Old 01-04-2014, 08:31 AM   #1
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
6spd MT Can't shift into second with these cold temperatures
Hey guys, for those living in Canada or the northern parts of the US, are any of you having trouble shifting into 2nd or any gear while your car is cold/ warming up? Do you think this a big issue?
Wilso is offline   Reply With Quote
Old 01-04-2014, 08:35 AM   #2
z3ro
Mine does it in the morning, but in that case it's been sitting overnight as well.
I've taken it to the dealer before for this issue and was told "that's how the trans are built and it may or may not loosen up over time."
z3ro is offline   Reply With Quote
Old 01-04-2014, 09:26 AM   #3
Wilso
Hmmm.. Mine does it any time it's cold, so in the morning on the way to work, and then on my way home for lunch. I wonder if a change of fluid would make a difference?
Old 01-04-2014, 10:00 AM   #4
tuwey
tuwey's Avatar
Drives: focus svt
I also have have this problem. My focus SVT was like this also. I found that double clutching on the up shift works till the transmission warms up.
Hope this helps till spring.
tuwey is offline   Reply With Quote
The Following User Says Thank You to tuwey For This Useful Post:
Mr.EvoMR (01-04-2014)
Old 01-04-2014, 10:01 AM   #5
Muskokan
Drives: white Sport-tech
Same here, I find if you really firmly throw it in like your bitch it helps, but even then i sometimes hit a wall of resistance, 2nd try works all the time half the time.
Muskokan is offline   Reply With Quote
Old 01-04-2014, 10:10 AM   #6
Norton 850
The "hard" shift from 1st to 2nd in cold weather is a common problem with the Aisin gear boxes that are installed in the FRS and BRZ. Unfortunately, there's no known cure for this nagging and, in my mind, unacceptable fault.
However, draining and filling the gear box with Redline 75W 85 gear oil will make a HUGE difference. Some people have even reported that it "cured" there shifting problems.
Hope this helps.
Norton 850 is offline   Reply With Quote
Old 01-04-2014, 10:30 AM   #7
jvincent
jvincent's Avatar
My shift into 2nd was notchy like everyone else but about a week or so before Christmas it started to get better and since then it has been much better.
I've got about 10K km on the odometer.
Old 01-04-2014, 10:38 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
Double clutch. I also get resistance going into first from stops when cold. Double clutch makes it much less noticeable or.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Wilso (01-04-2014)
Old 01-04-2014, 10:52 AM   #9
toeout
I switched to Redline MTL but still couldn't shift into 2nd on cold (relatively speaking, I'm TN ) mornings. Then I started shifting into 2nd at 3000 rpm, and goes in every time.
toeout is offline   Reply With Quote
The Following 2 Users Say Thank You to toeout For This Useful Post:
FRiSson (01-25-2014), Wilso (01-04-2014)
Old 01-04-2014, 11:13 AM   #10
Foobar
SLO NO MO
Foobar's Avatar
Double-clutch and/or throw the gear into neutral first before going into second (let the shifter go into the center of the pattern instead of going straight down from 1 to 2).
The Following 2 Users Say Thank You to Foobar For This Useful Post:
Mr.EvoMR (01-04-2014), Wilso (01-04-2014)
Old 01-04-2014, 11:32 AM   #11
imanedrn
imanedrn's Avatar
Drives: 2014 Subaru BRZ Ltd M/T WRB
Mine too. "Cold" mornings in Las Vegas - less than 50ush degrees. Double clutching works for me as well. She's real sensitive to preferred revs when cold. But I've had this happen on other older cars too, so it didn't worry me.
imanedrn is offline   Reply With Quote
Old 01-04-2014, 11:34 AM   #12
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Yes and no. It happens and it isn't a big issue.
You need a firm shift from 1 to 2 as the gearbox warms up. Only the first few shifts should baulk. After a km or two the synchros warm up.
Shift quality should get much better as miles build up on the gearbox.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
Wilso (01-04-2014)
Old 01-04-2014, 11:41 AM   #13
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
I wish that was our coldest weather, been -30C recently, that's -22F for those of you south of the border.
But on topic, I have experienced the same issue. Double clutching saves the tranny until warmed up, but it's still time for a fluid change to synth.
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
Wilso (01-04-2014)
Old 01-04-2014, 01:00 PM   #14
puravida
Drives: 14 brz, 97 nsx, 85 land cruiser
mine does it as well . . . and its not that cold here . . . noticeable improvement after car warms up.
puravida is offline   Reply With Quote
How To Take Tire Temperatures? Captain Snooze Tracking / Autocross / HPDE / Drifting 2 05-22-2013 11:05 AM
LF> OEM 6spd M/T Shift Knob in black leather hadezboy Interior Parts (Incl. Lighting) 0 03-29-2013 04:30 PM
WTB: OE FRS/BRZ 6SPD Shift Knob lexus005 Interior Parts (Incl. Lighting) 23 03-24-2013 07:26 PM
Sprint Rotor Temperatures Captain Snooze Tracking / Autocross / HPDE / Drifting 2 12-19-2012 12:59 PM
Cold transmission hard to shift from 1st to 2nd neutral Scion FR-S / Toyota 86 GT86 General Forum 9 08-08-2012 02:24 PM
