Old 11-26-2013, 01:33 AM   #15
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by gatorbushmen View Post
yep I'm top one as well. i bet you that's the problem. Im gonna go try it now, haha.
cool. let me know. i miss having a phone charger built in
lbroskee is offline   Reply With Quote
Old 11-26-2013, 02:06 AM   #16
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
PROBLEM SOLVED
Sorry it took me awhile I was fiddling with aha lol
gatorbushmen is offline   Reply With Quote
Old 11-26-2013, 02:07 AM   #17
lbroskee
lbroskee's Avatar
PROBLEM SOLVED
wow that really was the issue? unbelievable. i was honestly pulling that outta my ass. hahaha, but glad we figured it out
Old 11-26-2013, 02:27 AM   #18
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
PROBLEM SOLVED
So, after you plug the square gray into the bottom one, the USB charge works again???
Old 11-26-2013, 08:42 AM   #19
gatorbushmen
Amateur Drifter
Drives: '13 FRS
Yep! after looking on a DIY it even says to make sure you plug the gray one next to the GPS antenna on the bottom haha
Old 11-26-2013, 10:58 AM   #20
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Where did you install the GPS atenna ? On the side or on the top of the head unit?
Old 11-26-2013, 10:59 AM   #21
lbroskee
lbroskee's Avatar
GPS goes into the slot rt above left blue sqaure
Old 11-26-2013, 11:03 AM   #22
gatorbushmen
Amateur Drifter
Drives: '13 FRS
Do you mean the antenna itself? There is a metal bar in the back of the dash that you can see if you take out your head unit. I placed the magnetic antenna on top of the bar and wedged it between some wires on the right side.
Old 11-26-2013, 11:34 AM   #23
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
The "metal bar", I take the head unit out but can't find which metal bar you mention. For now I haut place the GPS antenna on the right side of the head unit. Kinda lag when it is try to find location.
Old 11-26-2013, 11:35 AM   #24
lbroskee
lbroskee's Avatar
look into the opening to the left. there is a metal bar that goes down at an angle. attach to that. i get no lag there. if u still do it could b ur area in which case ill want it in the open more
Old 11-26-2013, 12:22 PM   #25
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
OK. I will go do it again tonight after work. thanks..
Old 11-26-2013, 10:55 PM   #26
86black
Drives: Low and slow
I was gonna say both the gps and the usb connection are right next to each other on the bottom. I just recently installed mine. If you guys fix the plugs it'll start working. The top gray connector (similar gps connection) and 16pin connector above is for euro/other model so those two are left out.
86black is offline   Reply With Quote
2014 bespoke headunit with aha questions?? 86black Electronics | Audio | NAV | Infotainment 8 09-02-2014 12:08 PM
Bespoke (2013 or 2014) Tman08 Want-To-Buy Requests 4 12-02-2013 03:08 AM
Bespoke problem with connecting sweetfrs Electronics | Audio | NAV | Infotainment 1 04-24-2013 01:01 PM
FR-S Bespoke Contact List Transfer Problem Wayne Electronics | Audio | NAV | Infotainment 5 02-14-2013 01:08 AM
Video Connection Bespoke Problem. dale.m Electronics | Audio | NAV | Infotainment 6 02-10-2013 07:54 AM
