Old 12-01-2013, 03:03 PM   #15
Screw Loose Dan
Drives: '14 BRZ
I've never cared for taking my vehicle to dealers for servicing, but obviously for warranty work it needs to be done. I do agree that we shouldn't expect the dealer to fix aftermarket problems. But, I don't see how the window popping, having crickets for a fuel pump, and problems shifting into 2nd sound related to any aftermarket items on the car. Certainly stumbling and idle problems could be blamed on aftermarket exhaust items.
I'm not that familiar with these cars, since I've only had mine a couple of weeks, but why would an aftermarket O2 sensor get put somewhere that hitting a pothole could damage it? Or, am I missing something obvious?
Screw Loose Dan is offline   Reply With Quote
Old 12-01-2013, 05:08 PM   #16
Darkrune
Darkrune's Avatar
Drives: 2017 86
Unless you messed with the cats or the tune, a CBE is hardly going to cause anything but a little noise because back pressure is maintained by the cats 95%.
Sincerely,
A dude who knows techs are full of shit and warranty work is cheaped out on by dealerships.
Darkrune is offline   Reply With Quote
The Following 2 Users Say Thank You to Darkrune For This Useful Post:
Maverick22 (12-01-2013), PStaff716 (12-05-2013)
Old 12-01-2013, 11:31 PM   #17
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
Hello, Sorry it has been a while since i posted last.
There has been no change to the rough idle with my car. I returned it completely to stock for a week and there was no change in idle.
I want to address this post;
"1. It's impossible to disable the TPMS system. They didn't disable the system they deleted the code."
If that is true, then why is my TPMS light ot working?
I understand deleting the code, But why has it not returned?
"2. You had a rough idle before you went in. Your car was most likely damaged underneath before you brought it in, if it had the same rough idle before and after."
I took the car to the dealership to have the problem fixed! what part of that did you misread? Obviosly the rough idle is an issue.
3. If you're going to put aftermarket parts on your car, don't expect the dealership to spend time trying to fix it for free."
Even with stock parts on the car, the issues still exist.
The techs do not spend time fixing my car for free, Toyota's warranty program ays the dealership and the hourly fee for work.
And just because you are a tech does not neccesarily make you a good tech, the only issue I blame on my tech is smashing my wideband 02.
After the original post, we founn damage where my front bumper had been scrapd pretty bad. My car is at stock height and not once have I knowingly bottomed the front bumper out.
I still beleive the dealership broke my wideband and caused an exhaust leak i had to fix.
Now i am hoping a tune will fix the rough idle.
Maverick22 is offline   Reply With Quote
Old 12-04-2013, 07:35 AM   #18
connorlug
Drives: #1553 10 Series FRS
Listen man, I didn't mean to come off as a **** I'm just trying to explain a little bit.
1. The light is out because the code is deleted, if there is nothing wrong with your TPMS there's no reason for the light to come on. Are your sensors currently installed on the car?
2/3. I understand you brought it in for that issue, but if you bring it in with aftermarket intake/exhaust and a wideband what do you expect them to do?
Yes toyotas warranty program pays the dealership, but only if we actually fix something. We don't get any time for looking at your car for a rough idle unless we fix something or if we record a bunch of things we did to attempt to diagnose. 90% of the time Toyota won't pay us anything unless we perform a repair.
Onto your rough idle issue, did you remove and seal up the wideband?
connorlug is offline   Reply With Quote
Old 12-04-2013, 09:37 PM   #19
Maverick22
Maverick22's Avatar
The only thing aftermarket on the car when i took it in was the wideband, Which should not cause a rough idle. After removing the wideband and sealing the bung plus resetting the ECU, it still idles rough. It has been over 500 miles. I am not an idiot, and I know plenty about automobiles.
I didnt take it in with aftermarket parts knowing that they would blame it on them, I did half the time too when I worked for Toyota.
And since apparently you are not reading my posts..... I have aftermarket wheels on without sensors and I have no TPMS light on. It makes absolutey no sense.
Old 12-04-2013, 10:43 PM   #20
infinite012
Drives: 13 DGM BRZ Ltd
Do you park near your stock wheels at home? Do your stock wheels still have the TPMS w/tires installed with proper air pressure? Is your commute less than 25 miles one way?
infinite012 is offline   Reply With Quote
Old 12-05-2013, 09:41 AM   #21
Mike86
Drives: Scion frs
Yeah i have to drive at least 25 min on highway fir my light to come when i dont have the tpms in the wheels!! As for rough idle i had some issues also at first as soon as i raised my idle by 150 rpm problem seems to have dissapeared!! Good luck with your car man hopeit works out for you!
Mike
Mike86 is offline   Reply With Quote
Old 12-05-2013, 11:20 AM   #22
chriscross_tnt
chriscross_tnt's Avatar
Drives: 02 maxima 6spd sold 2013 frs daily
Sincerely, A frustrated toyota tech
Totally agree. Please note we get paid on the job. We can't just can't warranty parts . Cause when parts are sent back to the company and they determine it was caused by after market parts they bounce the claim and the dealer gets charged. Any signs of aftermarket interference that can cause a problem will make the dealer think twice.
Tpms cannot be disabled. The sensors are asleep when the car comes from port. When the pressures are drop and set they wake up. If they're was something wrong with your sensors they would be s flashing light in the dash.
I'm not standing up for your dealer but I'm sure you didn't let the dealer know you had a intake which you remove before bringing it in.
Sent from my HTC6500LVW using Tapatalk
chriscross_tnt is offline   Reply With Quote
Old 12-05-2013, 11:53 PM   #23
Darkrune
Darkrune's Avatar
Drives: 2017 86
Another amazing post added by someone who thinks adding a bung and another sensor for safety would cause damage. Even so, let's rule out exhaust and dig in a little here. We are arguing about retarded warranty issues instead of helping out a fellow board member. Sorry, but when you join a community, even as a tech, you are here as a comrade. So stop this, "I am a tech" bullshit.
Number two: when he raised his idle, his problems went away. That sounds like cam related issues which a bung (or other parts etc) would not cause.
Maverick, get your cam related parts checked out man. Sounds like you might be on the edge of catastrophe.
Local Toyota dealership paints FR-S mural draggin_az FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 04-20-2013 08:21 PM
Toyota 86 at a dealership in Montego Bay Jamaica RyPaul FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 01-05-2013 03:52 PM
Local Dealership Service Issues 31katys Northwest 9 12-29-2012 09:01 PM
Toyota Dealership Stock JiB AUSTRALIA 55 08-15-2012 07:03 AM
My local US Toyota dealership now taking deposits! dookie11 Scion FR-S / Toyota 86 GT86 General Forum 20 09-12-2011 11:51 AM
