Old 12-16-2013, 02:17 AM   #1
TheLaughingMan
TheLaughingMan's Avatar
High Pitched Noise, Engine Off
I don't think I've seen this one on here yet...
I had the car in the garage and turned the key to "ON" (but the engine wasn't running) and heard this high pitched noise coming from the engine bay. I opened up the hood and tried to bring my phone to the source. The pitch randomly changes and almost sounds strained at times. I thought maybe it was the fan for the radio/head unit, but it doesn't quite sound like it.
Thoughts?
I have ~950 miles
https://www.dropbox.com/s/hauyryk6kj...214_162428.mp4
TheLaughingMan is offline   Reply With Quote
Old 12-16-2013, 02:32 AM   #2
mike the snake
Fuel pump priming?
Old 12-16-2013, 02:35 AM   #3
TheLaughingMan
Originally Posted by mike the snake View Post
Fuel pump priming?
That kind of what I thought...but it sounded so strained and inconsistent.
Old 12-16-2013, 03:05 AM   #4
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Do you have HIDs installed?
Edit: After watching the video, it does not really sound like HID ballasts. Sorry man.
husker741 is offline   Reply With Quote
Old 12-16-2013, 03:08 AM   #5
TheLaughingMan
Negative. Stock everything.
Old 12-16-2013, 03:21 AM   #6
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Sounds like the electric motor in the throttle body, it holds the valve open during start up to idle high and get the catalytic converters lit off, normally with you in the car and hood down it blends in with the rest of the car preparing to start (power steering, power brakes, fuel pump etc.)
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Mr.EvoMR (01-04-2014), TheLaughingMan (12-16-2013)
Old 12-17-2013, 09:58 AM   #7
andrew20195
Drives: 2013 Subaru BRZ
I can't access the file at work, but it's most likely what strat said above. Subaru energizes their throttle motors anytime the key is on, and they are very noisy.
andrew20195 is offline   Reply With Quote
Old 12-17-2013, 10:48 AM   #8
BadMoon
BadMoon's Avatar
Drives: 2014 GLI Autobahn/Nav
My car does this as well. I'm pretty sure I read it's a system check. Its the computer turning on checking the pumps and stuff.
That's my version of the story because I don't know shit about cars. I just know it's checking something and normal. I just can't remember what.
*EDIT*
Here's what BRZ's manual says:
Noise from under vehicle after turning off the engine
Approximately five hours after the engine is turned off, you may hear sound
coming from under the vehicle for several minutes. This is the sound of a fuel
evaporation leakage check and, it does not indicate a malfunction.
BadMoon is offline   Reply With Quote
The Following User Says Thank You to BadMoon For This Useful Post:
Old 12-17-2013, 12:01 PM   #9
strat61caster
Originally Posted by BadMoon View Post
*EDIT*
That's a different sound, it's very clear the sound from the manual is coming from the rear of the car around the gas tank area, as noted several hours after the vehicle is turned off. OP's noise is clearly originating from the engine bay BEFORE the car is turned on with the key turned to the second stop.
ineedyourdiddly
Old 12-17-2013, 01:42 PM   #10
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
throttle body. normal
Old 01-04-2014, 06:25 PM   #11
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I only hear that when I leave the HIDs on after turning off the car (or turning them on without starting the engine). The high pitch sound goes away once I turn off the HIDs.
krayzie is offline   Reply With Quote
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 12:04 PM
Fuel Pump high pitch chirp noise lucius AFRICA 9 10-24-2013 03:40 PM
not very loud, but high pitched sound at 70+mph fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 16 10-16-2013 11:30 PM
High pitched whine from sound tube and idle jumping Nourdmrolnmt1 Issues | Warranty | Recalls / TSB 0 04-18-2013 12:00 AM
TSB - FRS (re: High pitched chirping...) PNW FRS Issues | Warranty | Recalls / TSB 1 01-19-2013 02:05 AM
