#15 |
Drives: '97 RSP JZZ30 GT-T
Its the extra oxygen molecules in the same volume of air. Its not more air being stuffed in.
Germans>Japanese>Italians>Americans. Unless its a Corvette. |
#16 |
Just a dude
Drives: Scion FR-S 2013
Curious is this no longer being taught in schools? I'm asking as by assumption the OP may be a young fellow but obviously old enough to drive. Discussions on air density etc for me in school were far before the age of 16 so just curious is all.
| The Following User Says Thank You to OICU812 For This Useful Post: | burnt toast (12-12-2013) |
#17 |
Drives: 2011 Camry Hybrid
You expect people to remember chemistry and physics after high school? It was a class you had to pass, not something you use in life, just like algebra and fractions
#18 |
Just a dude
Pretty sure I learned that in like grade 5 or 6 "Science" actually.
![]() Sorry I guess I have had to deal with "cold air" every year of my life where I live so perhaps it was obvious as a youngster even and well can't forget when you see cold temps again and again yearly lol. Everything with a motor always is beast in winter.
#19 |
mad tyte jdm y0
I should really switch to a CAI.
I think I've been irrationally afraid of hydrolocking for too long. I do live in SoCal after all...
#20 | |
![]() humfrz |
#21 |
Drives: 2006 Cayman S, 2007 Outback 2.5i
I know you're kidding, but this shouldn't make any difference on any modern car - all modern cars should automatically disconnect the AC compressor when full throttle is applied, so it shouldn't make any difference in available power. |
#22 |
Drives: Subaru BRZ Sport Tech Satin White
Does the BRZ have knock sensors? If it does then the engine won't make more power in cold weather.
Turbo engines do if they are intercoolers. |
#23 |
Not only that but the compressor doesn't run at all in cold weather because the evaporator would freeze up. Plus 3C or about 40F is the lowest temperature at which the AC can operate. There's an anti frost switch which opens at that temperature and disconnects the drive pulley from the compressor.
#24 |
Drives: 13FR-S
#25 |
Drives: Whiteout FR-S
I wonder if this is related to the engine cutting power when it gets too hot. I remember reading about a dyno test that saw a significant power decrease after just 1 pull in semi hot conditions.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#26 |
Drives: 2013 FRS / 2013 427 Vert
Dry Cold air is Mother Nature's version of forced induction. The difference at the drag strip is extreme. Not unusual to see a half second difference between best and worst conditions.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#27 |
Yes you are right, but I am just being pedantic about the term "more air" which to me sounds like a larger volume of air, which is NOT the case unless you are FI
#28 |
Drives: Attitude
Air density.
/thread |
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | zaptorque (12-05-2013) |
| TPMS IN COLD WEATHER | Scionshaun | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 11-20-2016 06:27 AM |
| Power window fault in cold weather | Suberman | Issues | Warranty | Recalls / TSB | 5 | 01-09-2014 09:24 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
| This car really hates the cold weather | Craig | Issues | Warranty | Recalls / TSB | 55 | 01-28-2013 06:42 PM |
| rattling in cold weather | mezdup | Issues | Warranty | Recalls / TSB | 2 | 01-22-2013 09:32 AM |
