#99 |
Drives: Firestorm 6MT
Beautiful fabrication!
#100 |
Drives: Sterling BRZ Ltd
Should have taken a pic before I installed it but I trimmed the 2.5" mandrel bent front pipe and welded on the flanges and mounting bracket. Fits like a dream, 100% 304 Stainless 100% American made
| The Following 3 Users Say Thank You to mrk1 For This Useful Post: |
#101 | |
Drives: Asphalt Scion Frs 6MT
Should I just start throwing wads of money at you now or.... Start selling these.. Seriously.
#102 |
Drives: 2013 MT FS FR-S / 07 GT500
Don't need rear seats, but would like to layup a rear seat delete based around dat brace, must have!
Stage 1 V2 .57trim Turbo Kit, ACT HD6P Clutch w/Streetlite Flywheel, Greddy EVO3
391whp/295tq 13psi 96 pump 335whp/260tq 10psi 93 pump |
#103 |
Drives: GBS BRZ
Have you also modded that M3?
#104 |
@wulfgang what you see in the background is actually my e46 328i track car, has M3 wheels at the moment. I do also have a e46 Dinan M3.
#105 |
Current state of the 328 track day build,
![]() Dinan M3, I love this picture. This has been doing track duties for a while but the 328 will take that over.
| The Following User Says Thank You to mrk1 For This Useful Post: | wulfgang (11-20-2013) |
#106 |
2.5" front pipe back out to mock up the 3", here is a shot of it next to the factory part
#107 |
Drives: FR-S Whiteout
What material did you use to fab the exhaust manifold? Really nice fab work!
Intent > Content
cowardice is the mother of cruelty. |
#108 |
Manifold is 1/2 304 flanges, billet 304 CNC merge, and 0.065 304 runners. I've never made a 0.065 manifold before but I figured if try with this car given how large this manifold is. I may still build some sort of turbo brace to help support the weight of the turbo.
#109 |
Drives: 13 BRZ
Turbo should NEVER be supported by the header, especially one with .065" tubing. Definitely look into fabbing a turbo support before you crack that beautiful header.
#110 |
Yeah I'm waiting to get the charge piping in so I can see what will fit. There aren't to many mounting location I like off the engine side. I'm curious how much heat will be transmitted through the bracket. A bracket could piggy back off a pulley mounting bolt but I don't want to cook the bearing. Right now its looking like a 2 part bracket using the AC compressor mounting bolts, is my best option.
#111 |
FedEx man was late today so I got some time to play with a turbo support bracket, here is on the ties into the AC compressor mounting bolts.
| The Following User Says Thank You to mrk1 For This Useful Post: | solidONE (11-21-2013) |
#112 |
I would think material that thin (the runners) will have problems with heat stress from the turbo. Why did you not opt to use thicker piping such as a Schedule 10 or thicker piping over thinner tubing?
Intent > Content
| AMR Performance: How to remove the factory bumper (walk-through images inside) | AMR | Engine, Exhaust, Transmission | 9 | 04-10-2013 08:45 PM |
| 86 Modelista walk around and GT Limited | SoCal_86 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-24-2012 12:53 PM |
