Old 12-11-2013, 11:39 AM   #29
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Originally Posted by BlackyRose View Post
In for this also. I am staying all stock and dont track or autox my car. Thoughts??
I would skip it then. It will only provide benefit in mid to extreme driving situations - Otherwise it's just a $150+ bar for dress up.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 12-11-2013, 04:57 PM   #30
brillo
Drives: 2013 Firestorm FR-S
I do track the car occationally, so the car being more neutral in terms of handling is not a bad thing.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 12-12-2013, 04:38 AM   #31
mfbmike
Drives: 2013 FRS, 2008 R32
Installed mine lastnight. Love, love, love the feel.
Same coils as you gopher but different alignment settings. -2 all around. No particularly glaring signs of understeer but the car is certainly less "tossable" due to the reduced body roll.
Granted, our setups are different. I'm sitting with -2 camber all around with 265/35 Michelin PSS. Car hooks like crazy. I love it.
mfbmike is offline   Reply With Quote
The Following User Says Thank You to mfbmike For This Useful Post:
boredom.is.me (12-12-2013)
Old 12-12-2013, 04:47 AM   #32
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Perfect word IMHO - "tossable"
The Following User Says Thank You to boredom.is.me For This Useful Post:
mfbmike (12-12-2013)
Old 12-12-2013, 10:39 AM   #33
Gopherboy6956
good lord on the tires lol. Fatties
Yea - when my car wakes up for the year in March, or you know, July with our weather here in Fargo - I'll have it realigned.
I put my stock wheels and tires on a few weeks before I put the car away, and I will say it felt more light on it's feet than with my 17x8 245's. But, meh.
Old 12-12-2013, 11:03 AM   #34
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
That sounds like my kind of setup! Thanks for your feedback!
In my sti, I have equal amounts of fun on 225/45 'street tires', 255/40 RS-3 and 225/45 R-Compound slicks. I think that they each have their procs and cons. The sharpness and resolution that the narrower tires offer is awesome and the car is certainly more 'tossable. On the stickier 255's, it's just big, fat, dumb grip with less 'sharpness'. The slicks, of course, are a whole different ballgame and I find them to actually be less fun.
Any pics?
Matt Beenen
Engineering
GrimmSpeed is offline   Reply With Quote
Old 12-12-2013, 02:32 PM   #35
mfbmike
Any pics?
Matt Beenen
Engineering
I actually posted a short review in my build thread. Not sure if you guys caught the tag or not.
http://www.ft86club.com/forums/showp...&postcount=114
Old 12-12-2013, 09:15 PM   #36
diss7
Drives: AE86, 2x GT86, TE27
Do you need to drop one of the shocks to install this, or is there enough slop or a slotted holes on the bar?
Cheers
Edit - I see that you don't need to drop the shock. PM'd.
diss7 is offline   Reply With Quote
Old 12-13-2013, 04:03 AM   #37
mfbmike
Cheers
No need. The install takes minutes.
Old 12-13-2013, 11:42 AM   #38
GrimmSpeed
GrimmSpeed's Avatar
I'm pretty bad about catching tags and mentions so I had not seen that yet. Thank you very much for the review, I couldn't agree more!
Chase
Engineering
The Following User Says Thank You to GrimmSpeed For This Useful Post:
mfbmike (12-13-2013)
Old 06-10-2015, 12:23 PM   #39
Dake
Dake's Avatar
I thought I'd resurrect this thread for fun and a couple of questions.
1) How much does this weigh (don't see it on the mnfr web site)
2) I've read it's important to get the front wheels off the ground before installing a strut tower brace, this appears to bolt on without and since there's no adjustment I guess it wouldn't matter if the front end's off the ground anyway. Does that make it less effective than another type like the Tanabe that has some adjustment and suggests unloading the front suspension first?
Dake is offline   Reply With Quote
Old 06-10-2015, 12:42 PM   #40
Gopherboy6956
It's maybe 8lbs? Its so long it was hard to gauge when I held it.
In my experience, there's no reason to lift the front of the car to preload it. I figure you'd want to bolt it to the car with normal load on the towers anyways.
There's a reason they made a solid bar instead of a adjustable bar through all their testing...
The Following 2 Users Say Thank You to Gopherboy6956 For This Useful Post:
Dake (06-10-2015), GrimmSpeed (06-11-2015)
Old 06-11-2015, 12:00 PM   #41
GrimmSpeed
GrimmSpeed's Avatar
Gopher pretty much nailed it.
However:
1. The strut bar weighs 3.95lbs
2. The mounts are slotted to allow for a little movement during install because the studs are not straight up and down relative to the plane of the bar, and when measuring the distance between towers for the initial design we always used the cars on the ground. Leaving the car on the ground to install is the same as pre-loading the bar. And as Gopher said, we designed it solid for a reason, because it is extremely effective. So much so that it has a noticeable decrease in low speed NVH, which is attributed to it's stiffness:
This shows the cyclic nature of the movement between strut towers. They move both towards each other, and away from each other. So being able to adjust preload to push the towers against each other starts to make less sense compared to simply locking them together.
Chase
Engineering
phobos512 (06-11-2015)
Old 06-11-2015, 12:26 PM   #42
Dake
Dake's Avatar
I see - makes sense thanks!
Password JDM Ultimate Strut Tower Brace Package Review and Photoexplosion F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 06-16-2015 04:05 PM
BRZ/FR-S Strut Tower Brace - Any Interest? GrimmSpeed Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1224 05-10-2015 07:40 PM
NPA: GrimmSpeed Strut Tower Brace for SCION FR-S & Subaru BRZ now available 86_Insider Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 09-30-2013 11:21 PM
FT-86 SpeedFactory Strut Tower Brace Review F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 01-07-2013 05:31 AM
DIY - Strut Tower Brace - FT-86 SpeedFactory F1point4 DIY (Do-It-Yourself) Guides 4 10-28-2012 05:30 PM
