#729 |
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
it is ok now i managed to update.
#730 |
Drives: FR-S Whiteout
Who else here has had their LTFT go up after switching back to gasoline from E85 maps or after trimming the intake snorkel?
I was looking through my old logs from before testing out the E85 map, and my LTFT were lower than they are currently with the OFT stage 1 map. I looked for exhaust and vacuum leaks and was only able to find a very small leak in the mid pipe to front pipe connection. Only things that were different pre and post- E85 were the trimmed intake scoop and the MAP version. (v1.3 vs. v1.42b) Is it possible that the MAF scaling need to be modified to account for the trimmed intake scoop? LTFT has increased across the entire range to around +10% plus minus a few percent. Last edited by solidONE; 12-26-2013 at 11:05 AM. |
#731 | |
Drives: 2015 WRX
Sent from my SCH-R970C using Tapatalk |
#732 |
Administrator
Drives: Boxster 986
Read my warnings: http://www.ft86club.com/forums/showt...54#post1411654
This applies to the entire subforum. For those who want to keep trolling and posting off-topic, you will face infractions. Keep your discussions on-topic and technical. |
#733 |
@shiv@vishnu
will OFT get fbkc, flkc, iat, iam working on non-us cars on the next update? Technical enough? @Hachiroku |
#734 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Last I heard they are working on it. Btw slo did you ever fix your rattle?
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#735 |
#736 |
#737 | |
Drives: 86 GT MT Velocity Orange
Are there any other alternative logging options available? All good to keep an eye on the fuel trims, but I want to see if my car will be knocking! |
#738 |
You can check the ignition timing against the base timing map + timing advance and see if it matches or higher then there is no knock.
Last edited by s2d4; 12-29-2013 at 11:06 AM. Reason: Didn't get it right 1st time around, still learning |
#739 |
Life to short to be slow!
Drives: Toyota GT86
I know this may have been ask before but I can't find it,,, If I have Ecutek how do I remove it and use Openflash?
#740 |
You could flash the stock map back on with ecutek then install the openflash. Not sure why you'd do that now that ecutek offers oft-equivalent tuning for free.
#741 |
Drives: Toyota GT86
Lol, just asking!!! Thanks!!!
#742 | |
Drives: 2013 FRS
At the end of the day, there are multiple good options for people. Which is good because different people will way pros and cons differently. Cheers, shiv |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 01:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 12:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
