#57 |
Drives: 17 Alfa Romeo 4C
I never see it discussed, but aggressive engine braking in manuals adds to clutch wear.
#58 |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
It's implied - same as dumping the clutch.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
#59 | ||||
Drives: 4 Wheels Auto
So far, so good. Now, let just say if on a flat ground and the car is stopped and not moving. The clutch is pressed (disconnect), brake is release and you shift to 1st gear. The gear is connected to the input shaft, which is idle because the car is not moving. The clutch plate on the engine side is spinning at idling RPM (assume it is 800 rpm for warmed up car). Now you release the clutch to the grabbing point, those two plates, one spinning at 800 RPM (or 13.3 rev per second) while the other is stationary, are trying to connect together. When you gently release the clutch to make connection, these two plates connects (grab) and the engine sends power to the input shaft, which sends the power to the transmission, and get the car moves. So your car moves. So far so good, this is just the basics of how a car moves, right? Observe the statements above, where does the *wear* of a clutch come in? That happens when two plates that are running different revs are trying to connect and sync the revs. To do so, the material on the plates need friction to sync the rev. This causes friction and heat, and the material would be lost gradually. To reduce the clutch wear and make a smooth transition, it is the best when connecting these two plates they are already in sync, or very small difference, in terms of their respective revolutions. This, IMO, is the fundamental theory of rev matching. The idea of rev matching is to rev the engine revolution with the revolution of input shaft that is connected to the gears in transmission and the driving wheels. It is all happening on the clutch. So, if we go back to our original situation: flat ground, car stationary, clutch in, 1st gear, no brake. Whether adding gas or not, you are wearing out the clutch. The key question is by how much. Adding gas before connecting the plates, the plate on the engine side is at higher RPM while the input shaft is idle. The difference in rev is higher, more wear. Not adding gas before connection, idle rev, less difference, less wear. In summary, your statement is correct in one way: not adding gas while releasing clutch, you will wear out the clutch. However, by doing this it will wear out less than that if you add gas while connecting those two plates. In other words, that statement is correct but not effective. Clutch is a wear item, and their mileage depends on how it is used. If you ease on it, it can last longer. If you keep dumping the clutch on start up, it will need to be replace sooner. It is as simple as people already said below. Quote:
| The Following User Says Thank You to Want.FR-S For This Useful Post: | Frost (12-20-2013) |
#60 |
Drives: FR-S MT
It will always be a little slow to start, that's because the car has very little torque below 2,000 rpm. An automatic can compensate for that. So can you, but it will take a while to find the sweet spot to drop the clutch.
#61 | |
Is not fast.
Drives: 2014 Whiteout M/T
I also didn't know about the reverse lock out... which got me wedged awkwardly in the middle of an intersection with no way to back up. |
#62 | |
Fears Hiccups
Drives: Toyota badged 2013 Whiteout FR-S
Short version:
Downshifting for engine braking without rev matching causes the most clutch wear; downshifting for engine braking with rev matching causes less clutch wear; engine braking without downshifting causes no clutch wear. Long version: Quote:
What is probably meant is that using the clutch to bring the engine to speed when downshifting instead of rev matching will cause significant clutch wear, while rev matching will cause less. Leaving the car in the current gear and letting the engine slow you down naturally is still engine braking, but causes no wear on the clutch. I keep seeing this point mentioned on this forum and nobody ever makes completely clear statements, which I'll bet causes confusion for new manual drivers. Last edited by fatherfork; 12-20-2013 at 03:32 PM. |
#63 |
OK, here we g...oh, wait
Drives: '13 Hot Lava 6M
Sounds like the salesperson did a terrible job. You're lucky no one got hurt.
#64 | |
Is not fast.
I decided to pull over into a parking lot as quickly as I could so I could review the manual. Once there, I practiced some starts, stops, and reverses... all with fairly poor clutch releases so there was some slight wheel spin and screaching. Did this for about a half hour. When I finally felt comfortable enough to make it home, I proceeded to leave the parking lot. As I did, however, I saw a sign that read... "Buena Park Police Station." So... I was essentially burning out, revving loud, and making a shit ton of noise in general... in a police station parking lot.
| The Following 2 Users Say Thank You to Manic For This Useful Post: | Jaywest717 (12-20-2013), JB86'd (12-20-2013) |
#65 | |
Drives: 2013 Scion FR-S 10-Series
Clutch control feels much better now. I can even keep my car stationary on an incline without using the regular brack or ebrake, but with the clutch alone (Only did this once though to test it out!) I love driving this car!! |
#66 | |
I have been scared shitless in downtown Toronto parking lots (looking at you Air Canada Centre) where an expensive ass Porsche (obviously non-PDK) is in front of me on a 20 foot ramp and we're stuck because everyone is trying to get out after the game. I'm smart enough to give him almost 10 feet and the sunvabitch rolls back almost 10 feet. All the while I hear him roaring the engine and I have NOWHERE TO GO. Please do yourself and other fellow drivers a favour and just pull the E-brake. A perfect driver from the outside just looks like he moves forwards. No weird revving or rolling back. Rolling back = EPIC ULTIMATE FAIL.
| The Following 3 Users Say Thank You to Frost For This Useful Post: |
#67 | |
#68 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
(It can take a while before you are comfortable enough to do this though, and as I said, I wouldn't go out and practice it a bunch. Just drive stick shift consistently, and eventually, it'll be completely natural to you. I've been driving almost exclusively stick shift for around 7 years now - I don't own a car with an auto, and eventually, it becomes second nature) |
#69 | |
Drives: Subaru BRZ Sport Tech Satin White
In many countries you would fail your driving test using the "inertia" method. Your car ALWAYS rolls backwards it is just a matter of how far. Try this inertia technique in winter and prepare to touch up the paint on your rear bumper a lot. |
#70 | |
Marine Electrician
Drives: Toyota TRD86, 2014
![]() So "catching up" not for me, I have driven some AT, and I find it boring, ofc I can see that it's great when living in a city, with lot of trafic ect. but out here, no way ![]() But eitherway you North Americans are lucky, with the price for an FRS Here in Norway the GT86 starts at 76K dollars.. ![]() Cheers |
| Tips needed: Driving roads in the Alps | atledreier | Other Vehicles & General Automotive Discussions | 0 | 06-05-2013 03:51 AM |
| Manual driving method | frosty86 | Scion FR-S / Toyota 86 GT86 General Forum | 123 | 01-14-2013 11:13 AM |
| driving manual questions | cantaloupe | BRZ First-Gen (2012+) — General Topics | 25 | 11-08-2012 05:27 PM |
| Is this a bad way to stop when driving manual? | artizhay | Engine, Exhaust, Transmission | 39 | 09-21-2012 05:32 AM |
| Best Manual transmission driving techniques? | rawbz | Other Vehicles & General Automotive Discussions | 24 | 05-23-2012 01:15 PM |
