#197 | |
Drives: '24 GR86
I'm more than content with 350whp and could never see myself wanting anymore than that. If I did, I'd say 400-450whp MAX but that would be on E85 and as a strictly track only car.
#198 |
Drives: 2013 Raven FR-S
Looking forward to the riser install. Also, may I ask where you ordered them from?
#199 | |
Drives: '24 GR86
| The Following User Says Thank You to TylerLieberman For This Useful Post: | gk (01-03-2014) |
#200 |
Thanks and are you gonna get a shop to do the install or do it yourself?
#201 |
Drives: '24 GR86
Do it ourself. I have somebody who can weld. The rest is just a matter of dropping the subframe and putting it back in after everything is installed
#202 |
Sweet, thinking about doing this mod too. Would you mind taking pictures of the steps you take during the install?
#203 |
Drives: '24 GR86
I'll be overseas. A good friend will be doing it for me here. I'll ask him to take some pictures though
#204 |
Drives: '24 GR86
Installed the Stance LCA's and got an alignment today.
I installed the control arms and dropped the car and was sitting at this height: ![]() A bit too much for me seeing how the axle angle was extremely jacked up and there was still not much suspension travel. So, I raised the rears up by about half an inch and got to about the same ride height as before. ![]() After that, I went and drove it around and could tell that it was definitely off alignment so I went and got it taken care of. Unfortunately, the stock toe links are maxed out so the best I could do is -1.8 camber in the rear while still maintaining zero toe. So I'm going to get some SPL Titanium Rear Toe Links to help get the extra adjustment I need and I'll end up going back down to -1.5 camber with 0 toe again. So now the car is all good for me to drive around on until I leave. I can't wait to start getting everything ordered for the car. It's going to be amazing when I come back. In the meantime, I have a few parts that I'm going to be installing on my wife's car next weekend ('13 Focus ST). I'll post some pics of that I suppose
#205 |
Drives: '24 GR86
So this is how it sits now:
![]() I leave in a few days to the middle east and won't be back until around the end of the year. The car is pretty much just going to sit the entire time and I'll accumulate some things for it while I'm gone. That being said, this is gonna be the last update for this thread until around October time most likely. How much I post from here on out just depends on how much free time I have to **** around on the forums when I'm over there. Until then guys..
#206 |
Just a dude
Drives: Scion FR-S 2013
Good luck over there Tyler, till then cheers.
| The Following User Says Thank You to OICU812 For This Useful Post: | TylerLieberman (01-10-2014) |
#207 |
Drives: Scion FRS
Did you bypass the srs light when you installed the aftermarket steering wheel?
#208 | |
Drives: '24 GR86
Yeah. Just make sure everything is lined up within the steering hub/clockspring properly. You can also check out the SRS light delete DIY here on the forums. It's just a matter of putting a resistor into one of the plugs under the driver seat. Super easy.
#209 |
Drives: Scion FRS
Ok thanks. Super helpful
#210 |
TURBOLICIOUS
Drives: a machine :]
Nice build Tyler! Just sent you a message.
| KO's Raven FR-S Build: Name "Raven12s" | KO | Member's Car Journals | 3 | 07-18-2013 02:09 AM |
| WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 05:49 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
| Five Axis Spoiler - Painted "RAVEN" Black | that_guy | Canada Classifieds | 29 | 12-18-2012 08:34 AM |
