Old 12-31-2013, 09:29 PM   #1
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Perrin plate relocate kit issues
So I tried to tighten the stem on the towhook hole to spec at 50 ft lbs as mentioned. The stem never came to a stopping point to torque anything near that pressure, but it doesn't seem to lock, and I know it's all the way in. I'm afraid I stripped something. Has anyone had similar issues? In case something did strip, would the stem or the towhook stem strip first?
Also, the plate now covers some of the DRL light, are there other relocate kits that don't?
Old 01-01-2014, 12:17 AM   #2
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Try the factory tow hook and see if that will tighten.
Chen is offline   Reply With Quote
Old 01-01-2014, 01:22 AM   #3
Turbo95eg6
Turbo95eg6's Avatar
Where is the factory towhook located?
Old 01-01-2014, 02:24 PM   #4
BPM
Drives: A Blue One
In the trunk, Lift open the cover and you will see it. Good Luck!
BPM is offline   Reply With Quote
The Following User Says Thank You to BPM For This Useful Post:
Turbo95eg6 (01-01-2014)
Old 01-01-2014, 09:52 PM   #5
Turbo95eg6
Turbo95eg6's Avatar
Well installed the factory hook with no issues, then tried the Perrin one again... And it worked? WTF? Shit like this makes me feel like a noob lol.
Old 01-02-2014, 07:13 AM   #6
nyfries
Drives: 14 FRS Whiteout
yea i had that problem too when i was installing my perrin. it wouldn't tighten, and than i took it out and tried again and it worked lol.
I don't know why that happened either lol
nyfries is offline   Reply With Quote
Old 01-02-2014, 02:23 PM   #7
FRSHBRZ
Drives: 2014 Subaru BRZ LTD 6MT SWP
Had the same issue.
Got it on, but I was really not confident that it was secure enough. Left my buddy's garage and by the time I got home it was loose enough that I could spin the plate bracket with minimal effort. Started from scratch the next morning and everything seems fine now. I still check it from time to time, but I don't think it's going anywhere.
I ended up drilling the tow hook cover and I'm just waiting to go pick us a 1.25 inch grommet (maybe slight bigger) to help seal the hole around the stem. Totally unnecessary, but I want it to look clean.
FRSHBRZ is offline   Reply With Quote
Old 01-02-2014, 03:40 PM   #8
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Grimmspeed does not since it is super adjustable. I have this and it's solid.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 01-02-2014, 03:46 PM   #9
Turbo95eg6
Turbo95eg6's Avatar
Originally Posted by FRSHBRZ View Post
Had the same issue.
Fucking wierd! Glad I wasn't the only one trippin'. Yeah, I have yet to drill a hole. Something tells me I'll have to get a few extra covers just in case I mess up.
Old 01-02-2014, 04:07 PM   #10
FRSHBRZ
I used this post: http://www.ft86club.com/forums/showthread.php?t=42533
Worked pretty well. I used a unibit which allowed me to gradually step down the diameter until I was happy. The cover sits on an angle with the curve of the bumper so keep that in mind when drilling.
Old 01-02-2014, 04:24 PM   #11
Dezoris
Dezoris's Avatar
Use a little penetrating oil in hole and threads before screwing.
Old 01-02-2014, 08:18 PM   #12
Turbo95eg6
Turbo95eg6's Avatar
Make me one and I'll paypal you $20
Perrin Oil Cooler Issues deange Engine, Exhaust, Transmission 137 01-29-2015 07:47 PM
Relocate front plate or not thehapaone Northwest 18 07-26-2013 07:58 PM
