Old 11-26-2013, 09:51 PM   #1
pinaygirlcassy
pinaygirlcassy's Avatar
Drives: Scion FR-S
Work VS-XX 18x9.0 +13
I just got some rims, 18x9 +13 all around with 215/40/18 tires. what would I have to do to make it look right? lol I'm pretty new to all this fitment stuff :p
http://www.workwheelsusa.com/product...ry=26&wheel=75
Instagram: pinaygirlcassy
pinaygirlcassy is offline   Reply With Quote
Old 11-26-2013, 10:03 PM   #2
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
pics?! They will poke like crazy in the front btw very interested in this
Old 11-26-2013, 10:16 PM   #3
pinaygirlcassy
Drives: Scion FR-S
can't throw them on just yet :/ only has tires on 2 of them. but I will post some as soon as I get tires for the other 2 lol
Old 11-27-2013, 02:04 PM   #4
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Could you just take pics of the tires on the rim? Curious how streached a 215 would look like on a 9" wide rim.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
texasbound972 is offline   Reply With Quote
Old 11-27-2013, 02:29 PM   #5
FunCon5
FunCon5's Avatar
It will poke 12mm more than this guys car. http://www.ft86club.com/forums/showthread.php?t=37848 Camber will be needed to tuck the top of the wheels. I am sure that others with aggressive offsets will be able to tell you the parts and brands they have used.
FunCon5 is offline   Reply With Quote
Old 12-02-2013, 01:12 PM   #6
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Nobody in the Wheel Directory has that wheel spec yet... I would like to add your wheels once you get them installed. Post some photos here once you get them installed.
What brand/model wheels are they anyway?
Thanks!
Old 12-02-2013, 04:31 PM   #7
pinaygirlcassy
Drives: Scion FR-S
it'll take time considering I have no suspension mods yet but they're work vsxx!
Old 12-02-2013, 09:47 PM   #8
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
you will DEFINITELY need suspension mods if you want it to look "right".
you need a full coilover and the control arms (or airbag the car).
you'll need lots of drop and camber but you can probably pull that off no problem in Cali. (then again, that crazy guy Vic does it here in NY so...)
that's a fairly aggressive fitment for this car. You can definitely run those wheels, but expect to make sacrifices.
dori. is offline   Reply With Quote
Old 12-02-2013, 11:05 PM   #9
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
You will only need coilovers to make them fit
Old 12-02-2013, 11:13 PM   #10
FlushBrz
SlammedFR-S
FlushBrz's Avatar
Drives: 13 FR-S
Might need a little more stretch in the front.. That's pretty aggressive.
FlushBrz is offline   Reply With Quote
Old 12-02-2013, 11:14 PM   #11
SmsAlSuwaidi
Boosted
A slight roll/pull upfront and - camber is all she needs, im running 9.5 +25 and i think i can pull off a 10mm spacer
Sent from my IBrick
Old 12-02-2013, 11:22 PM   #12
pinaygirlcassy
Drives: Scion FR-S
what about camber arms?
Old 12-02-2013, 11:26 PM   #13
SmsAlSuwaidi
Boosted
if you max your coils i think you can achieve -3sh -4 which might be sufficient ! Regarding the fronts you could add camber bolts just to be safe !
ill upload pics of my front that i just took in a few minutes
Old 12-02-2013, 11:50 PM   #14
SmsAlSuwaidi
Boosted
My specs are 9.5 +25 thou with maxed out camber plates
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
pinaygirlcassy (12-03-2013)
