Old 01-09-2014, 09:39 AM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I wanted to update I resolved my issues with the CEL P0301.
The closed loop/open loop transition in my car while running E85 was EXTREMELY rich, (AFR went down to 9) and this caused a misfire condition.
I asked my tuner to lean out the transition and now it only goes down to about 10.2, no more CEL.
This happened a few months ago but randomly saw this thread and wanted to let everyone know that may be your cause.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
GhostOp86 (11-08-2016), Muskokan (01-09-2014)
Old 01-09-2014, 10:07 AM   #16
s2d4
s2d4's Avatar
Was it in open loop or was it in close loop? Not entire sure what you mean by transition because it is either in close or open? or was the target/MAF scale incorrect?
Looks like plenty of guys have had this after a tune, they either get it replaced under warranty and someone bought aftermarket coilpacks and spark plugs instead...
Old 01-09-2014, 10:23 AM   #17
Sportsguy83
Drives: Limited BRZ
While cruising the car is in closed loop. When certain conditions are met (e.g certain load value, certain requested torque value, etc.) the ECU transitions from closed loop to open loop. That instant where the transition happened, the AFR would drop from 14.7 cruising to 9. It only happened in 6th gear (heavy engine load), and didn't need to go WOT, just partial throttle. So to answer your question, it was the instant it entered open loop.
GhostOp86 (11-08-2016), s2d4 (01-09-2014)
Old 01-09-2014, 10:28 AM   #18
s2d4
s2d4's Avatar
I thought it was load or throttle position.
Interesting, do you know what he did to fix the issue?
Old 01-09-2014, 10:35 AM   #19
Sportsguy83
Drives: Limited BRZ
It might be only load or throttle position, I don't remember.
Honestly don't know exactly what he did, but I requested specifically to lean it out when it entered open loop. The tune stayed the same (meaning the conditions/situation to enter open loop stayed the same), but now instead of dropping to the 9's, it stayed on the 10's.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 01-09-2014, 10:42 AM   #20
s2d4
s2d4's Avatar
Maybe @mad_sb and @jamesm would have some experience with this and how they would deal with it.
The Following User Says Thank You to s2d4 For This Useful Post:
Sportsguy83 (01-09-2014)
Old 01-09-2014, 10:52 AM   #21
s2d4
s2d4's Avatar
I think you have bigger port injectors? The scaling, duty cycle plus DI vs Port could have been an issue as neither of mad_sb or jamesm were keen on changing open loop fueling targets to fix stuff... Both of their reasonings were very sound.
lol, one of them basically implied a tuner was a crack head for using that method.
Old 01-09-2014, 11:00 AM   #22
jamesm
if you're seeing huge swings in afr coming out of closed loop it's very likely to due a mismatch is fueling error between port and direct injection. or just bad maf scaling around 2.9-3.2v, as this area is pretty hard to nail down. i'd have to see a log or ask more questions to know for sure, but that would be my first guess.
The Following User Says Thank You to jamesm For This Useful Post:
Old 01-09-2014, 01:49 PM   #23
Sportsguy83
Drives: Limited BRZ
At this point it doesn't matter anymore. I will get a new, different soon.
CEL P0301 C1201 and U0100 peachch Issues | Warranty | Recalls / TSB 32 12-21-2013 05:37 PM
I got this today. slidethis Issues | Warranty | Recalls / TSB 3 01-19-2013 05:12 AM
Got My FR-S TODAY!! DatDudeLoso Scion FR-S / Toyota 86 GT86 General Forum 7 06-18-2012 04:09 PM
