Old 12-01-2013, 06:11 PM   #15
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
Its the extra oxygen molecules in the same volume of air. Its not more air being stuffed in.
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
The Following 2 Users Say Thank You to czar07 For This Useful Post:
glorydays (12-12-2013), humfrz (12-01-2013)
Old 12-01-2013, 06:21 PM   #16
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Curious is this no longer being taught in schools? I'm asking as by assumption the OP may be a young fellow but obviously old enough to drive. Discussions on air density etc for me in school were far before the age of 16 so just curious is all.
The Following User Says Thank You to OICU812 For This Useful Post:
burnt toast (12-12-2013)
Old 12-01-2013, 06:31 PM   #17
trekkie
Drives: 2011 Camry Hybrid
You expect people to remember chemistry and physics after high school? It was a class you had to pass, not something you use in life, just like algebra and fractions
trekkie is offline   Reply With Quote
Old 12-01-2013, 06:34 PM   #18
OICU812
Just a dude
OICU812's Avatar
Pretty sure I learned that in like grade 5 or 6 "Science" actually.
Sorry I guess I have had to deal with "cold air" every year of my life where I live so perhaps it was obvious as a youngster even and well can't forget when you see cold temps again and again yearly lol. Everything with a motor always is beast in winter.
Old 12-01-2013, 07:15 PM   #19
BANGER
mad tyte jdm y0
BANGER's Avatar
Drives: 2010 Civic FA1
Send a message via AIM to BANGER
I should really switch to a CAI.
I think I've been irrationally afraid of hydrolocking for too long.
I do live in SoCal after all...
http://img.photobucket.com/albums/1003/Saki_AFA/Civic%202010/86sig.jpg
BANGER is offline   Reply With Quote
Old 12-01-2013, 09:19 PM   #20
Well, I learnt about the cold air thing, back on the farm; I noticed my tri-cycle would go faster, during the cool of the evenings ....... I wonder if that is related ....??
Old 12-01-2013, 09:30 PM   #21
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Originally Posted by Speedy000 View Post
because u dont have your ac on!
I know you're kidding, but this shouldn't make any difference on any modern car - all modern cars should automatically disconnect the AC compressor when full throttle is applied, so it shouldn't make any difference in available power.
chrisl is offline   Reply With Quote
Old 12-01-2013, 09:37 PM   #22
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Does the BRZ have knock sensors? If it does then the engine won't make more power in cold weather.
Turbo engines do if they are intercoolers.
Suberman is offline   Reply With Quote
Old 12-01-2013, 09:39 PM   #23
Suberman
Not only that but the compressor doesn't run at all in cold weather because the evaporator would freeze up. Plus 3C or about 40F is the lowest temperature at which the AC can operate. There's an anti frost switch which opens at that temperature and disconnects the drive pulley from the compressor.
Old 12-01-2013, 11:10 PM   #24
Rico415
Rico415's Avatar
Drives: 13FR-S
which make it more dense (MASS PER VOLUME) hence more air.... And it is not just more oxygen all elements in "air" are equally represented.
Rico415 is offline   Reply With Quote
Old 12-02-2013, 11:35 AM   #25
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I wonder if this is related to the engine cutting power when it gets too hot. I remember reading about a dyno test that saw a significant power decrease after just 1 pull in semi hot conditions.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 12-02-2013, 10:40 PM   #26
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Dry Cold air is Mother Nature's version of forced induction. The difference at the drag strip is extreme. Not unusual to see a half second difference between best and worst conditions.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 12-03-2013, 05:58 PM   #27
czar07
czar07's Avatar
Yes you are right, but I am just being pedantic about the term "more air" which to me sounds like a larger volume of air, which is NOT the case unless you are FI
Old 12-03-2013, 05:59 PM   #28
OrbitalEllipses
Drives: Attitude
Air density.
/thread
zaptorque (12-05-2013)
TPMS IN COLD WEATHER Scionshaun Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 11-20-2016 07:27 AM
Power window fault in cold weather Suberman Issues | Warranty | Recalls / TSB 5 01-09-2014 10:24 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
This car really hates the cold weather Craig Issues | Warranty | Recalls / TSB 55 01-28-2013 07:42 PM
rattling in cold weather mezdup Issues | Warranty | Recalls / TSB 2 01-22-2013 10:32 AM
