Old 12-20-2013, 01:06 PM   #15
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Originally Posted by STV3 View Post
I'm a newb at this ...[snip]... and I've also been doing some left foot braking to help keep control
Your left foot is not meant to be used on the brake pedal. Unless perhaps you only have one leg, and it's your left leg.
Rossman is offline   Reply With Quote
Old 12-20-2013, 01:14 PM   #16
onefitz
Drives: 13 GBS BRZ
Left foot braking is most definitely used in a racing to control load transfer.
onefitz is offline   Reply With Quote
Old 12-20-2013, 01:16 PM   #17
guysmiley
Sideways and Smiling
guysmiley's Avatar
The OEM tires have about as much traction as 4 bars of wet soap -- which is great for easy "drifts", but moves us from drift to "spin" at pretty low g's. This, by the way, is handy for doing donuts in the parking lot of your (former) employer with your left hand triumphantly raised out the window in a 1 finger salute. I gave this a try and it was AWESOME.
Anyway ... sounds like you may want to ask Santa for some stickier tires.
guysmiley is offline   Reply With Quote
Old 12-20-2013, 01:22 PM   #18
trekkie
Drives: 2011 Camry Hybrid
I would guess based on you saying that you did it 'in a truck' before easier that you're suffering from the problem of 'my back end weighs something' and you need to put more power into it than you're used too.
Speaking from experience of transitioning to a Truck to a Car. The Truck could spinout at a light with the brakes on (old truck, high speed idle broke so was always on, and a 454 chin V8 (what is that. 6.7L now?) can over power the brakes on an old truck and if there is snow on the ground...instant UNWANTED donuts)
trekkie is offline   Reply With Quote
Old 12-20-2013, 01:26 PM   #19
bestwheelbase
Drives: 1985 P-Type
More cowbell.
Old 12-20-2013, 01:41 PM   #20
Captain Stall
OK, here we g...oh, wait
Captain Stall's Avatar
Drives: '13 Hot Lava 6M
Originally Posted by z3ro View Post
Now, pardon my newbiness/dumbness/etc, but is there some sort of magical trick to getting this thing to smoothly drift corners? I've tried twice...
Magic? Try more than twice.
Captain Stall is offline   Reply With Quote
Old 12-20-2013, 02:25 PM   #21
STV3
Señor Member
STV3's Avatar
STV3 is offline   Reply With Quote
Old 12-20-2013, 02:30 PM   #22
z3ro
oh i'm in no way saying i dont need or dont want more practice, but coming from something that i could drift and would a drift relatively easily to something that is supposed to drift easy and for me doesn't is more of the issue
z3ro is offline   Reply With Quote
Old 12-20-2013, 04:36 PM   #23
993Fan
993Fan's Avatar
Drives: 2014 DGM BRZ MT
If you do spin, don't try to save it.
"in a spin both feet in and come to a complete stop"
(of course, both feet in = clutch + brake...)
993Fan is offline   Reply With Quote
Old 12-20-2013, 05:01 PM   #24
bestwheelbase
Drives: 1985 P-Type
Your truck probably had a shit-ton more torque and a lot less total grip on the drive wheels (unloaded, light rear).
This is about balance more than just power.
Old 12-20-2013, 05:51 PM   #25
z3ro
and thats a natural tendency for me for whatever reason. both times i've spun out i counter steer and clutch & brake. I havent ever stalled while spinning out.
wouldn't more torque make it easier to spin out?
Old 12-20-2013, 06:13 PM   #26
bestwheelbase
Drives: 1985 P-Type
With the truck it was easier to break traction without much weight transfer. Whereas in the car you're getting the whole thing rotating. Speaking of rotating... A lot of what you are feeling is the wheelbase. Your truck probably had much larger dimensions. The car is 2570mm and thus rotates faster.
This is kind of our thing. People often focus on horsepower/torque and maybe weight, but your wheelbase and chassis setup dictates a lot of your experience. Food for thought.
Cheers,
bestwheelbase
Old 12-20-2013, 06:24 PM   #27
frslee
Just drive it
Drives: 13' FR-S
It's very easy to spin the car with stock tires. 25~30mph on 2nd gear won't get you that power, try with 1st gear.
frslee is offline   Reply With Quote
Old 12-20-2013, 06:28 PM   #28
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
1st gear is way too short. The car can drift fine in a parking lot going 20-30mph in 2nd gear.
Also i found the best spot for me is my local community college parking lots. No one is around at night and the lots are wide and open.
bkblitzed is offline   Reply With Quote
