Old 09-06-2013, 10:08 AM   #15
jonbonazza
Originally Posted by |-Goku-| View Post
P117B (Fuel System Abnormal (Di))
Hope this helps. From what I have seen, that code is coming up for people with an aftermarket intake.
Excellent, thanks! Time for a tune, I suppose
jonbonazza is offline   Reply With Quote
Old 11-04-2013, 01:48 AM   #16
asphalt86_915
asphalt86_915's Avatar
Drives: asphalt scion frs
I had the rich code also and a direct injection code, i have an injen intake and a header back exhaust, i got it fix but my ecm was losing communication with the vehicle, and my direct injection fuel was acting up, both where replaced once before, no issues with intake or the exhaust
asphalt86_915 is offline   Reply With Quote
Old 11-19-2013, 02:03 AM   #17
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
I too have an AEM intake (Electronically Tuned Intake, aka ETI). I was fine for a while and started getting codes. AEM has an ETI module that works with the MAF and sends the proper info to the ECU. I'm getting a new ETI module from AEM. I'll be seeing if that fixes the issue and then possibly going back to stock intake to see if that solves the problem.
Let me know if anyone has found the solution. I'm not opposed to a Tune, if it makes the car run better with all the bolt ons. I also have the rough idle issue.
It was also suggested that I contact the dealer to ensure that my car has the most recent ECU flash from the dealer.
G_Rossney is offline   Reply With Quote
Old 11-19-2013, 02:19 AM   #18
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
I had the same thing happen to me a few months ago. One cool morning started the car and got "RICH" code. I ended up re-installing the stock intake. Switched back to AEM the other day and had no code but I like the OEM intake a lot more. It feels better.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 11-25-2013, 09:35 PM   #19
G_Rossney
First, I'd like to say that AEM was very quick to send out a new ETI module. I thought that was very nice of them and good customer service.
So here is my trouble shooting. I cleared the code with my BT code reader and Android phone.
1. replaced stock intake with stock filter; Car ran really well. No rough idle, and it seemed to work exactly like it was supposed to run. I actually thought the car almost ran better with the stock intake back on the car.
2. put the ETI module on the stock intake. Car ran just like it did with the AEM intake. My assumption is the ETI is causing my issues.
3. put the new ETI module from AEM on the stock intake, car ran fine, almost like without the module. It seemed like the car's idle was a little low. I think this confirmed my assumption the ETI module was bad. The lower idle speed could be to compensate for the increased air flow through the intake.
4. I bought the Perrin inlet tube and the K&N high flow filter. I'm going to test this setup on the car. The AEM intake connects to the same inlet port as the stock intake, and that seems to be the biggest restriction to air flow. If the panel filter allows enough air through, the Perrin inlet tube should allow for more air (larger diameter) and less disruption in air flow (see their site). I still have the AEM intake to re-install if I want to test that versus stock box with Perrin inlet tube and hi-flow filter.
I agree with M.Wood, I actually like how the car drives overall with the stock intake and the engine noise in the cabin.
Another CEL code whitefrs Forced Induction 20 11-27-2019 12:27 PM
Check engine light came on (p0172) milkesfrs Issues | Warranty | Recalls / TSB 5 08-17-2019 04:33 AM
Engine Code: P0172 P117B *KID* Engine, Exhaust, Transmission 2 01-25-2013 05:23 PM
P0172 Code with Injen Intake, will EcuTek tune help? ron_jeremy Engine, Exhaust, Transmission 0 11-27-2012 12:22 PM
FR-S Chassis Code mediumbrown Scion FR-S / Toyota 86 GT86 General Forum 2 08-01-2012 11:04 AM
