#2563 | |
On the latest run we hit 190tq at 4250rpm compare that to my stock run on the same dyno dynamics and its 105 tq at 4250rpm. I think when you do the Math on that you will find that it is indeed 80 percent(with TQ300 system). This is why i gave a range... TQ250 system is usually around 50 percent gain in torque from 4500 rpm and below. Talking about hp, my highest run on the tq300(fully stock) was 207hp(@6750), my highest run STOCK on the same dyno was 165 at 7100.....at 6750 it was only 159hp.....thus a 30% increase.....and again why i claimed a large range. I guess i could have said between 2000 RPM and 7500RPM you will experience a 20% to 50% increase in tq and power worst case.... but what fun is that. My numbers are put up for everyone to see, i havent held anything back.... thanks for keeping me honest This isnt an exact science.... every car is different.... my car seems to do very well for stock but losses top end to some of the guys with full exhaust. |
#2564 | |
Drives: VW
Don't take it from me, look at any compressor map of a large wheel (ex.T76). The surge line occurs @ higher flow rates, making it a very poor choice for low and mid engine rpm's for a ~200 HP engine. There are other ESC being developed with real engineering. Choice promotes excellence. |
| The Following 2 Users Say Thank You to Robftss For This Useful Post: | DAEMANO (11-21-2013), neutron256 (11-20-2013) |
#2565 | |
Drives: New and Old POS
I will continue to read more and keep my keyboard to myself LOL. |
#2566 | |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
Those maps pertain to one wheel in one housing. |
#2567 | |
Drives: VW
#2568 |
Atoning Unifex
Drives: '13 BRZ Premium, WR Blue
I went into "dealer mode" tonight before a service appointment in the morning, and I timed myself doing it. It took 14 minutes for me to swap the supercharger with the Perrin inlet tube, disconnect the controller's cable harness, and disconnect and stash the display for my advanced monitor.
Half of that time was me wrestling with my nemesis: the crankcase breather hose. |
#2569 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#2570 |
Drives: Raven FR-S
You guys are funny I just thru a CEL involving the ingnition coil P0351. Took the car in as-is. The code is becoming common with premature failures invoving cylinder 1's ingnition coil. Also did you guys flash the ecu and refuse the recent update?
#2571 | |||
Drives: Passat
Fenton did that in 2 minutes flat, no exaggeration! J/KQuote:
Hey Gary, If you wanted to defend Fenton's claims, you could not have picked a better dyno sheet! The one you chose shows the largest hp/tq gains over stock. Even then it still doesn't actually support his claims and I thank you for taking the time to post this best case data. Still, what I see when looking at all of the Phantom ESC dyno results posted to date are TQ gains of 30-70% in the dip and 15-25% near redline on the Dyno Dynamics sheets and TQ gains of 25-50% in the dip and 15-25% near redline on the Dynojet sheets. Maybe it's my OCD showing itself but I just can't concede that 25-70% can be called 50-85% nor is 15-25% close enough to say 25-35%. I don't believe the exaggeration was intentional nor do I wish to split hairs over a few percentage points but the figures quoted were just to far off for me to ignore. . Quote:
Sorry to bust your balls over a few percentage points but when stating a range of TQ gained within the TQ dip rpm range you can't accurately say that 25-70% is 50-85%. You seem to be quoting maximum peak TQ gains as they vary from different ESC's and dyno results including unseen new prototype results compared to an old baseline with 5 ft lbs subtracted and 5% gain added. This is getting far too muddled for me. Please carry on. I have only one more question for you, if you'll indulge me. Why is the 175 ft lbs ESC called the TQ250 and the 190ft lb model called the TQ300? What, if any, is the numerical significance in those model names? . Last edited by Fast_Freddy; 11-21-2013 at 02:08 AM. |
#2572 | |
Probaby
The baseline is the base line, every single time i went on the dyno dynamics the HP was within 1hp, even the day we tested the tq300, i just dont have the baseline overlayed on the max torque run, sorry. To my knowledge, the model numbers do not stand for Torque. Instead they refer to the maximum engine HP the particular ESC can FLOW. So the TQ250 can flow enough air to not be a restriction on a 250 Crank hp engine..... This is derived from the CFM at redline. Now the TQ300 is still in the experimental phase and we are making ground on getting closer to that, what we are finding is that the TQ300 really needs supporting mods to help it get to that goal.... There are some interesting things on the horizon that should help this system. This isnt to say that as soon as you slap a esc on you are making 250 engine hp, or 300 engine hp for the tq300, it just means that the ESC can flow enough air for that to happen....alot still comes down to tune and gas and "x" and "y"...If the cams fall flat on their face after 6500 obviously it makes it very hard to reach that with minimal boost. Honestly if you look at it we are getting very close to that, stock crank hp 200hp...equals maybe 170whp(15% DT loss) Add ESC, 250 engine HP flow.... 212whp at 15% DT loss..... you can see that our engine needs extra help even though the esc is flowing "x" CFM. Hope that helps to clear things up. |
| The Following User Says Thank You to fenton For This Useful Post: | DAEMANO (11-22-2013) |
#2573 | |
Drives: VW
He has concerns of patent infringements, but I have assured him the Phantom design is purely prior art engineered. There is a patent for an electric motor driven centrifugal supercharger...but it was publish in 1958, yes, it has been that long! Also, electrically driven PD blowers have been used in factories since forever. He has build 30kW units, a number that I have no interest in, but would love to see integrated into the FA20. ![]() On the development side: @Bu-Tang has been confirming the PSH-12180NBFR (21Ahr) starter battery and new battery cover/clamp conversion bits. (website has pics 'install download'). The last couple of nights we registered no temp on the Farenheit scale, sluggish, but she started up! R&D continues..... Rob. |
#2574 | |
Did they S#it a brick when you rolled in with this Alien technology? |
#2575 | |
Drives: '13 GBS Subaru BRZ
There are tons of electric supercharger/turbo patents out there, but most specify some form of more complex drive or control system. For instance Mr. Knight's patent is for his three motor system. Others are incredibly vague to he point where they are probably unenforceable. The patent system is sadly very broken, and enforcement often comes down to whomever has the deepest pockets.
#2576 | |
Drives: Passat
No misunderstanding at all, certainly not what you just implied. I'll keep checking in to see if a Phantom ESC ever achieves an 85% peak TQ gain or BHP to match it's "TQ" numerical rating. I'd say things are pretty clear to me now.
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
