go_a_way1
Old 12-13-2013, 09:27 AM   #2899
Victor Draken
Drives: Toyota Gt86
Originally Posted by SloS14 View Post
He is not selling fruit flavored candies.
cracked me up
Victor Draken is offline   Reply With Quote
Old 12-13-2013, 10:22 AM   #2900
Pizzman
Crap another obsession.
Drives: 2013 BRZ Limited
Maybe not flavored, but candy yes.
I can't be the only one who is concerned with aesthetics.
Performance-----------#------------------------Looks
Where are you on this fancy line graph?
Pizzman is offline   Reply With Quote
Old 12-13-2013, 01:58 PM   #2901
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Lines can't define me. I'm beyond the line. But I'm all over circles. Infinite in nature
Installed Mods:
Old 12-13-2013, 02:46 PM   #2902
mid_life_crisis
Drives: FR-S 10 #103 AT
Aren't you a physics teacher? I'm surprised you didn't put yourself on a Mobius strip.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 12-13-2013, 02:49 PM   #2903
Sojhinn
Sojhinn's Avatar
Damn nice one .
Installed Mods:
Old 12-13-2013, 05:22 PM   #2904
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
PSH-12180FR Battery Test
I parked my car for the winter on November 25th, 17 days ago. The car has been parked in my garage. My garage is insulated and doesn't get below freezing unless it's zero Fahrenheit outside...which it hasn't been. But it has been anywhere between 10 and 40 for the last three weeks so the temperatures in my garage have been somewhere between the high 30's and 50 degrees. I was wondering how the battery would hold up for an extended period of non-use, such as while parked at an airport.
The good news is that the car cranked right up as if it had been started yesterday. That, coupled with some of the low temperature tests others have done with this battery, gives me a lot of confidence that the smaller battery is up to the job of starting the car.
IRONY UPDATE:
Today I went out to start my Chevy Silverado. The battery is only 2 years old. After sitting two days where the days were in the mid 20's and the nights were in the the low teens...no start. Dead battery.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following 5 Users Say Thank You to Gary in NJ For This Useful Post:
DAEMANO (12-13-2013), Robftss (12-13-2013), SKELLINGTON (12-15-2013), SloS14 (12-13-2013), Sojhinn (12-13-2013)
Old 12-15-2013, 10:02 PM   #2905
Sojhinn
Sojhinn's Avatar
Swapped out my controllers today. Took me about 7 minutes to do the swap. New controller looks fantastic and has the connections mounted on the battery side instead of the farside. Nice having the drag reduction back. Rob suggested I modify my foot switch to activate at 90% for a more natural progression into full boost mode. I will be modifying that tomorrow while I work on my exhaust leak.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Robftss (12-17-2013)
Old 12-16-2013, 04:58 AM   #2906
Grantmac
Drives: 2001 NB MX-5
Originally Posted by Robftss View Post
This should work with the stock factory tune.... less initial TQ but same top end.
That looks excellent. Very smooth with almost no overshoot. Does it still draw the same current or are power requirements reduced?
-Grant
Grantmac is offline   Reply With Quote
Old 12-17-2013, 04:12 PM   #2907
Robftss
Drives: VW
-Grant
Hysteresis +/- 0.2 psi...adjustable setpoint 2 to 4 psi. It is a simple fast acting switch referenced by the DR line and plugs into the control/charger unit.
Power is reduced...though overall typically it intervenes for a short period of time.
Thanks!
Robftss is offline   Reply With Quote
Old 12-17-2013, 04:21 PM   #2908
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
Rob when will the group buy come...??
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
Old 12-17-2013, 04:22 PM   #2909
Robftss
Drives: VW
Who says nothing good comes from Canada LOL
- Snowmobiles
- Snow Blowers
- Zamboni
The Following 3 Users Say Thank You to Robftss For This Useful Post:
CBR600RR (12-17-2013), Pizzman (12-18-2013), SKELLINGTON (12-17-2013)
Old 12-18-2013, 02:24 AM   #2910
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
I'm interested, but I like things to look stock.. i.e. No wires everywhere or weirdly aligned connections (tubing, etc.). If I wasn't in California, I would seriously be looking at the innovate kit. It looks so clean.
mike_ekim1024 is offline   Reply With Quote
Old 12-18-2013, 08:57 AM   #2911
Gary in NJ
Gary in NJ's Avatar
I have no idea what you're talking about. All of my wires are contained in looms. You can't even tell that the battery pack isn't stock. I can't think of a cleaner install.
Old 12-18-2013, 10:27 AM   #2912
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
I've had multiple people look at the car and think the esc was a regular supercharger. They never noticed the three batteries unless I brought it up , and I'm very proud on how my looms are run so that it's not messy and looks stock.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
