Old 01-05-2014, 06:53 PM   #449
MrMarinakos
Drives: Asphalt Monogram Fr-s
So continuing on to my last post (i would do an edit but i also have a question in this one)
I got the 2000 grit wet sand paper- wet it down and sanded my tail lights very smooth and soft and it came out to be a haze dull look to it (pretty sure it happened to everyone)
but then i apply 5 clear coats (30mins to an hour between each) and it looked decent but pretty dull.
So i wet sanded again and then used meguirs UC to polish it(maybe it was a little soon but i waited a day to do this)
And i applied it and buffed it out several times for each tail light trying to get it more glossy but it still seems sort of dull. Any help?
Pictures:
MrMarinakos is offline   Reply With Quote
Old 01-05-2014, 09:27 PM   #450
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
@MrMarinakos it seems like you are rushing it! If you're wet sanding it should be on a paint that has completely cured. For most clears that means a Minimum of 12 to 24 hours in a hot/dry environment.
headlikeahole is offline   Reply With Quote
Old 01-05-2014, 09:28 PM   #451
MrMarinakos
should i wait another day and do it again and then polish?
Old 01-05-2014, 11:16 PM   #452
headlikeahole
That depends how much clear coat you have on there already. If its thick enough you could probably wait and simply restart the polishing process with better results.
Old 01-05-2014, 11:26 PM   #453
MrMarinakos
5 clear coats, but would you suggest sanding it again then polishing or just polish a couple more times?
Old 01-06-2014, 12:22 AM   #454
headlikeahole
Polish could be enough to get the look you want but it might take quite a few passes to get the level of shine you want. Its hard to tell from the pictures just what is required.
Old 01-13-2014, 12:33 AM   #455
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Can't remember how many coats, somewhere around 5 or so. 3 coats of clear coat. A few pitted spots and one or two fish eyes but they're crystal clear and I'm super happy with them
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 02-11-2014, 08:00 PM   #456
frsgal
frsgal's Avatar
Drives: 2014 FRS, Ultramarine Blue!
Thanks for this guide...I'm going to redout my Ultramarine's taillights. Far less intimidating than I thought. :]
frsgal is offline   Reply With Quote
Old 07-11-2014, 11:27 AM   #457
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
Originally Posted by Ric0 View Post
If anyone is debating doing this have no fear! If I can do it so can you
Steps on how I did mine.
1) clean tails and make sure you mask everything off
2) VERY light 1st coat of Dupli-Color Metalcast anodized red
3) after 15-20mins another light coat of paint (repeat this step 3-4 more times)
At this point you might be taking shit as the lamp may look dull and you can't see thru it.
4) Using 2000 grit sand paper wet sand it with soap until it's smooth (becareful you don't over do it, if you do... paint, wait to dry and wet sand again lightly)
5) VERY light coat of clear (I used Dupli-Color acrylic enamel clear coat)
6) after 15-20mins another coat of clear (repeat these steps 3-4 more times)
7) Wet sand with soap, don't over do it just enough to get rid of the orange peel
8) Rubbing compound (removes scratched from wet sanding)
9) Polish (gets it's smooth and almost shining)
10) wax the crap out of it to bring out the shine.
looks good... may tackle this over the weekend... couple of quick questions...
1. Would you recommend sanding with 2000 grit before the 1st coat of red is applied?
2. When you wet sand, are you going left to right or up and down, or both ways... sorry... if this is a stupid question
3. Where can I purchase Dupli-Color locally? Home depot, Napa...?
Vortech SC V3 // 3.12 Pulley // Moto-East Tune (93oct,e40-50,e85)
sissupr is offline   Reply With Quote
Old 07-12-2014, 12:36 PM   #458
Ric0
Drives: 2013 Subaru BRZ SSM
@sissupr
1 I didn't incase I messed up I could use alcohol to undo it but you can.
2 I just did it from side to side, some areas I had to do up and down, just don't over do the corners cause it might remove the paint and you'll have to re do it.
3 I purchased the paint at advance but most of these store carry it.
Note, since that pic Ive redone it twice cause the clear wouldn't hold and it would fade, painted it 3rd time and had prof cleared $40. Photobucket messes up the resolution, tails are as clear as oem.
Ric0 is offline   Reply With Quote
Old 07-12-2014, 12:49 PM   #459
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I got duplicolor metalcast and spraymax2k off Amazon. The spraymax is an awesome clearcoat
B-R-Z is offline   Reply With Quote
Old 07-12-2014, 01:20 PM   #460
B-R-Z
B-R-Z's Avatar
@sissupr I sanded before painting red. You need the surface to have something to stick to. Sanding direction really doesnt matter here, I sanded every which way.
People I've showed were surprised it was a DIY job. I highly recommend spray max 2k if you are going to do clear yourself.
Old 07-14-2014, 12:38 PM   #461
vroom4
vroom4 is offline   Reply With Quote
Old 07-16-2014, 10:56 AM   #462
sissupr
sissupr's Avatar
Here's what I got... little hazy/dull on the inside to my liking, but overall really happy for $30 of materials and my time. I put about 6 coats on (little heavy I know), so I need to get clean up the red paint a bit to make it shine clearer. It doesn't have a clear coat yet because I sanded it off to clean up the red paint a bit more... All this has is red sanded down with 1500 and 2000 + sealant. I wanted to make sure it was heading down the right direction before I put clear coat on again. I'm going to hit it again with 1500 and 2000, polish it down with Meg UC or 105 with my XP7424, clean up with soapy water, add 3 layers or clear, let dry, wet sand again with 1500 and 2000, polish, and lastly sealant/wax.
[IMG]
[IMG]
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 10:02 AM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 02:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 03:30 PM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 07:20 PM
