| Northwest AK, ID, OR, WA |
#15 |
Drives: 1990 BNR32 GTR
Well, that's what I'm trying to figure out. I've never done something like this before. Do I install everything and then get an alignment done? I think I might YOLO (sorry) and go for the Ohlins and Perrin 19mm front with either the 19mm rear or 22mm rear sway bars. Also going to try to get the camber plates refinished in red....
Probably use the Perrin endlinks? the ones that come with the Ohlins? I'm not sure. @DarrenDriven I'd love help installing these from someone who's done it before, I don't care his age.
#16 | |
Drives: fr-s
#17 |
Anywhere Specifically?
Probably doing install at Darrens, so somewhere close would be good.
#18 |
Drives: 2013 Whiteout FRS
PRE Racing is about 7.5 mi from his house
#19 |
Perfect. I'll start buying shit then. Anyone using the Perrin Sway's? I know @Chen is, but he said the 19mm/22mm makes his car really tail happy.
#20 | |
Regional Moderator
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
#21 |
Do you have the machined ones or the adjustable ones?
#22 |
Boosted Member
Drives: 2013 SWP BRZ Limited
http://www.ft86club.com/forums/showthread.php?t=34814
This is what I will be getting with my ST coils if I go that route. Caster and camber adjustment, and it looks badass. They will custom make it for any coils for no additional cost.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#23 |
Drives: 2013 Subaru BRZ
I am rocking AMR Engineering Coilovers, local in Vancouver WA. Love them.
Also rocking the Perrin F/R Sway and F/R End Links with the 1 Piece Machined front end link. Car is very stable and planted. If the rear is going to come out its very predictable and controllable.
#24 | |
Drives: fr-s
What's the cost on the AMR's? What are the spring rates? Are they fully adjustable? |
#25 |
Regional Moderator
#26 |
Drives: Raven FR-S
Check out the MSI top hats at rallysport direct. The company makes both front and rear adjustable top hats. I installed the front ones and will eventually install the rears.
http://www.rallysportdirect.com/MSI-...t-Upper-Mounts http://www.rallysportdirect.com/MSI-...r-Upper-Mounts |
#27 |
Junior
Drives: a car
Thought this is the proper place to put this question...
I'm having a tough time deciding between the ST coils and KW V1 coils, basically is the mucho extra bucks worth the SS on the KW? or does the PNW (specifically Seattle) not get enough snow --> then salt for the need of stainless steel?
#28 | |
Drives: 2014 BRZ SWP LTD
| How should i lower :( | Obja | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 06-15-2014 01:39 PM |
| Want to lower my FR-S where can I go? | laley81 | Southern California | 16 | 08-22-2013 08:05 PM |
| I want it lower !! | Ndgreely | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 07-13-2013 12:10 AM |
| How can I go lower? | nab335 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 07-08-2013 04:15 PM |
| Lower the seats? | MrMista | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 04-19-2013 08:41 PM |
