Drives: Raven Scion FR-S
Hey just wonder what the best battery out there would be with more than the stock 390 CCA. I'm having issues with the car going completely dead on start up so I have to reset the battery for it to work so I'm going to get a new alarm in and also a new higher powered battery since I have a bunch of led aftermarket work done to the car ....he dealership disconnected the security box when they put in my alarm and auto start so that could also be the issue ... Best battery with proper fitment and works well in cold weather
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
#2 |
Drives: Subaru BRZ Sport Tech Satin White
Subaru and scion fit a 500 CCA battery to automatic equipped cars. Drop in fit in any BRZ/FRS.
#3 |
The stock Panasonic battery is 390CCA so I can go up to 500? And also what size do I need or other specs before getting one
#4 |
SLO NO MO
I went with Optima Batteries YellowTop Dual-Purpose Battery, Group 75/25, 620 CCA
Model # D35 is the exact fit/polarity for our cars. It's normally around $230 but I bought it when I had a coupon for around $180. |
#5 |
One of these would work good.
http://www.interstatebatteries.com/c...501-2147384906 However, I'd suggest you first find out what is draining your old battery .... ?? humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | subwaynm (01-04-2014) |
#6 |
Professional Smartass
Drives: White Out FRS
This is the same battery I just got. It's so much better than stock.
#7 |
Drives: 2013 DGM BRZ Ltd
my Panasonic does not crank strong when its cold out it seems like a junk battery. I have a dash cam wired up with a power magic but I have disconnected it for the winter as I do not trust it.
| The Following User Says Thank You to raptor87 For This Useful Post: | Busybee (10-12-2019) |
#8 |
I found this on amazon this is it correct? What do I use to mount it ? [ame="http://www.amazon.com/Optima-8040-218-FFP-YellowTop-Group-Battery/dp/B006QH56GE"]Optima 8040-218-FFP YellowTop Group 35 Deep Cycle Battery : Amazon.com : Automotive[/ame]
#9 | |
That's the correct battery. Mount it how you'd mount the battery you have in the car. |
#10 | |
#11 | ||
SLO NO MO
Take the new battery's top cover piece and attach it to the bottom (snaps right on to give it more height to match the stock size), put the battery in place, tighten the battery tie down, attach the positive battery terminal connector and tighten it, attach the negative battery terminal connector and tighten it. Start the car. With exception to the Optima cover piece attached to the bottom, these instructions apply to any battery you get. Also keep in mind that any Group 35 battery will physically fit, so long as the negative is on the left and the positive is on the right. If you get the polarity reversed, the existing cables won't reach without some serious hacking. |
#12 |
Drives: 2015 Series.Blue
Keep in mind Optimas aren't what they used to be. They used to be made in the USA, now they're made in Mexico and their quality has gone way down.
LED stuff on the car isn't going to do much. LED's consume a fraction of a normal bulb, if anything you've lessened the load on the electrical system. |
#13 |
Drives: Scion FR-S Coupe
A new Battery is fine but as humfrs said check and see what is draining the battery down or the same thing will happen to the new Battery
#14 | |
SLO NO MO
Another battery to consider would be the Odyssey or DieHard Platinum (re-branded Odyssey). Sent from my Nexus 5 using Tapatalk Last edited by Foobar; 01-04-2014 at 08:24 AM. |
| New to me daily driver.. 95 M3. | Dave-ROR | Other Vehicles & General Automotive Discussions | 58 | 07-17-2014 02:05 AM |
| Is your FR-S your daily driver? | Drive | Scion FR-S / Toyota 86 GT86 General Forum | 136 | 02-10-2014 09:10 AM |
| FRS as a Daily Driver? | Pake1 | Scion FR-S / Toyota 86 GT86 General Forum | 104 | 08-15-2012 11:48 PM |
| BRZ as daily driver? | Pakjk89 | BRZ First-Gen (2012+) — General Topics | 80 | 03-22-2012 09:50 AM |
| The daily driver | KiingDavid | CANADA | 25 | 02-06-2012 01:14 PM |
