Old 12-25-2013, 11:17 AM   #43
FR-S Matt
Originally Posted by ID86 View Post
Cool. So that eliminates the blind spot completely right, even with my mirror seeing just like 1% of my car.
To the people checking over their shoulder (Driver), is it okay to check blindspot from the first window instead of the triangle window or does that provide not enough vision?
Yes, it does eliminate it. I've tested it multiple times on the highway.
The Following User Says Thank You to FR-S Matt For This Useful Post:
ID86 (12-25-2013)
Old 12-25-2013, 05:12 PM   #44
uEih
Drives: CBS Subaru BRZ Limited
I don't know what triangle window you're talking about because there's one in the very front which I don't think is possible to look through while driving and the back seat window which you shouldn't even have your head twisted that far. Just look over your shoulder and check your mirrors. A blindspot is just that, a little area on the side of your car that your mirrors may not catch, anything else you should see clearly or you have your mirrors set up incorrectly.
uEih is offline   Reply With Quote
Old 12-25-2013, 07:06 PM   #45
e-d.
Drives: Scion FR-S 13
Originally Posted by CBR600RR View Post
if your mirrors are properly adjusted you will not have a blind spot
Originally Posted by whaap View Post
This is the most common mistake made by drivers. If you fan out your side view mirrors enough you will be able to see the car approaching you from behind. As he starts to pass you (on either side) you will see him in your side view mirror before he leaves the rear view mirror. Before he leaves the side view mirror you should see him with your peripheral vision, if not a slight head check. It will seem strange at first but try it for awhile and you will wonder why it took you so long to figure it out.
mindblown realization
e-d. is offline   Reply With Quote
The Following User Says Thank You to e-d. For This Useful Post:
racecat (12-27-2013)
Old 12-25-2013, 08:47 PM   #46
JB86'd
JB86'd's Avatar
Drives: JAWS
Originally Posted by OICU812 View Post
Same here these helped a ton and well they look good to ?
This. I have the blue convex Rexspeed mirrors and recommend them to everyone. What a world of difference. and yeah they look like they're from a much more expensive car
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
Rio (12-27-2013)
Old 12-27-2013, 02:26 AM   #47
racecat
racecat's Avatar
Drives: Hot Lava FR-S MT
Originally Posted by CrazyWookiee View Post
Like a lot have said above, the mirrors adjusted properly will eliminate the blind spots. Your mirrors should be set up to have a "panoramic" view of everything behind you.
http://www.caranddriver.com/features...id-blind-spots
You shouldn't see your own car in your side view mirrors. Cars on either side of you if they are further away should be in your center rear view. As they move closer to the left and right, when they "leave" the view of your center rear view they should transition straight to one of the side mirrors. As they are traveling in your side view mirrors view, when they start "leaving" that mirror they are now right beside you out of the corner of your eye. No blind spots.
If you insist on seeing a fraction of your car in your side views, you may want to invest in some aftermarket convex mirrors, but if you set up the panoramic rear view mirrors, you shouldn't have a problem.
When I first tried this is seemed so weird, but I'm STILL impressed by how well it works. I love watching approaching cars go from mirror to mirror and it keeps me more observant about where those other drivers are. I wish everyone knew this.
racecat is offline   Reply With Quote
The Following User Says Thank You to racecat For This Useful Post:
CrazyWookiee (01-01-2014)
Old 12-28-2013, 05:38 PM   #48
marebear
marebear's Avatar
Drives: 2014 Pearl White FR-S (HAKU)
Ditto.
Adjust your side mirrors so you barely see any of your own car in them, and use the rear-view often. I still shoulder-check, but my mirrors are much more reliable since I learned how to properly set them.
marebear is offline   Reply With Quote
New Parking Spot raul Scion FR-S / Toyota 86 GT86 General Forum 7 09-05-2012 01:42 AM
Blind spot mirrors? enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-11-2012 03:29 AM
spot cleaning jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-26-2012 07:12 PM
People having a hard time with the FR-S blind spot driver01 Scion FR-S / Toyota 86 GT86 General Forum 28 06-16-2012 04:27 PM
Blind Spots? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 35 10-04-2011 04:17 PM
