Old 12-08-2013, 01:26 PM   #2325
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Originally Posted by sw20kosh View Post
Impressive! What pulley are you running? What sort of max timing are you seeing during WOT pulls? Should be something like 25 deg towards redline?
I do love my torco. Keep a bottle in the trunk with me. I always use it at the track.
I'm on 75mm pulley, I asked Bill to give me map 1 on pumpgas and Map 2 with Torco.
Ryan86 is offline   Reply With Quote
Old 12-08-2013, 02:36 PM   #2326
xxscaxx
Drives: 2013 SWP BRZ
My tensioner has wobble/play too when the motor is spinning. I just assumed that is what a tensioner does when the motor is spinning... How much wobble is standard?
P.S. Anyone know how much a new tensioner costs? Never had any problems with my belts luckily. I did shim my idler pulley so the belt sits in the middle of the pulley.
I just checked my pulley and while its not directly in the center and close to the edge, its still fully on the pulley. But I wonder if this is the reason why a few have had to rebuild the pulley - maybe its putting tension on the bearings with the belt not being directly in the center of the pulley.
I started hearing a noise the past few days, it comes and goes, but I'm wondering if its the pulley.
xxscaxx is offline   Reply With Quote
Old 12-09-2013, 10:10 AM   #2327
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Originally Posted by Touge_ninja View Post
@DarrenDriven might wanna take me off the list.... could not wait any longer and went with a different kit.
Not surprised haha.
Old 12-11-2013, 09:29 PM   #2328
wrxgoose
WUB WUB
Drives: 2013 Firestorm
so is anyone else having issues with their tensioner and the belt?
wrxgoose is offline   Reply With Quote
Old 12-11-2013, 10:38 PM   #2329
Ryan86
Road Warrior
Ryan86's Avatar
Give the Blue Gates RC belt a go, it's slightly smaller, than the kit belt, which after a weeks worth of driving runs perfect.
Got me eye on the Raceseng tensioner pulley, they look hardcore compared to the plastic pulleys.
Old 12-11-2013, 10:44 PM   #2330
wrxgoose
WUB WUB
is it a manual, or automatic tensioner?
Old 12-11-2013, 10:52 PM   #2331
Ryan86
Road Warrior
Ryan86's Avatar
Sorry I was meant to say idle pulleys. Our cars are self tensioning??
Old 12-11-2013, 10:54 PM   #2332
wrxgoose
WUB WUB
that's what it seems to be, but when i get on it, it slacks, and that seems to be why my belt is comin off and eating stuff
Old 12-11-2013, 11:06 PM   #2333
Ryan86
Road Warrior
Ryan86's Avatar
Try the Blue Gates, tension is far better and I'm sure it reduces drag. I've done almost 2000km now no issue and the belt running super smooth now that it worn in.
Old 12-11-2013, 11:09 PM   #2334
wrxgoose
WUB WUB
even with driving as hard as you can? that's the only times i seem to be having problems
Old 12-11-2013, 11:16 PM   #2335
xxscaxx
my blue gates belt is working problem free with my 70mm pulley. Then again, I never had issues with the belt, stock or not.
goose, did you check your supercharger pulley to make sure it was rotating correctly? I remember someone having an issue when turning the pulley by hand with the belt off and it had a "wobble." Maybe this is cause it to come off?
I don't beat on my car but I have done a lot of logging so a lot of WOT pulls and i've never had issues. I have been "stomping" it lately (low rpm, just WOT) with the blue gates belt and putting some more strain on things and still no issues.
Old 12-12-2013, 04:20 AM   #2336
sw20kosh
Drives: 2013 Black FR-S
I've tracked this kit maybe 5 times and had no problems with the belt. 75 mm and 70 mm pulleys.
@whataboutbob, what about you and all your autoX?
Old 12-12-2013, 10:12 PM   #2337
whataboutbob
AutoX-10/10ths every run
@sw20kosh I had the idler pulley go out on me and tried to space the replacement unit Innovate sent me out so that the belt was more centered on it. The next AutoX event I took a very nasty spin and came back into grid to find that it had thrown the belt completely off, but the belt was not damaged. I immediately removed my spacing modification and put a new belt on and did the rest of my runs. I've probably put about 2K miles and a couple of AutoX days on the setup since and have had no belt or idler pulley issues since. FYI I am still using the 75mm pulley and plan to continue to do so.
Build thread:Here
Old 12-13-2013, 04:43 PM   #2338
DriftEm
DriftEm's Avatar
http://www.delicioustuning.com/node/247
DriftEm is offline   Reply With Quote
The Following User Says Thank You to DriftEm For This Useful Post:
akuhei (12-13-2013)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
