Old 11-26-2013, 06:15 PM   #1
3essess
Drives: frs
E-Brake Activates With a Loud THUD
Just wondering, when you're moving, does anyone's e-brake activate with a loud thud when pulled? I'm not talking about drifting, just at say <5mph? Wonding if something is wrong or just normal "sounds." Thanks.
3essess is offline   Reply With Quote
Old 11-26-2013, 06:40 PM   #2
OrbitalEllipses
Drives: Attitude
Normal play in the drum. Don't use the brake while moving unless it's an EMERGENCY and you won't hear that sound.
Old 11-26-2013, 07:27 PM   #3
dontpanic
Drives: shiny side up.
yup. every one i've driven in does that. haven't bothered to chase it down.
dontpanic is offline   Reply With Quote
Old 11-26-2013, 09:03 PM   #4
FirestormFRS
Try it in any other car and get back to us with the result....pretty sure we all know already.
FirestormFRS is offline   Reply With Quote
Old 11-26-2013, 10:16 PM   #5
3essess
Drives: frs
Thanks all...guess that is how a drum brake works.
Old 12-09-2013, 04:36 AM   #6
arashishozen
Guest
Posts: n/a
I thought it had.disc brakes all the way around
Old 12-09-2013, 08:26 AM   #7
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
e-brake is a drum. Rear are drum/disc. (drum for e-brake only)
Old 12-09-2013, 08:53 AM   #8
arashishozen
Guest
Posts: n/a
O.o really? I didn't know that
Old 12-09-2013, 10:38 AM   #9
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
All it needs is to have the parking shoes adjusted. Mine went away after I adjusted them
LavosTRD is offline   Reply With Quote
Old 12-09-2013, 01:02 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Look at rear brakes. There's two sets of "brake lines"... one goes to the caliper, other goes to the rear hub.
Rear disc + drum parking brake.
-alex
Old 12-10-2013, 09:53 PM   #11
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Are you in gear while activating the e-brake?
ashtray is offline   Reply With Quote
Old 12-10-2013, 10:51 PM   #12
DOTman05
Drives: Evo 8
Normal sound
DOTman05 is offline   Reply With Quote
Old 12-11-2013, 01:20 PM   #13
Nm86
Drives: Ultramarine
That's the anchor hitting the ground.
Nm86 is offline   Reply With Quote
Thud putting in gear? Shad0ez Engine, Exhaust, Transmission 3 10-29-2013 04:29 PM
Loud thud from inside car when driving over things? Weeber Scion FR-S / Toyota 86 GT86 General Forum 21 10-15-2013 03:04 AM
Anyone get clutch rattle or thud? teamturbo Issues | Warranty | Recalls / TSB 4 08-11-2013 03:17 PM
Thud/Clunk when shifting. erom Engine, Exhaust, Transmission 10 06-17-2012 08:08 PM
Thud when engaging 1st anyone else? earthsscum Engine, Exhaust, Transmission 47 06-13-2012 08:26 PM
