Old 11-21-2013, 09:49 PM   #85
DJCarbine
Thupercharged
DJCarbine's Avatar
It would be convenient if a vendor sold a "DI seal replacement kit" with the tool, seals, and all required misc parts
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 11-22-2013, 11:06 PM   #86
aCab
aCab's Avatar
Drives: FR-S & S2k
To be fair, I probably tracked the car 14 days untuned with some mountain runs untied as well. Then probably 20+ days tuned
Bilstein Damptronic Prototypes | Other silly bits
aCab is offline   Reply With Quote
Old 11-22-2013, 11:07 PM   #87
aCab
aCab's Avatar
Drives: FR-S & S2k
My service writer called me today...asked if I messed with the motor at all in the engine bay. Apparently, the timing cover and a coil were dislodged from their proper location - not sure why as I never touched anything.
The Following User Says Thank You to aCab For This Useful Post:
CSG Mike (11-23-2013)
Old 11-23-2013, 01:27 AM   #88
CSG Mike
CSG Mike's Avatar
I didn't know u did that many O.o
Old 11-24-2013, 03:59 PM   #89
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
My P0351 code popped again today while logging the stock rom. Thought I would log some of the misfire parameters that you can. cylinder 1 with the coil code misfired once. However cylinder 4 misfired 40 times according to the software. That can't be good. Wondering if that means the di seals are leaking to be miss-firing that much. if its this bad I would assume a miss-fire code no?
This car has never seen a track day. just some good old fashion mid-western back roads.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 11-24-2013, 04:58 PM   #90
suaveflooder
suck….keep us updated @feldy
suaveflooder is offline   Reply With Quote
Old 11-24-2013, 06:28 PM   #91
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Could just be be a bad coil?
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 11-24-2013, 08:13 PM   #92
Ozzman
Drives: old
Could also just be an anomaly, Ford ecu's have to see somewhere over a thousand misfires before they will throw a code. Just keep an eye on it.
Ozzman is offline   Reply With Quote
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Wind noise from door seal - possible fix nzer Issues | Warranty | Recalls / TSB 2 05-05-2013 03:36 PM
DetailersDomain.com - Clean Up - and Seal - Audi S4 DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-08-2013 05:16 PM
Nitro seal applied bacon_cheese_beer Cosmetic Modification (Interior/Exterior/Lighting) 0 11-19-2012 01:22 PM
Whiteout FR-S | Detail + HD Nitro-seal MattR Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 09-20-2012 02:15 PM
