noticing more of the mid range tone from the engine. Daniel at car mods Australia whom I purchased from did mention that the sound does settle down after a couple of hundred kms as carbon starts to coat the inner surfaces. At first I thought I would not want it any louder by changiing other exhaust components, but now I'm wondereing if I should also change the front pipe to hiflow catted front pipe...... but since I do not yet intend to retune the ECU, its hard to justify the additional spend for a bit more sound with little performance gain,cause it does sound pretty great at the moment, even better with the windows wound down..., the perrin 3 inch makes driving so much more enjoyable...
The Following User Says Thank You to Batspeed For This Useful Post:
flippy (01-28-2014)
Old 01-28-2014, 03:19 PM   #52
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
I'm not sure if this was a question meant for us or not, but if it was, please shoot us a PM and we can go from there.
PERRIN_Mladen is offline   Reply With Quote
Old 02-04-2014, 04:51 AM   #53
Bongertz
Drives: Brz
nice pictures sir do you think the 3" exhaust alone taken out of it box would fit in a 20x20x20 box? im shipping it to the philippines. i can't figure out a cost effective way and i dont know if itll fit. :/
Bongertz is offline   Reply With Quote
Old 02-04-2014, 03:30 PM   #54
NinjaRxMan
NinjaRxMan's Avatar
Sorry, I don't think it would fit. The dimension of the box was 44.5x24x12. I did a measurement of the exhaust from tail tip to tail tip and that was already ~40". I would recommend the box that was packaged by perrin. It was well package and protected all the parts. Good luck!
Old 02-04-2014, 03:40 PM   #55
PERRIN_Mladen
Drives: '11 535i
We do ship internationally, so that may save you some cost.
http://perrinperformance.com/p-14308....html#int_form
Hope that helps.
Old 02-11-2014, 02:13 AM   #56
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Originally Posted by Drift-Office View Post
THere's no reason to run a 3 inch exhaust on a NA car - generally, you'll loose torque and it's a louder exhaust note. I prefer to see at least a 3 inch in FI environments since most of the FP / OP offerings are still 2.5 inch to ensure crossmember clearance, etc etc...
Bob @ Drift-Office, LLC
I dont believe this is a universally true statement.
TouchMyHonda is offline   Reply With Quote
The Following User Says Thank You to TouchMyHonda For This Useful Post:
Drift-Office (02-11-2014)
Perrin 3" Catback Exhaust Group Buy!! Check it out!! Mike@CZP Groupbuys 1190 06-01-2018 01:27 PM
PERRIN Big 3" Catback DAN_BRZ Engine, Exhaust, Transmission 95 04-28-2014 07:19 PM
Perrin 3" catback exhaust - impression DarkestBuddha Engine, Exhaust, Transmission 21 09-11-2013 02:54 PM
Perrin 2.5" Non Res Catback Pudge Ate Me Engine, Exhaust, Transmission 8 06-08-2013 02:11 AM
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 10:47 PM
