Old 01-04-2014, 01:58 AM   #1
Hardpack
Drives: Raven black FR-S
Plasti Dip emblems
So later this week when I get my badges in from Toyota, the plan is to head over to Home Depot or Lowes and pick up some red plasti dip and prep the emblems so I can take the old ones off and stick the new ones on all in one go.
Question is, which is better... spray on, or liquid? The spray on looks like it takes FOREVER to cure, and I have to do 4-6 coats, whereas the liquid looks like 2-3 dips and you're good to go. Anyone have any experience with this as far as prep work / use / satisfaction and which they prefer.
Hardpack is offline   Reply With Quote
Old 01-04-2014, 02:21 AM   #2
RojerLockless
RojerLockless's Avatar
Drives: Raven Fr-s
Yes
RojerLockless is offline   Reply With Quote
Old 01-04-2014, 09:49 AM   #3
z3ro
So I have some recent experience with the spray and lemme tell you, it's a bitch. If you go that route make sure the cans are warm and make sure you shake the shit outta them. Then keep shaking. Then shake some more. You cannot shake them enough. And when you spray, spray closer then you think. 4-6 inches.
z3ro is offline   Reply With Quote
Old 01-04-2014, 08:27 PM   #4
ktech
Drives: '13 BRZ Ltd, 6MT
For your purpose the dip seems better - if you had a larger surface to cover, I'd suggest an airbrush application. Rattle can paint in general sucks compared to professional style airbrush application; I can't imagine rattle can plasti-dip is any good.
That said, I'm biased - I know a guy who works for a paint distributor, so I have occasional access to their test lab, complete with $$$ spray guns and a booth...
ktech is offline   Reply With Quote
Old 01-04-2014, 08:42 PM   #5
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
use spray. its way easier, will come out more even, you wont get drip the hardens on one side and the cure time really isnt that bad. I plasti dipped my entire car for the winter and that only took 5 hours including the prep. I let it sit for a day but with emblems its not as important
drambo136 is offline   Reply With Quote
The Following User Says Thank You to drambo136 For This Useful Post:
Hardpack (01-05-2014)
Old 01-04-2014, 09:44 PM   #6
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
I'd caution you against the red. The pigment bleeds from it into whatever you dip. It may also get in/on the paint of your car over time. Red is the only color I know of that does this with plasti dip.
I've rattle canned a few things with the black and it was easy just watch some YouTube videos and take your time. Make the last coat a little thick and it self levels and smooths.
FrsDuke is offline   Reply With Quote
The Following User Says Thank You to FrsDuke For This Useful Post:
Old 01-04-2014, 11:56 PM   #7
Sailors14FR-S
Sailors14FR-S's Avatar
Drives: 2014 Scion FR-S
Done a tone of Plasti-dip, always used rattle can and if you take your time it will come out great...
Did my Corvette's rims with it and loved it...
Sailors14FR-S is offline   Reply With Quote
The Following User Says Thank You to Sailors14FR-S For This Useful Post:
Old 01-05-2014, 12:22 AM   #8
ktech
Well I stand corrected. Apparently rattle cans aren't as bad as I thought!
Sent from my One using Tapatalk
Old 01-05-2014, 02:11 PM   #9
z3ro
I think some colors are easier to spray then others. I had a hard time with coverage with the white
Old 01-05-2014, 05:19 PM   #10
Hardpack
Will this still happen if I coat them before I put them on the car, or will it bleed even then?
Old 01-05-2014, 05:41 PM   #11
FrsDuke
Fanboy
FrsDuke's Avatar
One example I saw was a superman theme. The guy had like 6 non red layers of dip on before he added red stuff. When he removed it his white brz had a red S on the hood still.
Old 01-05-2014, 05:59 PM   #12
Hardpack
I only plan on putting layers of red onto the emblems. Is there anything I can put over it as a final coat to seal it/keep it from bleeding?
Old 01-05-2014, 06:29 PM   #13
FrsDuke
Fanboy
FrsDuke's Avatar
Why not just paint and clear coat the emblems?
Old 01-05-2014, 06:34 PM   #14
Hardpack
I didn't think of that. Figured paint and clear coat would be a bit more in depth, but didn't really look into it.
Where to get plasti dip done? Norcalmav23 Northern California 22 03-06-2014 11:31 PM
Plasti Dip Emblems 86_ZN6 Cosmetic Modification (Interior/Exterior/Lighting) 87 11-14-2013 08:28 PM
Plasti-Dip NickFRS Northwest 1 11-12-2013 11:07 PM
Plasti Dip Badges crouchy35 AUSTRALIA 6 09-20-2013 04:31 AM
Just another Plasti dip fun :) EPIKsung FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 07-17-2013 02:08 AM
