#15 |
Burnt clutch in 4800 miles would seem to indicate some kind of mechanical failure, especially if you've got a lot of experience driving manuals (and assuming you're not abusing the clutch). I'd escalate this as far up the chain as possible.
2022 BRZ Build 2013 FR-S Build |
#16 | |
Drives: Subaru BRZ Sport Tech Satin White
The reason unintended acceleration is ALWAYS a driver error is you should just select neutral and, if necessary switch off the engine. This is why neutral can be selected without pressing the brake pedal in all automatics. The same dufous who doesn't know this also can't tell the brake pedal from the accelerator. Misapplication of pedals is a well known phenomenon especially among driving instructors. Software does not cause throttles to open, the systems are redundantly fail safe. The same technology as fly by wire airliners use and military aircraft and trains etc etc. In olden days throttles used to stick open, return springs broke or fell off, throttle plates iced up or linkages broke. To be competent to drive safely you needed to know what to do if this happened to you: select neutral (or push in the clutch) and switch off. In those days the engine would explode if you didn't switch off, nowadays the rev limiter just cuts in so you have lots of time to switch off. Bottom line: the speed of the car is ALWAYS up to the driver. This post may save your life someday. |
#17 | |
Guy on internet
Drives: Slowly
#18 |
Drives: FR-S Asphalt/ CBR 1K
Thanks for the feedback guys. To shed some light, I do drive harder than merely commuting. I do not drift the car (purposely). It's gone to the canyons 15+ times and WSIR once. Over the phone, I was told that the clutch was "fried". That being said, I think the proper moral thing to do is to pay the bill.
I was under the impressions that these cars could be driven hard - not abused - but at least driven hard. |
| The Following User Says Thank You to FastOnFastOff For This Useful Post: | tdog227 (11-21-2013) |
#19 | |
Drives: 2013 BRZ, WRB
| The Following User Says Thank You to Ralph Spoilsport For This Useful Post: | Panman (11-24-2013) |
#20 |
Drives: MR2
A proper break-in for the clutch will also help extend the service life. So take it easy for the first 500 miles on your new clutch.
Sent from my SCH-I535 using Tapatalk |
| The Following User Says Thank You to nate89 For This Useful Post: | FastOnFastOff (11-20-2013) |
#21 | |
Your canyon carving or a day at the track shouldn't wear out a clutch on the FR-S (non-boosted). humfrz |
| The Following 6 Users Say Thank You to humfrz For This Useful Post: | Carwhisperer (11-20-2013), CSG Mike (11-20-2013), FastOnFastOff (11-20-2013), GT 86 Brah (11-24-2013), Marchy (11-20-2013), strat61caster (11-20-2013) |
#22 | |
Drives: '13 FRS - STX
I think I've seen a grand total of 4 threads about premature clutch failure (admittedly not in the track section), it's hard to tell if it's from abuse or not but your case is abnormal. I'd be looking into it more aggressively, but if $1600 is a small price to pay to get the monkey off your back and get back to things that matter it's understandable. Most of the people who bought this car were not expecting $1,000+ repair bills within the first two or three years of ownership (hell I'm looking at spending less than $200/year plus tires and gas), you're going to see a lot of resistance for shelling out the money. If it was my car, I'd be doing the repair myself, but I'm insane. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | FastOnFastOff (11-20-2013), Tgionet (11-20-2013) |
#23 |
NASA SpecE30 Racer
Tell them you want to see the "fried" clutch. If it didn't fail due to wear, then in my mind it should be covered under warranty.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | sierra (11-22-2013) |
#24 |
That all sounds bogus to me. I drive my car plenty hard, done a number of Autoxes, my commute is through canyons, etc, etc...25k miles clutch feels fine.
| The Following User Says Thank You to jeebus For This Useful Post: | FastOnFastOff (11-20-2013) |
#25 |
#26 |
#27 | |
| The Following User Says Thank You to FastOnFastOff For This Useful Post: | strat61caster (11-20-2013) |
#28 |
They can tell if the clutch is "fried", usually the plate shows signs of slipping/heat, as well as the flywheel, which will show signs of being abused or being burnt up.
Sounds to me like your clutch hydraulic line may have lost pressure. This would cause the pedal to go to the floor, and with subsequent pumping, might get you half of it back. It might be as simple as tightening a loose fitting and rebleeding the system. Did they tell you what failed on your clutch? I would think, that even with abuse, it would be pretty hard to burn up or break a clutch in 4800 miles. I would stand your ground, go higher up the food chain, and get them to replace whatever's broken. Good luck! |
| The Following 2 Users Say Thank You to mike the snake For This Useful Post: | FastOnFastOff (11-21-2013), strat61caster (11-20-2013) |
| Tags |
| exploding clutch |
| Brz just broke 1k miles, clutch begins to feel grindy | rourich | Northern California | 14 | 10-11-2013 05:16 PM |
| Burnt Tips | Reggaeboyz | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 09-15-2013 11:58 PM |
| Faint Clutch Smell - 6,000 Miles | FnFast | Issues | Warranty | Recalls / TSB | 8 | 08-16-2013 05:17 PM |
| 700 Miles Blown Clutch | Bonburner | Issues | Warranty | Recalls / TSB | 76 | 09-23-2012 10:32 PM |
| 5k~ Miles - Clutch with extreme broken glass noise | Pscylo | Issues | Warranty | Recalls / TSB | 11 | 08-30-2012 02:12 AM |
