Old 01-04-2014, 11:14 PM   #785
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by jamesm View Post
if you're on pump gas and the only thing you've changed is related to the intake (the filter and trimmed snorkel) then it would be reasonable to adjust the maf, it just doesn't make sense that it would require an across-the-board correction like that unless the diameter changed, which i don't believe it has given your description. typically any changes introduced by something like a filter or altering the airbox would look more like turbulence, less like global correction.
you are on pump gas, correct? i'd recommend going back to stock maf scaling and creating a proper fueling error chart from at least 30k rows of data, just to see where you really are now. there is very little to learn from looking at trims in the log without applying some math and making the data more reasonable to interpret. in fact you can be led very far in the wrong direction by just looking at raw logs without filtering and processing.
once you have good reliable data to go on, you'll see if changes are necessary and know (pretty much) exactly what to do to fix it.
You totally lost me at "30k rows." If you have a link or source on how to do this and what's required I would greatly appreciate it.
Here is an earlier log I took with the unmodified v1.42b tune:
http://www.datazap.me/u/solidone/91-...2-3-4-7-8-9-10
If you zoom in on the first spike in rpm to red line you will see the LTFT at +12.5%~17.19%
Here's after I modified the MAF scale:
http://www.datazap.me/u/solidone/maf...2-3-9-10-11-12
I understand that looking at fuel trims and adjusting one parameter is probably not the best way or the right way, but it produced good result. Stays on the target AFR's without much or any correction by the ECU. I've worked on cars for a while, but am an total noob when it comes to electronic engine management. Closest to "tuning" fuel and ignition I've done is rejetting carbs and installing woodruff key to advance timing or making a car pass CA smog test. I need to get schooled in this stuff. It's all mumbo jumbo to me right now.
Old 01-05-2014, 12:19 AM   #786
jamesm
http://www.ft86club.com/forums/showthread.php?t=53773
just ignore all of the stuff about port/di ratios. looking at your log it looks to be much improved, but it'll be a lot easier to tell with the data formatted in a more friendly way.
The Following User Says Thank You to jamesm For This Useful Post:
solidONE (01-05-2014)
Old 01-05-2014, 02:31 AM   #787
jeebus
Originally Posted by s2d4 View Post
This doesn't sound like scaling but more like a multiplier/gain?
perhaps due to the catless FP?
I have a catless fp too and my logs look similar to other stock cars and I've had no issues with ltft.
jeebus is offline   Reply With Quote
Old 01-05-2014, 05:55 PM   #788
solidONE
solidONE's Avatar
You, sir, are a gentleman and a scholar. Too bad I could not get the excel file to work.. lol I don't think this works with portable excel app.
The Following User Says Thank You to solidONE For This Useful Post:
jamesm (01-05-2014)
Old 01-05-2014, 05:55 PM   #789
solidONE
solidONE's Avatar
What intake mods do you have and what fuel are you running? 93 or 91?
Old 01-05-2014, 07:03 PM   #790
jamesm
no you'll need the full desktop version of excel. if you don't have that, let me know and i may have some alternatives (particularly if you're on a mac).
solidONE (01-06-2014)
Old 01-06-2014, 12:24 AM   #791
solidONE
solidONE's Avatar
Will install the desktop version and try again.
Here's a graph screenshot of the original maf scale compared to my modified maf scale:
No lumps or bumps anywhere.
Old 01-06-2014, 12:40 AM   #792
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Just curious and sorry if it's already been answered before, but what modifications are you running?
-shiv
Shiv@Openflash is offline   Reply With Quote
Old 01-06-2014, 01:45 AM   #793
solidONE
solidONE's Avatar
Yup catless J2 front pipe, aFe drop in filter, and trimmed snorkel. All else stock with a 1.42b stg 1 OFT tune.
I did keep a bit more material on the snorkel than shiv and others. Although I'm sure that's not going to change much.
-shiv
Since I've been doing this after work the ambient temps seems to be lower when I took the logs. I think the new scaling threw the temp compensation off a little as it runs a little leaner during the day vs night time.
Aside from the stuff below everything else is stock.
This filter:
http://afepower.com/shop/details_new...as&&brandID=59
This front pipe that now cost US $1,109.99 lol:
http://www.ebay.com/itm/J2-Racing-Sp...591119&vxp=mtr
And what I did with the snorkel:
Old 01-06-2014, 01:15 PM   #794
jeebus
My snorkel has been trimmed, running a K&N, and I'm on 91. I had no issues with the tune before or after my snorkel was trimmed either.
Old 01-06-2014, 10:35 PM   #795
jeebus
I haven't logged in a bit. Decided to take a look today and WTF my AM was at .5? I managed to get it up to .7 but by the end of my drive it was at .2....bad gas??
Old 01-06-2014, 10:54 PM   #796
solidONE
solidONE's Avatar
LTFT takes time settle in, so if you took your last log right after reflashing your LTFT will not be as high as it should and your STFT will reflect this. Unless the new rom you flashed was close to being ideal then there will not be much correction.
Also I noticed during low rpm range and high load, such as lugging your car up a hill in too high a gear, you will more likely see your IAM get cut down. Specially if your fuel map is off (indicated by wildly fluctuating or really high STFT)
What is the diameter of your cat-deleted front pipe? Brand?
Old 01-06-2014, 11:06 PM   #797
solidONE
solidONE's Avatar
Will this excel app work without intake air temps? OFT does not have IAT logging capabilities yet. Hope to see this added soon, along with option to display selected inputs like a gauge(s) with larger high visible readouts.
Old 01-07-2014, 12:48 AM   #798
jeebus
My ltft is at around 2...noshing crazy.. And my stft doesn't wildly fluctuate. Front pipe is Berk. 2.5"
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
